MonoMachine problem with sysex dump of pattern
2007-05-09 by Patrik Rydberg
Hello! I ran into a pretty scary problem yesterday. I created a nice (I though to at least... ;o) ) pattern on my MonoMochine (OS 1.08). I then made a sysex dump of it (pat+kit), using TM-1 and C6. No problem, 1 pattern, 1 kit. Saved it, no problem. Tried to send it back, with the MM in "verify" mode, no problem, 2 messages, no errors, as it should be. However, when I tried to send it back for real, MM answered, 2 messages, 1 error. The kit got through OK, but not the pattern. Didn't matter if I used original location or specify. Allways, one error. Changed to the Midex8 midi interface, same problem. I have emailed this together with the dump to elektron support, but I just wanted to check, does anybody else have this? Regards /Patrik www.cutpaste.org
