Emax
OS reformat to disk ( SE PLUS 1.0 to ? )
2014-02-02 by loricruzer@...
Hi ,
I have an Emax SE , it has the SCSI which I use with a zip drive , the Emax is using OS 1.0 , works fine. I have some original SoftWorx disks that I would like to hear on my Emax.
The problem is that I can not format them to run on my Emax. In the 'Master' section, there is no way to copy the OS on to a floppy that doesn't have the same OS. If there is a way, then I don't know how. When I try to play the SoftWorx disk, display says 'different revision' .
How do I format the SoftWorx disk to the 1.0 OS ?
Thanks for the help.
Re: [emax] OS reformat to disk ( SE PLUS 1.0 to ? )
2014-02-02 by Windrumscoggin
There's two ways you can do this but it takes some time and you'll have to learn EMXP
Either create an OS disc in EMXP with the same OS as your softworx discs then update your  EMax to the OS required of the softworx discs and then load the discs
 or
transfer the softworx disks sound files to your PC then use EMXP to transfer those files to a floppy
You formatted on your EMax.
You can then load them in
Download and read up on how to use EMXP here
http://www.emxp.net
Le sorcière des Oscillateurs mystère
On Feb 1, 2014, at 9:57 PM, <loricruzer@...> wrote:
> Hi ,
2014-02-02 by jammie
emxp load floppy into pc then get bank it will read contents of floppy into memory save image as an emx floppy image
then put a fresh 3.5 720k disk in format it and add the new os to the disk
then put the emx bank onto the disk
if you have scsi you can create a zip100 image and do 35 banks on it and you can add it that way and then burn a zip100 disk
but for that you would require a ide or scsi zip in the pc
  To: emax@yahoogroups.com
  Sent: Sunday, February 02, 2014 5:57 AM
  Subject: [emax] OS reformat to disk ( SE PLUS 1.0 to ? )
  Hi ,
  No virus found in this message.
  Checked by AVG - www.avg.com
  Version: 2014.0.4259 / Virus Database: 3684/7051 - Release Date: 02/01/14
2014-02-03 by wandamusic@...
HI, All,
I joined but have not participated, as I have not played my emax for many
years, but thinking of pulling it out again.
I am not familiar with softworx, but I do recall that when I made "song
disks" where I'd have the os plus a supermodemap on a disk, I woiudl choose
the  disks I wanted to take sounds from,and one by one, I'd load the sounds
into the  song disk.
I do not recall the way I did this but I'd start with a nearly empty
supermode map/os disk, then switch floppies, to one with a soundbank I wanted,
and using one of the commands, load a sound bank into the memory.
After loading all the banks I wanted (I'd then save everything in the
memory to the floppy. (I did not have any HD, just the emax se)
I am wondering if that method might allow you to hear sounds that are on a
disk with a differnent os?
Wanda
In a message dated 2/2/2014 12:57:49 A.M. Eastern Standard Time,
loricruzer@... writes:
Hi ,
