EMAX I 16 levels?(MPC)
2015-02-02 by ozgoskar@...
Hi guys im wondering how can i setup a sample to 16 levels on my mpc? doing this by choosing a pad in mpc doesnt work, the pitch doesnt change. so i guess i need to turn note var tuning on my emax first, now the problem is how do i do this? THX.
2015-02-02 by w.niessen@...
2015-02-03 by ozgoskar@...
Nope i mean 16 levels from the mpc i know this is possible on the emax. It means the same sample on 16pads and every pad has diffrent pitch. Lets take bass as a example. I want to play it from my emax.
2015-02-03 by w.niessen@...
2015-02-04 by Robert Van Kuran
Like 'Pitch Keys' on the SP-12;) -RVK
> On Feb 3, 2015, at 2:51 PM, "ozgoskar@... [emax]" <emax@yahoogroups.com> wrote: > > Nope i mean 16 levels from the mpc i know this is possible on the emax. It means the same sample on 16pads and every pad has diffrent pitch. Lets take bass as a example. I want to play it from my emax. > >
2015-02-04 by Robin Sutcliffe
-RVKNope i mean 16 levels from the mpc i know this is possible on the emax. It means the same sample on 16pads and every pad has diffrent pitch. Lets take bass as a example. I want to play it from my emax.
2015-02-04 by Daniel H
This guy has lots of tips not in the manual, maybe it's in there?On 4 February 2015 at 04:06, Robert Van Kuran guitar5l50@... [emax] <emax@yahoogroups.com> wrote:Like 'Pitch Keys' on the SP-12;)
16 levels button will only control affect the MPC, not external gear. if you want a similar way to control your external sampler then you need to make a new PROGRAM and assign the pads to notes in ascending order. Then from the Main screen set that that as the program and set your midi output to external device 1a.. Save the program to use as your default program so you can pull it up quickly later when you want to do the same thing again..On Wed, Feb 4, 2015 at 3:03 AM, Robin Sutcliffe rssutcliffe@... [emax] <emax@yahoogroups.com> wrote:This guy has lots of tips not in the manual, maybe it's in there?On 4 February 2015 at 04:06, Robert Van Kuran guitar5l50@... [emax] <emax@yahoogroups.com> wrote:Like 'Pitch Keys' on the SP-12;)
2015-02-05 by Robin Sutcliffe
I've got a .pgm file like this, chromatic arrangement. I can send it if you want it.On 4 February 2015 at 18:17, Daniel H xxxdna@... [emax] <emax@yahoogroups.com> wrote:16 levels button will only control affect the MPC, not external gear. if you want a similar way to control your external sampler then you need to make a new PROGRAM and assign the pads to notes in ascending order. Then from the Main screen set that that as the program and set your midi output to external device 1a.. Save the program to use as your default program so you can pull it up quickly later when you want to do the same thing again..On Wed, Feb 4, 2015 at 3:03 AM, Robin Sutcliffe rssutcliffe@... [emax] <emax@yahoogroups.com> wrote:This guy has lots of tips not in the manual, maybe it's in there?On 4 February 2015 at 04:06, Robert Van Kuran guitar5l50@... [emax] <emax@yahoogroups.com> wrote:Like 'Pitch Keys' on the SP-12;)
2015-02-08 by ozgoskar@...
Yeah thanks i would apreciate that!!
2015-02-08 by Robin Sutcliffe
Here you go On 8 February 2015 at 01:47, ozgoskar@... [emax] <emax@yahoogroups.com > wrote: > > > Yeah thanks i would apreciate that!! > > [Non-text portions of this message have been removed]
2015-02-09 by el macaco
2015-02-10 by Robin Sutcliffe
I think 16 levels spits out the same midi note if assigned to a midi out, would be cool if it sent pitchbend data to it, although it would affect the whole program.
Easy way, Sample the Emax note into the MPC, press 16 levels, play emax sample from MPC.
Do the opposite too, bouncing samples from the MPC to the emax or between 2 samplers wth different strengths is great work flow.To: emax@yahoogroups.com
Date: Sun, 8 Feb 2015 18:51:49 +0100
Subject: Re: [emax] Re: EMAX I 16 levels?(MPC)
Here you go
2015-02-11 by ozgoskar@...
Thank you all for the answers, Do you guys know how i can put the program on disk?
i have omniflop and emxp. i know how to burn os but wont succes with burning programs:(
2015-02-11 by Robin Sutcliffe
