Emax
emax hd zip upgrade: wrong software error?
2003-06-30 by a7634
I recently installed the zip upgrade, am I correct, on an emax hd
model, you only need to replace the cable leading to the harddrive to
a nexternal zip drive using a connector (only one cable actually has
to be altered, right?) and install the emax plus os, however the emax
software I b ought from emulator archive gives me the "wrong
software" error. I doubt it could be their fault, but I've triple
checked my work now and have done nothing wrong...
any help would be fabulous
~AJB
RE: [emax] emax hd zip upgrade: wrong software error?
2003-06-30 by Rob Keeble
Details of the upgrade are here:
http://www.emulatorarchive.com/Samplers/EmaxOverview/EmaxSCSI/emaxscsi.html
Check you have the right motherboard, PAL chip, Boot ROM and SCSI chip.
It may be that the Plus OS software is built on the SE code base, in which
case you may need an SE model to start with. However the E-mu Systems
upgrade documentation is not specific about HD or HD SE. "wrong software" is
the error messge from a non-SE Emax when booting from SE software.
Rob
  ~AJB
        Yahoo! Groups Sponsor
  http://www.silveriafamily.com
Re: emax hd zip upgrade: wrong software error?
2003-07-08 by dragonmusik
> ~AJB
You cannot use a zip drive on an Emax HD,it is very specific,it will
only recognize a 20mb seagate hard drive.If you want to use removable
media for storage, you will have to get an EmaxII.
Dave
RE: [emax] Re: emax hd zip upgrade: wrong software error?
2003-07-09 by Rob Keeble
The Emax DOES work with 100MB SCSI ZIP drives. It formats them to 20MB (and
very quickly). The issue is that the SE OS version is needed as a pre-req to
using Emax OS Plus (which supports multiple SCSI ID's). Plus is an OS
extension to SE.
Regards Rob
  Dave
