Emax
Emax II and Emax disks
2003-07-11 by Kevin Kelley
It is my understanding that the emax II can read the emax I library.
If you place a emax I bank in the memory of an emax II and save it to
a new disk would it still be able to be read on the emax I? I would
like to archive my emax I library on a emax II but I was concerned
that it may no be able to be read if transferred back to the original
format.
Thanks
Kevin Kelley
Audio Playground
Re: Emax II and Emax disks
2003-07-11 by rascalrevenge
When you use the normal SAVE on Emax II, Emax I will not read the
data, also you would need two floppies instead of one, because it´s
16 bit data then, Emax I cannot handle multi-disk banks, it has only
512k Ram as you know. You must use the SAVE AS COMPRESSED BANK (i.e.
Emax I format) function of Emax II (see also manual). Hope this
helps. Nice weekend. Regs Rascal
library.
to
original
> format.
> Thanks
> Kevin Kelley
> Audio Playground
