Emax
EMX Program - Can't get it to work!
2003-08-19 by jdowning_wood
Okay, after many hours wasting my time with EMX and trying to
get it to work I have resorted to posting a message.
First, has ANYONE ever got this program to work? How!?!?
1st attempt seemed to work until I loaded the disk on th emax.
The sounds where all garbled (like a bad loop) but actually
loaded. But I was using DOS inside Win 2000 I found out that
was my mistake.
2nd Attempt. So I got out an older PC running Win 98 and
restarted in DOS mode, but now the EMX program says my
floppy disk sectors are bad (brand new DS/DD disk formatted on
the emax), even tried foramtting in EMX but got the same results.
3rd Attempt. Started from a boot disk, same results as 2nd
attempt.
Do I need to istall just MS-DOS on my HD? How?!!!
Any help would be great!
Thanks all
RE: [emax] EMX Program - Can't get it to work!
2003-08-19 by InTune@...
I've been able to make EMX work fine, doing it exactly as you have described
on your 2nd attempt. Have you tried different sample files?  I found that
some of the files that are available seem to be corrupt, maybe you just got
unlucky & tried those files.
Brad
http://www.silveriafamily.com
Re: EMX Program - Can't get it to work!
Thanks Brad,
I finally got it to work. Basically had to to do clean HD format and
install Win 98 (version A) and restart in DOS mode. For some
reason I couldn't get it to work from Win 98 version B? It was an
old machine so no big deal re-formatting, etc.
Interesting that it still won't format a Emax disk or OS without
errors, but will create the disks okay and verify them. All the ones
created so far work fine.
Thanks for the help!
--- In emax@yahoogroups.com, "InTune@B..." <intune@b...>
have described
found that
you just got
> Brad
Service.
RE: [emax] Re: EMX Program - Can't get it to work!
I'm glad you got it to work, I din't even realize there was a 'B' version of
window 98.  Now that I think about it, I think I also had to format the
disks on the Emax or they would not work.
Brad
  Sent: Tuesday, August 19, 2003 10:03 AM
  To: emax@yahoogroups.com
  Subject: [emax] Re: EMX Program - Can't get it to work!
  Thanks Brad,
        Yahoo! Groups Sponsor
              ADVERTISEMENT
