Emax
new to grp
new to grp
2003-09-07 by plaztikjezuz
hello,
new to the grp, i have a emax se, had it for a couple of years.
i used to use it a lot but it few tot he wayside when i got a laptop.
well now i have found my old disks and booted up a couple of the
factory disks and they sound killer.
my problem is i was never able to get any of the factory disks i d/l
to work right in the machine. i used a pc based program the used dos.
i now have both platforms mac or pc so i looking for a program that
can put the factory disks on 3.5 for me.
thanks
scotto
Re: new to grp
just wanted to add this.
was thinking and maybe the program never worked because i used it in
the dos shell window?
and the machine i have is the se model w/o the hd, how hard is it to
add a hd to the machine. or is it just not worth it these days
expacally since i use a laptop a ableton live already.
i also think my disk drive is going bad, are they had to replace? what
kind is needed?
and while i'm on disk what kind is the proper kind to use? SD or DD.
so to be so full of questions but i just pulled this machine out of
moth ball and was mainly using it as a controller but like the sounds
it had in it and some really fit into what i'm doing currently.
i'm also going through the archives so please dont think i'm one of
those people who ask ask ask and never look.
--- In emax@yahoogroups.com, "plaztikjezuz" <plastic_jesus_@h...> wrote:
>     hello,
> thanks
> scotto
Re: [emax] Re: new to grp
2003-09-08 by Matt Ferrari
To: <emax@yahoogroups.com>
Sent: Sunday, September 07, 2003 1:32 AM
Subject: [emax] Re: new to grp
> > scotto
Welcome to the group Scotto,
      the disks to use are double sided double density,
they are harder to find now days since not many people need them.
There is a slew of purchasing suggestions in the message archive here.
   In reference to the program your using to transfer sounds im assuming
your using the emx program that can be found in the files section of the
group?
   it will run in windows but you will find that the disks it makes will be
unusable
run it in dos only.
   check out the emulator archive and the emax II home page from the owner
of this group for info on disk drives..
Matt
