Emax
emax disc
emax disc
2003-09-28 by Kyle Kelley
I didn't know if it would be appropriate to ask, but I just recently bought an emax at a pawn shop, but it did not come with the factory disks. I printed the manual off the net, so I suppose I'll be able to get it up and running in a bit of a while (funny word choice there). I was just hoping someone could help me get a new disc that I can start up with. I also wondered if I had to use DS/DD disks or if HD discs work fine. Thanks.
Kyle
(Littleton, CO)
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
RE: [emax] emax disc
2003-09-28 by Rob Keeble
DS/DD's are best, but HD's will work with the HD hole covered.
I can supply Emax and Emax II OS diskettes, with a sample bank, brand new
DS/DD's. But I have to charge a nominal amount as I get loads of requests.
Contact me at info@... for details.
However I am sure someone on the list will be able to supply one for free.
Rob
  Kyle
  (Littleton, CO)
2003-09-29 by Kyle Kelley
Well in the last 24 hours, I've bought DD/DS disks, and formatted them using the emx program. i put the os on from the files section of this usergroup, and this is what I get:
After booting with disk in drive the emax says "loading software" while it makes the same noise of Click       click        click-da-click                                click        click            click-da-click and so on and so on. I wonder if maybe the os is bad, my emax disk drive is bad or the emx prog. I dunno. If you could help that would be cool. I would buy your set for newbies as you might call it if you think it will work.
My Aol Instant Messenger s/n is DirtyMorpheus if you (Rob) or anyone else can be of assistance. Thanks for your time.
Kyle
Rob
  Kyle
  (Littleton, CO)
Yahoo! Groups SponsorADVERTISEMENT
http://www.silveriafamily.com
Do you Yahoo!?
2003-09-29 by Brian Ronn
Hi Kyle,
I'll recommend you to format the discs in the Emax and write the banks to the DS/DD disc from the EMX program. That'll work.
Be aware that Emx program must be run in a pure DOS box, not an emulated DOS box from windows.
Best regards
Brian
Kyle
Rob
  Kyle
  (Littleton, CO)
Do you Yahoo!?
Yahoo! Mail - Gratis: 6 MB lagerplads, spamfilter og virusscan
I'm afraid I have no start-up disks to try that... I
would have started that way in the first place...
yea...
--- Brian Ronn <brian_ronn@...> wrote:
> Hi Kyle,
> Best regards
> Brian
> this is what I get:
>                   click        click
> for your time.
> Kyle
> Hi,
> hole covered.
> Rob
> but I just recently
> work fine. Thanks.
>   Kyle
>   (Littleton, CO)
> removed]
> Terms of Service.
> Do you Yahoo!?
> search
> removed]
> Terms of Service.
> virusscan
> removed]
Do you Yahoo!?
http://shopping.yahoo.com
Re: emax disc
2003-09-30 by hartmaan2003
Here's what I would do, as has been mentioned previously but maybe
not in this order.
1]Unzip the emx program to c:\emx under DOS
2]Copy the emaxos from the files section on this forum and place in
the emx dir
4]Launch EMX and at the menu run format emax disk (this was crucial
for me as previously I had used the EmaxII)
5]after that has completed - make an emax os disk from menu
Hopefully you can now place the disk in the Emax and boot it up :-)
There is the chance that the Emax FDD is dodgy!
P.S I am new to this and had a real time getting banks into the
beast - but trial and error prevailed.
> yea...
> --- Brian Ronn <brian_ronn@y...> wrote:
> > Hi Kyle,
> > Best regards
> > Brian
> > this is what I get:
> >                   click        click
> > for your time.
> > Kyle
> > Rob Keeble <rob@e...> wrote:
> > Hi,
> > hole covered.
> > Contact me at info@e... for details.
> > Rob
> > but I just recently
> > work fine. Thanks.
> >   Kyle
> >   (Littleton, CO)
> > removed]
> > Terms of Service.
> > Do you Yahoo!?
> > search
> > removed]
> > Terms of Service.
> > virusscan
> > removed]
> Do you Yahoo!?
