"soundmemorysize error ll"
2000-11-14 by Hans Törnqvist
Hi John.Thanks for your reply.I have one more question. How do I know if the daughterboard still has the memory installed.Chances are that the former owner has been taking it out.Cause there are a lot of empty spaces on the board John.If you know what I mean?!! The problem is that I dont know how it should look like if there really are memory attatched to the board. I have tried to fasten it but there is still only 1Mb reported. If you could in an easy way guide me thru this I would be more than happy.I would be madly happy. Thanks again. Hans. ----- Original Message ----- From: "John Joseph Silveria II" <emaxjs@...> To: "Hans T\ufffdrnqvist" <funkfingers@...>; <emax@egroups.com> Sent: Monday, November 13, 2000 5:58 PM Subject: Re: [emax] "soundmemorysize error" > > what!!!? My problem with the E-Max started when I bought a secondhand > > rack-version from a guy who told me that this unit had 4 or maybe 8 Mb of > > memory inside.He did not know for sure because he had not been using it > > for a couple of years and had lost his SCSI-cable for the > > harddrive(gasp,gasp).Well I bought it anyway,for a good price. When I > > started it for the first time the display told me that the unit had a > > "soundmemorysize error". I shut it down and the same warning came up > > again. I then tried to boot from a floppy-disc with the latest os and to > > my surprise the warning was gone.Only problem was,the memorysize was down
> > to 1 Mb!! "Is there anybody out there"that can help me to get those > > precious Mb back cause I love the sound of a healthy E-Max ll. > > Don't panic! > > A 4 thru 8Mb Emax II has a daughterboard with all the extra memory > that plugs into the original memory board of the unit. These are > notoriously difficult to get in and seated well enough for the Emax II to > recognize them. Chances are while in storage or while being moved > this board came loose and the Emax now doesn't see the amount of > memory it expects. > > You need to unplug the unit, take it off the top panel (back panel > comes with it to) and try to reseat the daughterboard. Chances are > once you do that the unit will see the memory and that's that. > > Pay attention to what you are doing while taking it apart, often the > output board's ribbon cable becomes unplugged and you'll need to plug > it back in before closing the unit up. > > There is a very slight chance that the Emax II might want you to > reinitialize the memory which means you might need to call E-mu. But, > don't worry about that, because it's highly doubtful. > > > > ********************************************************** > AIM/AOL: Emax JS **John Silveria II** ICQ: 60199476 > > Emax and Emax II User's Group - http://www.silveriafamily.com > Emax and Emax II Mailing List - emax@onelist.com > ********************************************************** > > > Emax and Emax II User's Group > > http://www.silveriafamily.com > >
