To: <emax@yahoogroups.com>
Sent: Monday, January 12, 2004 8:26 PM
Subject: [emax] Internal HD Install
> I have an Emax II tthat never had the internal HD. I've decided to
> finally do it. I have the case open, and I see the internal power
> supply cable, the brackets to screw the drive down to, but I'm not
> sure which of the ribbon cables is the appropriate cable to use. Also,
> they all seem to have a smaller connector than the SCSI 50 pin
> connector on the hard disk. Anyone have any experiences and feedback
> for me?
> Many thanks in advance.
> homershines
You need a scci cable, in my case 12" left no slack, and it
plugs in right next to where you see the ribbon from the floppy
drive close to the external scci port.
When I did mine, my power connector
was tied tightly so i had to snip the tie to
make it reach the hard drive.
If you have brackets in yours, your
one step up on me, because alls I had
was plastic molded holes at the top of the case.
There is a list of compatible drives on
the silveria site
http://www.silveriafamily.com/emax/emax2_drivelist.html
Matt
