Re: [emax] filtering and basslines
2005-02-13 by Hustler Avenue
What's up everyone. I've owned an Emax for a good while, but could never get a filtered sample to have that deep muffled sounnd i've heard off of s950's or that warm resonant bass that you would hear on an ASR. This can't be the case for this beast By the way, I'm new to the group and I'm glad you let me into the cypher. On Sat, 12 Feb 2005 08:48:00 -0800 (PST), emax@yahoogroups.com <emax@yahoogroups.com> wrote:
> > > There is 1 message in this issue. > > Topics in this digest: > > 1. Re: Re: Sampling, > From: "elmacaco" <elmacaco@...> > > ________________________________________________________________________ > ________________________________________________________________________ > > Message: 1 > Date: Fri, 11 Feb 2005 15:17:04 -0500 > From: "elmacaco" <elmacaco@...> > Subject: Re: Re: Sampling, > > IS your mod wheel up? ;) > > I sum the stereo out of my Turn table into a mono jack into the emax. Never had any problems, you usually need to turn the gain down from the default +40dB, are you running your turntable through a mixer or preamp of some sort? plugging the TT direct with the gain set to max won't cut it. > ----- Original Message ----- > From: gedankentief > To: emax@yahoogroups.com > Sent: Friday, February 11, 2005 4:26 AM > Subject: [emax] Re: Sampling, > > Hi, > i'm sampling from vinyl. Is the emax I able to sample stereo? There > is only one input, so I guessed it's mono. > I still believe it's a settings problem. How do all the others record > their samples, any special settings? (except rate, length, ...) > > Are there any general settings the emax stores and don't lose when > powered off? Already tried recalibration ... > > Any ideas or suggestions? > > Peace > Flo > > --- In emax@yahoogroups.com, "mandcmiller" <mandcmiller@e...> wrote: > > > > What is the source you are sampling? If the source is modulating, > but you are only > > sampling 1 channel, that may be the culprit. Or, if you are > combining both channels > > and there is a phase problem, that might also be the problem. > > > > Matt > > --- In emax@yahoogroups.com, "gedankentief" <flo.superstar@g...> > wrote: > > > > > > Hi there, > > > > > > i have little sampling problem with my emax I. The sampled sounds > are > > > always a bit pulsating, fluttery (??). You won't recognize it a > lot > > > with a short drum line, but with sustained samples. I checked the > LFO > > > and other settings and set all values to zero. The sound was > better, > > > but still not "original". > > > Do you know which settings I can check to solve that? I just want > to > > > put the emax on, sample a source and then sample from emax with > my pc. > > > Shouldn't be too hard to achieve??!! > > > > > > Thanks & greetings from Austria > > > Flo > > Emax and Emax II User's Group Website > > http://www.silveriafamily.com > > Yahoo! Groups Sponsor > ADVERTISEMENT > > ------------------------------------------------------------------------------ > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/emax/ > > b.. To unsubscribe from this group, send an email to: > emax-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > [Non-text portions of this message have been removed] > > ________________________________________________________________________ > ________________________________________________________________________ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.com > ------------------------------------------------------------------------ > Yahoo! Groups Links > > > > > ------------------------------------------------------------------------ > >
