To: emax@yahoogroups.com
Sent: Friday, February 11, 2005 4:26 AM
Subject: [emax] Re: Sampling,
i'm sampling from vinyl. Is the emax I able to sample stereo? There
is only one input, so I guessed it's mono.
I still believe it's a settings problem. How do all the others record
their samples, any special settings? (except rate, length, ...)
Are there any general settings the emax stores and don't lose when
powered off? Already tried recalibration ...
Any ideas or suggestions?
Peace
Flo
--- In emax@yahoogroups.com, "mandcmiller" <mandcmiller@e...> wrote:
> What is the source you are sampling? If the source is modulating,
but you are only
> sampling 1 channel, that may be the culprit. Or, if you are
combining both channels
> and there is a phase problem, that might also be the problem.
> Matt
> --- In emax@yahoogroups.com, "gedankentief" <flo.superstar@g...>
wrote:
> > Hi there,
> > i have little sampling problem with my emax I. The sampled sounds
are
> > always a bit pulsating, fluttery (??). You won't recognize it a
lot
> > with a short drum line, but with sustained samples. I checked the
LFO
> > and other settings and set all values to zero. The sound was
better,
> > but still not "original".
> > Do you know which settings I can check to solve that? I just want
to
> > put the emax on, sample a source and then sample from emax with
my pc.
> > Shouldn't be too hard to achieve??!!
> > Thanks & greetings from Austria
> > Flo
http://www.silveriafamily.com
Yahoo! Groups Sponsor
ADVERTISEMENT
Yahoo! Groups Links
http://groups.yahoo.com/group/emax/
emax-unsubscribe@yahoogroups.com
