Emax II boot problem
2005-06-13 by johnbrit2002
Hi, I have an Emax II which I bought in 1992. Recently it stopped booting from the hard drive. I suspected the drive and replaced it. It worked long enough for me to format and load the software from a floppy but then exhibited the same symptom. It is quite happy to boot from a Zip drive that I back all of my samples up to. I was told that the external SCSI port shares exactly the same bus as the the internal drive. Is this true or does the HD controller have two separate SCSI busses? Has anyone else experienced this. I replaced the HD cable to no avail. Could just be a dry joint, I suppose. Thanks
