Emax
RS422 Cable for Emax / Mac connection
2005-08-11 by Simon_Owen
Hi folks
Does anyone know where it's possible to get an RS422 Cable for my Emax, can't find one
anywhere and i can't solder for S**t, so if you know of anywhere to buy one in the UK, i'd be
glad of some help.
Cheers
Simon Owen
Re: [emax] RS422 Cable for Emax / Mac connection
2005-08-11 by gray
Is that RS422 a male or female 25 pin or 50 pin......
  To: emax@yahoogroups.com
  Sent: Thursday, August 11, 2005 11:43 AM
  Subject: [emax] RS422 Cable for Emax / Mac connection
  Hi folks
  glad of some help.
  Cheers
  Simon Owen
  http://www.silveriafamily.com
  YAHOO! GROUPS LINKS
    a..  Visit your group "emax" on the web.
    b..  To unsubscribe from this group, send an email to:
     emax-unsubscribe@yahoogroups.com
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2005-08-11 by gray
I think this might be the cable Im not sure what the RS422 looks like....
     Canadian$7.95
      6' Mac+ to HAYES MODEM- Mini Din 8 Male to DB25M- Hi-Speed CMPHM06-HS
gray
  Hi folks
  glad of some help.
  Cheers
  Simon Owen
  YAHOO! GROUPS LINKS
2005-08-11 by J R
I'm selling one (CABLE) with a MAC SE with Sound
Designer in original box with original disks if anyone
is interested.
$50.00 plus shipping from Orlando FL
>      Canadian$7.95
> DB25M- Hi-Speed
> gray
>   ----- Original Message -----
>   From: Simon_Owen
> connection
>   Hi folks
>   glad of some help.
>   Cheers
>   Simon Owen
>   YAHOO! GROUPS LINKS
> email to:
> removed]
____________________________________________________
Start your day with Yahoo! - make it your home page
http://www.yahoo.com/r/hs
2005-08-12 by ted Summers
The cable is an 8-pin mini-DIN to 9 pin D-SUB.....I built my
own.....just buy 2 of each end connector (about $6 for a total of 4
connectors), buy wire more than long enough to reach (typical about 26
cents a foot), and get a new tip with a small end for your soldering
iron. If you get a good soldering iron (not some $10 Radio Shack junk)
it will make an easier job of it. 15W soldering iron that costs around
$25 is reasonable, then test doing wires and soldering to a board that
is bad or something like that for practice. That is how you learn.....
in the beginning that is how I had to do it...
PS- the reason a more expensive soldering iron helps is this: cheap
irons lose their heat and so as you solder, the iron loses strength and
you either don't get a good connection, or you have to hold the iron
there and it heats the plastic of the connectors (ruining the end). A
good soldering iron won't lose heat as fast and cause that to
happen....(solder stations won't really lose heat at all- at least
noticeable to the average user)
Good luck,
Ted
> is interested.
>>      Canadian$7.95
>> DB25M- Hi-Speed
>> gray
>>   From: Simon_Owen
>> connection
>>   Hi folks
>>   glad of some help.
>>   Cheers
>>   Simon Owen
>>   YAHOO! GROUPS LINKS
>> email to:
>> removed]
2005-08-12 by gray
Is this what it looks like.......
Mac 128 512 512KE 6ft Printer Cable Imagewriter II^
$6.99
Computer Renaissance (by Manhattan cable) brand DB 9 male to mini din8 male ... also now have: The hard to find old Image writer 8 pin mini din (Mac connector) to ...
http://froogle.google.com/froogle?q=Mac+8+pin+mini+din+to+9+pin&hl=en&lr=&sa=N&tab=ff&oi=froogler
gray
  Sent: Thursday, August 11, 2005 10:51 PM
  Subject: Re: [emax] RS422 Cable for Emax / Mac connection
  Good luck,
  Ted
  > is interested.
  >>      Canadian$7.95
  >> DB25M- Hi-Speed
  >> gray
  >>   From: Simon_Owen
  >> connection
  >>   Hi folks
  >>   glad of some help.
  >>   Cheers
  >>   Simon Owen
  >>   YAHOO! GROUPS LINKS
  >> email to:
  >> removed]
  YAHOO! GROUPS LINKS
2005-08-13 by ted Summers
That is what it looks like. Whether the pinout is correct or not is
another matter. If you buy the cable and it doesn't work, try using a 9
pin to 9 pin null modem adapter....
Hope this helps,
Ted
