WAV-to-EMAX translator program for PC has been released
2005-11-08 by esynthesist
As some of you may have noticed I've put a WAV2EMAX conversion program in the files section a few days ago. I replaced that one now with a second build. You can find it here: http://launch.groups.yahoo.com/group/emax/files/WAV2EMAX/ This small DOS-program takes all .WAV files found in the ..\create folder and creates an EMAX-I compatible disk image out of it. This image can then be loaded in your EMAX-I or EMAX-II sampler, after you have put it on a disk using EMX. It should work (tests by Emalcaco and myself were succesful :-). Please read the readme.txt file first to find out how to use the program. It's very simple really, but you'll have to open a DOS window :-) Especially check the requirements for the .WAV files (16-bit, only mono or stereo, EMAX-I compatible frequency, ...) and total EMAX memory. This version of WAV2EMAX can not create full 16-bit EMAX-II images yet. This feature will be added in the next build. Have fun, ///E-Synthesist
