Emax
floppy jumpers
floppy jumpers
2006-05-21 by Bob Conner
Well I couldn't find any info.
Has anybody tried search the group posts?
Chances are if you got a DS DD drive from somewhere
(old computer or other device) it would work.
As far as jumpering, there can't be too many
combinations to try. It's either going to read or it's
not.
Bob
Do You Yahoo!?
http://mail.yahoo.com
Re: floppy jumpers
2006-05-21 by esynthesist
You probably already know the meaning of the jumpers on the TEAC FD
235 HF floppy drive and are just searching for the specific EMAX
settings. I don't know if I have a TEAC drive in one of my EMAX
samplers - I'll check it out.
Anyway, here is the meaning of the different jumpers on that drive. I
found it on some AKAI MPC forum:
A1 - B1 DS0 Drive select 0
B1 - C1 DS1 Drive select 1
A2 - B2 DS2 Drive select 2
B2 - C2 DS3 Drive select 3
C3 - D3 REN disable auto-recalibration
D3 - E3 ACD(a) disable auto-checking
E3 - F3 ACD(b) disable auto-checking
D2 - E2 RY34 Ready output on Pin 34
E1 - E2 DC34 Disk Change output on Pin 34
E1 - F1 DC2 Disk Change output on Pin 2
G1 - G2 HA density set automatically
F1 - G1 HI2 density set by HD IN on pin 2
F1 - F2 HO2 density (HD OUT) output on pin 2
F3 - G3 IR LED on when: (Drive Select AND Ready)
FYI: the following are the settings for the AKAI MP60 :-):
-> SET jumper DS0, HI2, RY34, ACD(b), and FG
-> But these settings are NOT for EMAX.
If I have a TEAC drive in one of my EMAX, I'll post the jumper
settings.
///E-Synthesist
> not.
> Bob
> Do You Yahoo!?
Re: floppy jumpers
OK so I checked my samplers and only one of them has a TEAC drive.
Unfortunately it's an FD-235-HF-5429, not an A-series.
Mine has only two jumpers :-)
Anyway here's some more information on all these drives.
http://www.teac.com/DSPD/pdf/3fd0020a.pdf
I hope someone on this group is willing to post the jumpersettings
for EMAX.
///E-Synthesist
I
> settings.
> ///E-Synthesist
> > not.
> > Bob
> > Do You Yahoo!?
Re: [emax] Re: floppy jumpers
2006-05-21 by ted Summers
Unfortunately, both emax's I have had Mitsubishi drives.
 From what I gather though, the following is true:
A1-B1 Jumpered
G1-G2 Jumpered (always make sure your DS/HD disks have the hole
covered so they act like 720k disks!)
Not sure about F3-G3, but try it off first.
The rest UNJUMPERED. The reason I say this is, I bought a standard
floppy drive (black- do not remember if it was teac, sony or mitsumi)
from newegg. I soldered the Surface mount jumper from ds1 to ds0.
Tested and it worked with no problems. Then I made a bracket so there
is no gaping hole in the front of my emax.
That is all I had to do to get a new working floppy in my emax
(though making the bracket took a while)....
Ted
> settings.
> ///E-Synthesist
>> not.
>> Bob
>> Do You Yahoo!?
> ------------------------ Yahoo! Groups Sponsor --------------------
> Get to your groups with one click. Know instantly when new email
> arrives
> http://us.click.yahoo.com/.7bhrC/MGxNAA/yQLSAA/QnLolB/TM
> http://www.silveriafamily.com
Help for OS disk
2006-05-28 by SG
Hi to everybody,
is there anyone who could ship to me a floppy disk (I live in Italy)
with the Emax OS 3.2 system?
I tried to ask at emulator archive so I sent some e-mail but I didn't
receive answer.
Thanks in advance for your kindness.
greetings
Simone
Re: [emax] Help for OS disk
2006-05-28 by SG
Ciao Davide e grazie per la risposta,
mi faresti una grande gentilezza perché non so più dove sbattere la
testa; il problema è che ho acquistato un emax I senza HD che veniva
venduto senza alcun OS di sistema e come un bischero l'ho preso
perchè pensavo che con emax utilities si riuscisse a creare un floppy
di sistema dal niente......... grrrrr.... dopo aver assemblato un pc
su cui ho installato il dos 6.22 ho capito che non funge; se sei in
grado di spedirmi un floppy con il system in oggetto fammi sapere che
provvedo a spedirti in pvt il mio indirizzo (le eventuali spese sono
ovviamente tutte a mio carico);
ti ringrazio in anticipo per la cortesia
Ciao
Simone
Il giorno 28/mag/06, alle ore 12:05, pasquale.aprea@... ha
scritto:
> ciao, forse ce l'ho.
> dico forse perchè ho appena installato l'upgrade SE e non posso
> quindi testarlo,
> inoltre devo cercarlo ma dovrei averlo e potrei spedirtelo.
> Nel caso posso crearlo con il pc ex novo, l'ho appena fatto con il
> floppy
> se upgrade ed ha funzionato.
> Se hai un qualsiasi OS ed il tuo emax è quindi in grado di
> formattare un
> floppy è molto semplice con emax utilities da dos creare l'os disk.
> ciao,
> davide (milano)
>> -- Original Message --
>> To: emax@yahoogroups.com
>> From: SG <amenophis@...>
>> Date: Sun, 28 May 2006 11:56:43 +0200
>> Subject: [emax] Help for OS disk
>> Reply-To: emax@yahoogroups.com
>> Hi to everybody,
>> receive answer.
>> greetings
>> Simone
>> Home is just a click away.? Make Yahoo! your home page now.
>> http://us.click.yahoo.com/DHchtC/3FxNAA/yQLSAA/QnLolB/TM
>> Yahoo! Groups Links
