EMAX PLUS has default external SCSI ?
2006-05-21 by esynthesist
Does anyone know if an EMAX PLUS has an external SCSI connector by default ? I saw a rackversion of an EMAX PLUS sampler yesterday, having the specifications "EMAX PLUS SE 'with SCSI'" printed on the front of it. But I couldn't find an external SCSI connector on the back. On emulatorarchive I read that the PLUS versions should have an external SCSI connector. I'm a bit confused... ///E-Synthesist
Yes, it was a sticker upgrade. I guess these only have internal scsi, don't they ? But they should be easily expandable I guess... ///E-synthesist --- In emax@yahoogroups.com, "elmacaco" <elmacaco@...> wrote: > > was it maybe a sticker upgrade? > > I'm not sure if any emaxes came with scsi connectors. > > ----- Original Message ----- > From: esynthesist > To: emax@yahoogroups.com > Sent: Sunday, May 21, 2006 7:07 AM > Subject: [emax] EMAX PLUS has default external SCSI ? > > > Does anyone know if an EMAX PLUS has an external SCSI connector by > default ? > I saw a rackversion of an EMAX PLUS sampler yesterday, having the > specifications "EMAX PLUS SE 'with SCSI'" printed on the front of it. > But I couldn't find an external SCSI connector on the back. > On emulatorarchive I read that the PLUS versions should have an > external SCSI connector. > > I'm a bit confused... > > ///E-Synthesist > > > > > > > Emax and Emax II User's Group Website > > http://www.silveriafamily.com > > > > SPONSORED LINKS Electronic instrument Emax Synthesizer music > Electronic music Music sampler Electronic musical instrument > > > -------------------------------------------------------------------- ---------- > YAHOO! GROUPS LINKS > > a.. Visit your group "emax" on the web. > > b.. To unsubscribe from this group, send an email to: > emax-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > -------------------------------------------------------------------- ----------
> > > > [Non-text portions of this message have been removed] >
2006-05-21 by elmacaco
was it maybe a sticker upgrade? I'm not sure if any emaxes came with scsi connectors.
default ?
///E-Synthesist
YAHOO! GROUPS LINKS
[Non-text portions of this message have been removed]2006-05-21 by elmacaco
Well the sticker upgrade explains it then. However upgraded it didn't install an external scsi port. Any Emax HD SE can have a scsi port added, the Emulator Archive gives great instructions on how to do it. This machine having the plus OS already makes it an easy upgrade, you just need an internal external scsi adaptor and an internal scsi cable, and a hole punch or drill :)
Sent: Sunday, May 21, 2006 12:44 PM
Subject: [emax] Re: EMAX PLUS has default external SCSI ?
///E-synthesist
> From: esynthesist
by
> default ?
it.
> ///E-Synthesist
instrument
> YAHOO! GROUPS LINKS
of Service.
YAHOO! GROUPS LINKS
[Non-text portions of this message have been removed]2006-05-21 by ted Summers
The rack emax that I bought off ebay recently had an external scsi port that looks factory to me. I can't test if it is good or not as I stole the chips and connector to make my keyboard SCSI, and when it arrived it was already "non-working". I do know it basically had a bad floppy controller chip for sure, and that the fuse holder is missing.... dunno how much of the rest of it is good or bad, but I know the scsi chips worked in my keyboard, and so I might have parts available if interest is out there.... for instance for the board that already has the external scsi connector there, ready to be attached to.....if someone didn't want to do that soldering / modification to rev 1 boards it would be a good choice. They are rev 3 boards... Or for someone who has a flaky emax, these might enable you to make 1 good working emax set.... the jacks off one of the boards were broken in shipping, but if you had one or two ports that need replacing, then you would have some to trade out... just a couple of ideas.... thanks, Ted
On May 21, 2006, at 12:02 PM, elmacaco wrote: > Well the sticker upgrade explains it then. However upgraded it > didn't install an external scsi port. > > Any Emax HD SE can have a scsi port added, the Emulator Archive > gives great instructions on how to do it. This machine having the > plus OS already makes it an easy upgrade, you just need an internal > external scsi adaptor and an internal scsi cable, and a hole punch > or drill :) > > > ----- Original Message ----- > From: esynthesist > To: emax@yahoogroups.com > Sent: Sunday, May 21, 2006 12:44 PM > Subject: [emax] Re: EMAX PLUS has default external SCSI ? > > > Yes, it was a sticker upgrade. > I guess these only have internal scsi, don't they ? > But they should be easily expandable I guess... > > ///E-synthesist > > --- In emax@yahoogroups.com, "elmacaco" <elmacaco@...> wrote: >> >> was it maybe a sticker upgrade? >> >> I'm not sure if any emaxes came with scsi connectors. >> >> ----- Original Message ----- >> From: esynthesist >> To: emax@yahoogroups.com >> Sent: Sunday, May 21, 2006 7:07 AM >> Subject: [emax] EMAX PLUS has default external SCSI ? >> >> >> Does anyone know if an EMAX PLUS has an external SCSI connector > by >> default ? >> I saw a rackversion of an EMAX PLUS sampler yesterday, having the >> specifications "EMAX PLUS SE 'with SCSI'" printed on the front of > it. >> But I couldn't find an external SCSI connector on the back. >> On emulatorarchive I read that the PLUS versions should have an >> external SCSI connector. >> >> I'm a bit confused... >> >> ///E-Synthesist >> >> >> >> >> >> >> Emax and Emax II User's Group Website >> >> http://www.silveriafamily.com >> >> >> >> SPONSORED LINKS Electronic instrument Emax Synthesizer music >> Electronic music Music sampler Electronic musical > instrument >> >> >> -------------------------------------------------------------------- > ---------- >> YAHOO! GROUPS LINKS >> >> a.. Visit your group "emax" on the web. >> >> b.. To unsubscribe from this group, send an email to: >> emax-unsubscribe@yahoogroups.com >> >> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. >> >> >> -------------------------------------------------------------------- > ---------- >> >> >> >> [Non-text portions of this message have been removed] >> > > > > > > > > Emax and Emax II User's Group Website > > http://www.silveriafamily.com > > > > SPONSORED LINKS Electronic instrument Emax Synthesizer music > Electronic music Music sampler Electronic musical instrument > > > ---------------------------------------------------------------------- > -------- > YAHOO! GROUPS LINKS > > a.. Visit your group "emax" on the web. > > b.. To unsubscribe from this group, send an email to: > emax-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > ---------------------------------------------------------------------- > -------- > > > > [Non-text portions of this message have been removed] > > > > ------------------------ Yahoo! Groups Sponsor -------------------- > ~--> > Get to your groups with one click. Know instantly when new email > arrives > http://us.click.yahoo.com/.7bhrC/MGxNAA/yQLSAA/QnLolB/TM > -------------------------------------------------------------------- > ~-> > > Emax and Emax II User's Group Website > > http://www.silveriafamily.com > Yahoo! Groups Links > > > > > > > >
I know on another post you had said someone else email may not have gone through, but I have emailed you several times over the past year with no response. Although I now have made my keyboard scsi from the rack I got off ebay (if you saw my other post), I now have a rack emax that no longer has the scsi chips. Are you still looking into making this upgrade available??? I am sure there are still a few people out there wondering about the availability of this upgrade. Thanks, Ted
2006-05-23 by mishon66@...
Ted
Yes well I found the chips but more is needed to make the upgrade than just the SCSI chip set.
Rich -----Original Message----- From: ted Summers <djtbs1@...> To: emax@yahoogroups.com Sent: Sun, 21 May 2006 15:12:16 -0700 Subject: [emax] To Route 66 I know on another post you had said someone else email may not have gone through, but I have emailed you several times over the past year with no response. Although I now have made my keyboard scsi from the rack I got off ebay (if you saw my other post), I now have a rack emax that no longer has the scsi chips. Are you still looking into making this upgrade available??? I am sure there are still a few people out there wondering about the availability of this upgrade. Thanks, Ted Emax and Emax II User's Group Website http://www.silveriafamily.com Yahoo! Groups Links [Non-text portions of this message have been removed]
2006-09-10 by esynthesist
Hi guys, here's a small update on the "emax plus without external scsi" topic... Yesterday we checked that EMAX PLUS SE racksampler again - the one I was talking about before. The sampler is an original factory EMAX PLUS SE version, not an upgrade as I mentioned before. There's no upgrade sticker, all printing is done on the frontpanel itself. But as I said, this machine has NO external SCSI onboard. Emulatorarchive says that EMAX PLUS always shipped with external SCSI, so I guess I found yet another "emax version": the PLUS without external SCSI :-) The machine has a very low serial number, so maybe that's the reason. Who knows ? (Dave Rossum :-) The sampler has a PC333 rev B board, and internal SCSI on the main board. I didn't buy it yet however because the display is giving trouble: after using the EMAX for a while and pressing some buttons, the display shows a black bar on the first line and a blank second line and it won't show anything else anymore. The sampler still works, but of course it's hard to use that way. Anyone experienced this problem yet ?? ///E-Synthesist --- In emax@yahoogroups.com, "elmacaco" <elmacaco@...> wrote: > > Well the sticker upgrade explains it then. However upgraded it didn't install an external scsi port. > > Any Emax HD SE can have a scsi port added, the Emulator Archive gives great instructions on how to do it. This machine having the plus OS already makes it an easy upgrade, you just need an internal external scsi adaptor and an internal scsi cable, and a hole punch or drill :) > > > ----- Original Message ----- > From: esynthesist > To: emax@yahoogroups.com > Sent: Sunday, May 21, 2006 12:44 PM > Subject: [emax] Re: EMAX PLUS has default external SCSI ? > > > Yes, it was a sticker upgrade. > I guess these only have internal scsi, don't they ? > But they should be easily expandable I guess... > > ///E-synthesist > > --- In emax@yahoogroups.com, "elmacaco" <elmacaco@> wrote: > > > > was it maybe a sticker upgrade? > > > > I'm not sure if any emaxes came with scsi connectors. > > > > ----- Original Message ----- > > From: esynthesist > > To: emax@yahoogroups.com > > Sent: Sunday, May 21, 2006 7:07 AM > > Subject: [emax] EMAX PLUS has default external SCSI ? > > > > > > Does anyone know if an EMAX PLUS has an external SCSI connector > by > > default ? > > I saw a rackversion of an EMAX PLUS sampler yesterday, having the > > specifications "EMAX PLUS SE 'with SCSI'" printed on the front of > it. > > But I couldn't find an external SCSI connector on the back. > > On emulatorarchive I read that the PLUS versions should have an > > external SCSI connector. > > > > I'm a bit confused... > > > > ///E-Synthesist > > > > > > > > > > > > > > Emax and Emax II User's Group Website > > > > http://www.silveriafamily.com > > > > > > > > SPONSORED LINKS Electronic instrument Emax Synthesizer music > > Electronic music Music sampler Electronic musical > instrument > > > > > > ---------------------------------------------------------------- ---- > ---------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "emax" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > emax-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > ---------------------------------------------------------------- ---- > ---------- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > Emax and Emax II User's Group Website > > http://www.silveriafamily.com > > > > SPONSORED LINKS Electronic instrument Emax Synthesizer music > Electronic music Music sampler Electronic musical instrument > > > -------------------------------------------------------------------- ---------- > YAHOO! GROUPS LINKS > > a.. Visit your group "emax" on the web. > > b.. To unsubscribe from this group, send an email to: > emax-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > -------------------------------------------------------------------- ----------
