Emax
Triggering Drum Samples from an Alesis HR-16 on an Emax 1?
2006-09-09 by peter_vh01
Hey guys,
I am trying to set up my Emax so that when I press a pad on my Alesis
HR-16, I hear a drum tone from the Emax. Currently, I am hearing just
a very short portion of the drum sample. I had the sum trouble with my
Ensoniq EPS, and was able to remedy this using a special 'percussion'
envelope setting.
I assume that a similar solution is available on the Emax 1, but I am
not too familiar with the unit. Could someone please describe the
process which I would have to go through to make this happen?
Thanks!
- Peter
Re: [emax] Triggering Drum Samples from an Alesis HR-16 on an Emax 1?
2006-09-09 by Roger Schumann
Drum - to - MIDI triggers are working in that way, that you don´t have a MIDI Note-off, this means, that you have to make longer the release of your samples VCA inside the Emax to hear the full sound.
As I am user of the Emax2 with plenty experience of Drum triggers, I think, it´s just like this.
Try this VCA settings:
A        0
H        0
D        32
S        0
R        22
or if necessary, the release longer.
Hope that helps. Let me know how it works.
Roger
www.fo-co.com
  To: emax@yahoogroups.com
  Sent: Saturday, September 09, 2006 7:30 AM
  Subject: [emax] Triggering Drum Samples from an Alesis HR-16 on an Emax 1?
  Hey guys,
  envelope setting.
  Thanks!
  - Peter
