Emax
looking for emax HD SE O.S disc
2006-08-15 by rob salazar
Im looking to see if any has an emax HD SE O.S disc to send me
-I will pay for shipping and other cost
I have a non-working ( needs OS disk) HD SE model and also would
idealy like to modify to
a plus version to be able to connect to an iomega ZIP drive.
sorry,I cant figure out emx .. it hurts my head.
thx
rob
Re: [emax] looking for emax HD SE O.S disc
2006-08-15 by jarek lis
Hello Rob,
  Are you after the blank operating disc that you need to get the thing going?
  If so, let me know.
  I'm in Australia, so if you are not, and don't hear back from someone closer let me know.
  Cheers, Jarek.
thx
rob
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls.  Great rates starting at 1ยข/min.
Re: looking for emax HD SE O.S disc
2006-08-15 by esynthesist
Hi Rob, did you try the other options besides EMX ?
1/ EMXP (Windows XP)for which you have to install the EMXP EMAX
floppy driver first (included). See files section for download. Note
that not all disks formatted by the current beta-version of EMXP are
bootable from EMAX samplers. The same is true for EMX.
2/ CopyQM (native MS DOS required, don't use a Windows DOS box) for
which a zip package exists including the Plus OS, see files section.
The PLUS OS should work fine on your HD SE. Using CopyQM almost
guarantees a perfect working bootable disk, but CopyQM is a strange
program to use :-)
3/ OmniFlop (Windows XP). You can download OmniFlop from the
http://www.shlock.co.uk/Utils/OmniFlop/OmniFlop.htm website, and
format a disk using the format option in it. Just choose Emu EMAX as
a target layout, register the application (when OmniFlop tells you
to) and format the disk. Then use EMX (under native MS DOS) to put
the OS on the disk. Why using Omniflop instead of EMX/EMXP ? Because
there's a bigger chance that the disk will be bootable on EMAX
samplers.
I was going to publish the new version of EMXP today, which
definitely can make your disk, but I discovered a small problem in
the program after two days of intensive testing so I will put the
release on hold for a few more days and remove the problem first.
///E-Synthesist
> thx
> rob
Re: [emax] Re: looking for emax HD SE O.S disc
2006-08-15 by elmacaco
yo Kris,
sorry, my pc took a shit and I had to reinstall xp and everything else, what were the other things you wanted me to test?
I'm having sketchy access to email.
sorry about that,
Ed
  To: emax@yahoogroups.com
  Sent: Tuesday, August 15, 2006 5:52 PM
  Subject: [emax] Re: looking for emax HD SE O.S disc
  program to use :-)
  samplers.
  ///E-Synthesist
  > thx
  > rob
2006-08-16 by esynthesist
Ed... No problem... I've put my EMAX-I zip stuff on hold a few weeks
ago because I wanted to finish version 1.92 of EMXP. Which will be
released at the end of this week. It looks stable now, e.g. no lost
data on ZIP disks anymore, quite stable EMAX-1 <--> EMAX-2 <--> WAV
conversion features and 100% support for the more reliable OmniFlop
floppy driver. But v1.92 will still only support ZIP disks for EMAX-
II, not EMAX-I...
I've sent you a small testprogram a few weeks ago that should be able
to select banks from your EMAX-HD zip disk and convert them to EMX
files on your PC harddisk.
Next week I will make a similar testprogram that can write EMX files
to your EMAX-HD/PLUS zip disk.
I will not post these small testprograms to the group because they're
really for die-hard test purposes only. Sorry about that.
Final version of EMXP, including ZIP support for EMAX-HD/Plus will be
released in september/october. Small chance that it will also have an
AKAI S3000 import/export feature, but that's really a SMALL chance.
After that release I will end my EMAX programming (and support)
efforts, because I really have other things to do in my life :-)
Let me know when your e-mail works again.
///E-Synthesist
--- In emax@yahoogroups.com, "elmacaco" <elmacaco@...> wrote:
> yo Kris,
> sorry about that,
> Ed
>   ----- Original Message -----
>   From: esynthesist
Note
are
for
section.
strange
>   program to use :-)
as
you
put
Because
>   samplers.
in
>   Regards
>   ///E-Synthesist
>   > thx
>   > rob
