Emax
Sound Designer and Alchemy for Emax SE / Apple Powerbook 3, OS X
Re: [emax] Sound Designer and Alchemy for Emax SE / Apple Powerbook 3, OS X
2007-02-17 by cruising@...
Hello Josef,
They won't run under osX..neither Os9...they are too recent.
You have to get and old mac with an OS 7.5 (don't remember with os8??)
Let us know if you happend to run one of these softs.
Cruising
Le 16 févr. 07 à 11:12, josbru57 a écrit :
> Hi,
> can somebody inform me, whether the Passport Alchemy or the Sound
> Designer Editor for the Emax SE does run on a Mac Powerbook 3, Lombard
> with Mac OS X?
> Regards
> Josef
2007-02-17 by jesse misemer
I am using alchemy with my emax hd se plus on a powermac 8600 and on a 9600/They are 604e processors before the g3's.With a drive I have os 7.5 on, works like a champ to look at samples and send to emax.You can use your favorite sound editor and send them to the emax via rs422. It's a mini fairlight?
Jesse
Never Miss an Email
Stay connected with Yahoo! Mail on your mobile. Get started!
2007-02-17 by ted Summers
I had used the Alchemy on a Beige G3 and it seemed to work on on OS
8.1.... of course- it wasnt the cracked version, it was original.
That may make a difference...
Ted
> Jesse
> Never Miss an Email
2007-02-18 by cruising@...
Hello,
There is a point I don't remember : was it necessary to have a midi
connexion in parallel of the Rs 422 ?
Or was the Rs 422 working alone ?
Tia
Cruising
2007-02-18 by ted Summers
One or the other, the emax can't use both at the same time, if I
remember correctly....
Ted
On Feb 18, 2007, at 12:26 AM, cruising@... wrote:
> Hello,
> Tia
> Cruising
2007-02-19 by cruising@...
Hello Ted,
Thanks for your answer,
Is the Rs 422 cable Wiring the same as for the Emax II ? (It's so
old...)
Thanks
Thierry
> Ted
> > Hello,
> > Tia
> > Cruising
2007-02-19 by ted Summers
The cable should be the same. I don't have an Emax II, but it is an
RS422 (mac port) to RS232 (Emax / pc) style port. So that shouldn't
change from one model to another....
Ted
On Feb 19, 2007, at 3:08 AM, cruising@... wrote:
> Hello Ted,
> old...)
> Thanks
> Thierry
> > Ted
> > On Feb 18, 2007, at 12:26 AM, cruising@free.fr wrote:
> > > Hello,
> midi
> > > Tia
> > > Cruising
> and
> drive I
> send to
