Emax II - boot from Zip...?
2007-03-18 by b_j_glover
Hi - I've got an Emax II (2212) which I haven't been able to boot up - I've tried creating boot floppies, but they've never worked, and I think the drive might need replacing. But I've got a 100MB SCSI Zip drive, and I was wondering if there might be any way to create a bootable image on that via a PC...?
2007-03-18 by esynthesist
Yes there is. You can create an EMAX-II ZIP disk image with EMXP v2.02. (using the "manage Emax HD/CD images"->"create new image" menu). After the 96 MB image-file has been created by EMXP, you can add an Emax-II OS to it (again with EMXP v2.02). OS files can be downloaded in this group or from the emulatorarchive website. Then you have to copy the image to a ZIP disk (connected to your PC). Again use EMXP for this :-) (via "restore" function) One important note though ! The ZIP disk must have been formatted first in an "emax-compatible" way. You don't need an EMAX to do that, but unfortunately my experience shows that simply formatting a ZIP disk on a Windows machine does not guarantee an EMAX-compatible ZIP disk. I always format them first on an old Mac Classic. This format procedure seems to be compatible with Emax... ///E-Synthesist --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@...> wrote: > > Hi - > > I've got an Emax II (2212) which I haven't been able to boot up - I've > tried creating boot floppies, but they've never worked, and I think the > drive might need replacing. But I've got a 100MB SCSI Zip drive, and I
> was wondering if there might be any way to create a bootable image on > that via a PC...? >
Hi - Thanks for the quick reply - that's an excellent utility. Unfortunately the Emax II seems to want to read its OS from the floppy unless you change the SCSI Boot ID to something else. The manual says: "This function allows you to select which SCSI drive (0=floppy, 1- 7=HD) Emax II will scan on initial power up for its operating software. Note: Emax II will always boot from floppy if a formatted floppy disk resides in the drive on power up" My external ZIP drive only allows the 5/6 ID setting. I also tried booting up from a prepared internal SCSI drive set to ID 0, and using the trick of putting a jumper on pins 25/26 of the floppy connector to avert the system check, but it hangs on "Pease Insert Disk". I don't know whether that's because the drive doesn't spin up in time, or whether the thing is canny enough to know it's been hoodwinked. Bleugh - after pulling apart my PC, my Emax and my Kurzweil to get this far, I think I'm going to have to surrender to Route 66...;) But once I get it working, I'll definitely be making more use of the wondrous EMXP... specify otherwise --- In emax@yahoogroups.com, "esynthesist" <esynthesist@...> wrote: > > Yes there is. > > You can create an EMAX-II ZIP disk image with EMXP v2.02. > (using the "manage Emax HD/CD images"->"create new image" menu). After > the 96 MB image-file has been created by EMXP, you can add an Emax- II > OS to it (again with EMXP v2.02). OS files can be downloaded in this > group or from the emulatorarchive website. > > Then you have to copy the image to a ZIP disk (connected to your PC). > Again use EMXP for this :-) (via "restore" function) > > One important note though ! > The ZIP disk must have been formatted first in an "emax-compatible" way. > You don't need an EMAX to do that, but unfortunately my experience > shows that simply formatting a ZIP disk on a Windows machine does not > guarantee an EMAX-compatible ZIP disk. > I always format them first on an old Mac Classic. This format procedure > seems to be compatible with Emax... > > ///E-Synthesist > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > Hi - > > > > I've got an Emax II (2212) which I haven't been able to boot up - > I've > > tried creating boot floppies, but they've never worked, and I think > the > > drive might need replacing. But I've got a 100MB SCSI Zip drive, and > I > > was wondering if there might be any way to create a bootable image on
> > that via a PC...? > > >
That's strange ! I have an EMAX-II rack without any internal HD. The only two disk devices connected to this EMAX-II are: - the internal floppy drive - an external 100 MB ZIP drive with ID = 6 and terminator = ON. (the Boot SCSI ID in the Master Module is set to 4 however) When I boot the EMAX-II without any floppy disk in the drive, but with an EMAX-II formatted ZIP disk with OS in the ZIP drive, it boots from that ZIP disk ! The EMAX-II always scans the complete SCSI chain if it doesn't find an OS on the floppy disk or on the "default SCSI device" set by the SCSI ID you mentioned in the Master module. This Master setting does not mean that the OS can only be loaded from that device. The Master SCSI ID must be set if your EMAX-II has multiple HD's (or ZIP disks) each carrying its own OS. In that case, you have to tell the EMAX-II which OS device is the preferred one/should be used. It indicates the first HD which will be checked by the EMAX-II. If no OS resides on that HD, EMAX-II will start the SCSI chain search. So normally you should not have any problem with booting from an external ZIP drive. (on EMAX-I however, the ZIP drive MUST have SCSI ID = 0) Regards ///E-Synthesist --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@...> wrote: > > Hi - > > Thanks for the quick reply - that's an excellent utility. > > Unfortunately the Emax II seems to want to read its OS from the > floppy unless you change the SCSI Boot ID to something else. The > manual says: > > "This function allows you to select which SCSI drive (0=floppy, 1- > 7=HD) Emax II will scan on initial power up for its operating > software. Note: Emax II will always boot from floppy if a formatted > floppy disk resides in the drive on power up" > > My external ZIP drive only allows the 5/6 ID setting. I also tried > booting up from a prepared internal SCSI drive set to ID 0, and using > the trick of putting a jumper on pins 25/26 of the floppy connector > to avert the system check, but it hangs on "Pease Insert Disk". I > don't know whether that's because the drive doesn't spin up in time, > or whether the thing is canny enough to know it's been hoodwinked. > > Bleugh - after pulling apart my PC, my Emax and my Kurzweil to get > this far, I think I'm going to have to surrender to Route 66...;) But > once I get it working, I'll definitely be making more use of the > wondrous EMXP... > > specify otherwise --- In emax@yahoogroups.com, "esynthesist" > <esynthesist@> wrote: > > > > Yes there is. > > > > You can create an EMAX-II ZIP disk image with EMXP v2.02. > > (using the "manage Emax HD/CD images"->"create new image" menu). > After > > the 96 MB image-file has been created by EMXP, you can add an Emax- > II > > OS to it (again with EMXP v2.02). OS files can be downloaded in > this > > group or from the emulatorarchive website. > > > > Then you have to copy the image to a ZIP disk (connected to your > PC). > > Again use EMXP for this :-) (via "restore" function) > > > > One important note though ! > > The ZIP disk must have been formatted first in an "emax- compatible" > way. > > You don't need an EMAX to do that, but unfortunately my experience > > shows that simply formatting a ZIP disk on a Windows machine does > not > > guarantee an EMAX-compatible ZIP disk. > > I always format them first on an old Mac Classic. This format > procedure > > seems to be compatible with Emax... > > > > ///E-Synthesist > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > > > Hi - > > > > > > I've got an Emax II (2212) which I haven't been able to boot up - > > I've > > > tried creating boot floppies, but they've never worked, and I > think > > the > > > drive might need replacing. But I've got a 100MB SCSI Zip drive,
> and > > I > > > was wondering if there might be any way to create a bootable > image on > > > that via a PC...? > > > > > >
Thanks for the extra info. When I was trying the ZIP method, I was using a PC formatted (250MB) disk, though you warned this might not work. However, the "Restore" function in EMXP seemed to operate correctly. But is the fact that Restore can be used to put an image on the disk enough to guarantee that the disk is in an acceptable format to the Emax...? > That's strange ! > > I have an EMAX-II rack without any internal HD. > The only two disk devices connected to this EMAX-II are: > - the internal floppy drive > - an external 100 MB ZIP drive with ID = 6 and terminator = ON. > (the Boot SCSI ID in the Master Module is set to 4 however) > > When I boot the EMAX-II without any floppy disk in the drive, but > with an EMAX-II formatted ZIP disk with OS in the ZIP drive, it boots > from that ZIP disk ! > > The EMAX-II always scans the complete SCSI chain if it doesn't find > an OS on the floppy disk or on the "default SCSI device" set by the > SCSI ID you mentioned in the Master module. > This Master setting does not mean that the OS can only be loaded from > that device. The Master SCSI ID must be set if your EMAX-II has > multiple HD's (or ZIP disks) each carrying its own OS. In that case, > you have to tell the EMAX-II which OS device is the preferred > one/should be used. It indicates the first HD which will be checked > by the EMAX-II. If no OS resides on that HD, EMAX-II will start the > SCSI chain search. > > So normally you should not have any problem with booting from an > external ZIP drive. > (on EMAX-I however, the ZIP drive MUST have SCSI ID = 0) > > Regards > > ///E-Synthesist > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > Hi - > > > > Thanks for the quick reply - that's an excellent utility. > > > > Unfortunately the Emax II seems to want to read its OS from the > > floppy unless you change the SCSI Boot ID to something else. The > > manual says: > > > > "This function allows you to select which SCSI drive (0=floppy, 1- > > 7=HD) Emax II will scan on initial power up for its operating > > software. Note: Emax II will always boot from floppy if a formatted > > floppy disk resides in the drive on power up" > > > > My external ZIP drive only allows the 5/6 ID setting. I also tried > > booting up from a prepared internal SCSI drive set to ID 0, and > using > > the trick of putting a jumper on pins 25/26 of the floppy connector > > to avert the system check, but it hangs on "Pease Insert Disk". I > > don't know whether that's because the drive doesn't spin up in > time, > > or whether the thing is canny enough to know it's been hoodwinked. > > > > Bleugh - after pulling apart my PC, my Emax and my Kurzweil to get > > this far, I think I'm going to have to surrender to Route 66...;) > But > > once I get it working, I'll definitely be making more use of the > > wondrous EMXP... > > > > specify otherwise --- In emax@yahoogroups.com, "esynthesist" > > <esynthesist@> wrote: > > > > > > Yes there is. > > > > > > You can create an EMAX-II ZIP disk image with EMXP v2.02. > > > (using the "manage Emax HD/CD images"->"create new image" menu). > > After > > > the 96 MB image-file has been created by EMXP, you can add an > Emax- > > II > > > OS to it (again with EMXP v2.02). OS files can be downloaded in > > this > > > group or from the emulatorarchive website. > > > > > > Then you have to copy the image to a ZIP disk (connected to your > > PC). > > > Again use EMXP for this :-) (via "restore" function) > > > > > > One important note though ! > > > The ZIP disk must have been formatted first in an "emax- > compatible" > > way. > > > You don't need an EMAX to do that, but unfortunately my > experience > > > shows that simply formatting a ZIP disk on a Windows machine does
> > not > > > guarantee an EMAX-compatible ZIP disk. > > > I always format them first on an old Mac Classic. This format > > procedure > > > seems to be compatible with Emax... > > > > > > ///E-Synthesist > > > > > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > > > > > Hi - > > > > > > > > I've got an Emax II (2212) which I haven't been able to boot > up - > > > I've > > > > tried creating boot floppies, but they've never worked, and I > > think > > > the > > > > drive might need replacing. But I've got a 100MB SCSI Zip > drive, > > and > > > I > > > > was wondering if there might be any way to create a bootable > > image on > > > > that via a PC...? > > > > > > > > > >
No, the restore function always works. Windows formatted ZIP disks are almost the same as Emax/MAC formatted ZIP disks. But Emax/Mac machines format a few more sectors on the disk, and unfortunately Emax seems to check the existence of these additional sectors. If it can't find them, it gives an error message "Not an EMAX-II disk" or something like that. I haven't found a way yet to format ZIP disks with those additonal sectors under Windows XP. I think it's possible with parallel versions and old Iomega drivers, but most of us use USB drives of course. Anyway, that's the reason why there's no "format ZIP" function in EMXP... So I hope you have access to a Mac computer somewhere ? (or pre-formatted ZIP-disks for MAC, those exist too !) ///E-Synthesist --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@...> wrote: > > Thanks for the extra info. When I was trying the ZIP method, I was > using a PC formatted (250MB) disk, though you warned this might not > work. However, the "Restore" function in EMXP seemed to operate > correctly. But is the fact that Restore can be used to put an image > on the disk enough to guarantee that the disk is in an acceptable > format to the Emax...? > > > That's strange ! > > > > I have an EMAX-II rack without any internal HD. > > The only two disk devices connected to this EMAX-II are: > > - the internal floppy drive > > - an external 100 MB ZIP drive with ID = 6 and terminator = ON. > > (the Boot SCSI ID in the Master Module is set to 4 however) > > > > When I boot the EMAX-II without any floppy disk in the drive, but > > with an EMAX-II formatted ZIP disk with OS in the ZIP drive, it > boots > > from that ZIP disk ! > > > > The EMAX-II always scans the complete SCSI chain if it doesn't find > > an OS on the floppy disk or on the "default SCSI device" set by the > > SCSI ID you mentioned in the Master module. > > This Master setting does not mean that the OS can only be loaded > from > > that device. The Master SCSI ID must be set if your EMAX-II has > > multiple HD's (or ZIP disks) each carrying its own OS. In that > case, > > you have to tell the EMAX-II which OS device is the preferred > > one/should be used. It indicates the first HD which will be checked > > by the EMAX-II. If no OS resides on that HD, EMAX-II will start the > > SCSI chain search. > > > > So normally you should not have any problem with booting from an > > external ZIP drive. > > (on EMAX-I however, the ZIP drive MUST have SCSI ID = 0) > > > > Regards > > > > ///E-Synthesist > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > > > Hi - > > > > > > Thanks for the quick reply - that's an excellent utility. > > > > > > Unfortunately the Emax II seems to want to read its OS from the > > > floppy unless you change the SCSI Boot ID to something else. The > > > manual says: > > > > > > "This function allows you to select which SCSI drive (0=floppy, 1- > > > 7=HD) Emax II will scan on initial power up for its operating > > > software. Note: Emax II will always boot from floppy if a > formatted > > > floppy disk resides in the drive on power up" > > > > > > My external ZIP drive only allows the 5/6 ID setting. I also > tried > > > booting up from a prepared internal SCSI drive set to ID 0, and > > using > > > the trick of putting a jumper on pins 25/26 of the floppy > connector > > > to avert the system check, but it hangs on "Pease Insert Disk". I > > > don't know whether that's because the drive doesn't spin up in > > time, > > > or whether the thing is canny enough to know it's been hoodwinked. > > > > > > Bleugh - after pulling apart my PC, my Emax and my Kurzweil to > get > > > this far, I think I'm going to have to surrender to Route 66...;) > > But > > > once I get it working, I'll definitely be making more use of the > > > wondrous EMXP... > > > > > > specify otherwise --- In emax@yahoogroups.com, "esynthesist" > > > <esynthesist@> wrote: > > > > > > > > Yes there is. > > > > > > > > You can create an EMAX-II ZIP disk image with EMXP v2.02. > > > > (using the "manage Emax HD/CD images"->"create new image" > menu). > > > After > > > > the 96 MB image-file has been created by EMXP, you can add an > > Emax- > > > II > > > > OS to it (again with EMXP v2.02). OS files can be downloaded in > > > this > > > > group or from the emulatorarchive website. > > > > > > > > Then you have to copy the image to a ZIP disk (connected to > your > > > PC). > > > > Again use EMXP for this :-) (via "restore" function) > > > > > > > > One important note though ! > > > > The ZIP disk must have been formatted first in an "emax- > > compatible" > > > way. > > > > You don't need an EMAX to do that, but unfortunately my > > experience > > > > shows that simply formatting a ZIP disk on a Windows machine > does > > > not > > > > guarantee an EMAX-compatible ZIP disk. > > > > I always format them first on an old Mac Classic. This format > > > procedure > > > > seems to be compatible with Emax... > > > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > > > > > > > Hi - > > > > > > > > > > I've got an Emax II (2212) which I haven't been able to boot > > up - > > > > I've > > > > > tried creating boot floppies, but they've never worked, and I > > > think > > > > the > > > > > drive might need replacing. But I've got a 100MB SCSI Zip > > drive, > > > and > > > > I > > > > > was wondering if there might be any way to create a bootable
> > > image on > > > > > that via a PC...? > > > > > > > > > > > > > > >
2007-03-19 by esynthesist
Just FYI: I managed to format a ZIP disk on a Windows XP machine in such way that the disk is readable and bootable by an Emax. I'll just explain exactly what I did: 1/ I formatted the disk using a free demo-version of MacDisk (for WinXP). I used the HFS (not HFS+) format option. --> This disk is not usable on an Emax yet, but at least the original MS-DOS format structure is "killed" :-) 2/ Then I re-formatted the very same disk using the IomegaWare format function (I have IomegaWare running on my PC, this package adds some functions to the Windows Explorer menu, of which also Iomega Format). I used the short format (30 seconds) procedure. --> This format resulted in an error... 3/ Immediately after this Iomega Format I re-formatted the very same disk again, this time simply with the standard Format Disk function in Windows Explorer. I used the "long" format option. The format capacity I selected was 96 MB (the only possible one). Then I copied an EMAX-II HD image to that ZIP disk with EMXP. --> This disk can be read and booted on my EMAX-II ! Maybe step 2 can be skipped, I don't know because I don't have any non-EMAX zip disks left so I can't do another test anymore. Anyway, whatever format tools you try, it is extremely important that you are able to format the disk with a 96 MB capacity. So not the 95.7 MB which is the default capacity suggested by Windows Explorer... So it seems possible to create an EMAX-II ZIP disk from scratch without any need for a Mac computer or EMAX-II sampler ! Have fun, ///E-Synthesist --- In emax@yahoogroups.com, "esynthesist" <esynthesist@...> wrote: > > No, the restore function always works. > Windows formatted ZIP disks are almost the same as Emax/MAC formatted > ZIP disks. But Emax/Mac machines format a few more sectors on the > disk, and unfortunately Emax seems to check the existence of these > additional sectors. If it can't find them, it gives an error > message "Not an EMAX-II disk" or something like that. > > I haven't found a way yet to format ZIP disks with those additonal > sectors under Windows XP. I think it's possible with parallel > versions and old Iomega drivers, but most of us use USB drives of > course. > Anyway, that's the reason why there's no "format ZIP" function in > EMXP... > > So I hope you have access to a Mac computer somewhere ? > (or pre-formatted ZIP-disks for MAC, those exist too !) > > ///E-Synthesist > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > Thanks for the extra info. When I was trying the ZIP method, I was > > using a PC formatted (250MB) disk, though you warned this might not > > work. However, the "Restore" function in EMXP seemed to operate > > correctly. But is the fact that Restore can be used to put an image > > on the disk enough to guarantee that the disk is in an acceptable > > format to the Emax...? > > > > > That's strange ! > > > > > > I have an EMAX-II rack without any internal HD. > > > The only two disk devices connected to this EMAX-II are: > > > - the internal floppy drive > > > - an external 100 MB ZIP drive with ID = 6 and terminator = ON. > > > (the Boot SCSI ID in the Master Module is set to 4 however) > > > > > > When I boot the EMAX-II without any floppy disk in the drive, but > > > with an EMAX-II formatted ZIP disk with OS in the ZIP drive, it > > boots > > > from that ZIP disk ! > > > > > > The EMAX-II always scans the complete SCSI chain if it doesn't > find > > > an OS on the floppy disk or on the "default SCSI device" set by > the > > > SCSI ID you mentioned in the Master module. > > > This Master setting does not mean that the OS can only be loaded > > from > > > that device. The Master SCSI ID must be set if your EMAX-II has > > > multiple HD's (or ZIP disks) each carrying its own OS. In that > > case, > > > you have to tell the EMAX-II which OS device is the preferred > > > one/should be used. It indicates the first HD which will be > checked > > > by the EMAX-II. If no OS resides on that HD, EMAX-II will start > the > > > SCSI chain search. > > > > > > So normally you should not have any problem with booting from an > > > external ZIP drive. > > > (on EMAX-I however, the ZIP drive MUST have SCSI ID = 0) > > > > > > Regards > > > > > > ///E-Synthesist > > > > > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > > > > > Hi - > > > > > > > > Thanks for the quick reply - that's an excellent utility. > > > > > > > > Unfortunately the Emax II seems to want to read its OS from the > > > > floppy unless you change the SCSI Boot ID to something else. > The > > > > manual says: > > > > > > > > "This function allows you to select which SCSI drive (0=floppy, > 1- > > > > 7=HD) Emax II will scan on initial power up for its operating > > > > software. Note: Emax II will always boot from floppy if a > > formatted > > > > floppy disk resides in the drive on power up" > > > > > > > > My external ZIP drive only allows the 5/6 ID setting. I also > > tried > > > > booting up from a prepared internal SCSI drive set to ID 0, and > > > using > > > > the trick of putting a jumper on pins 25/26 of the floppy > > connector > > > > to avert the system check, but it hangs on "Pease Insert Disk". > I > > > > don't know whether that's because the drive doesn't spin up in > > > time, > > > > or whether the thing is canny enough to know it's been > hoodwinked. > > > > > > > > Bleugh - after pulling apart my PC, my Emax and my Kurzweil to > > get > > > > this far, I think I'm going to have to surrender to Route > 66...;) > > > But > > > > once I get it working, I'll definitely be making more use of > the > > > > wondrous EMXP... > > > > > > > > specify otherwise --- In emax@yahoogroups.com, "esynthesist" > > > > <esynthesist@> wrote: > > > > > > > > > > Yes there is. > > > > > > > > > > You can create an EMAX-II ZIP disk image with EMXP v2.02. > > > > > (using the "manage Emax HD/CD images"->"create new image" > > menu). > > > > After > > > > > the 96 MB image-file has been created by EMXP, you can add an > > > Emax- > > > > II > > > > > OS to it (again with EMXP v2.02). OS files can be downloaded > in > > > > this > > > > > group or from the emulatorarchive website. > > > > > > > > > > Then you have to copy the image to a ZIP disk (connected to > > your > > > > PC). > > > > > Again use EMXP for this :-) (via "restore" function) > > > > > > > > > > One important note though ! > > > > > The ZIP disk must have been formatted first in an "emax- > > > compatible" > > > > way. > > > > > You don't need an EMAX to do that, but unfortunately my > > > experience > > > > > shows that simply formatting a ZIP disk on a Windows machine > > does > > > > not > > > > > guarantee an EMAX-compatible ZIP disk. > > > > > I always format them first on an old Mac Classic. This format > > > > procedure > > > > > seems to be compatible with Emax... > > > > > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > > > > > > > > > Hi - > > > > > > > > > > > > I've got an Emax II (2212) which I haven't been able to > boot > > > up - > > > > > I've > > > > > > tried creating boot floppies, but they've never worked, and
> I > > > > think > > > > > the > > > > > > drive might need replacing. But I've got a 100MB SCSI Zip > > > drive, > > > > and > > > > > I > > > > > > was wondering if there might be any way to create a > bootable > > > > image on > > > > > > that via a PC...? > > > > > > > > > > > > > > > > > > > > >
2007-03-19 by b_j_glover
Nice work...;) I was fiddling around trying something similar with a free demo of MacDrive, but it got my PC into a horrible state - I wouldn't recommend letting this software anywhere near your computer. I'll have another crack at it with this approach. ) --- In emax@yahoogroups.com, "esynthesist" <esynthesist@...> wrote: > > Just FYI: I managed to format a ZIP disk on a Windows XP machine in > such way that the disk is readable and bootable by an Emax. > > I'll just explain exactly what I did: > > 1/ I formatted the disk using a free demo-version of MacDisk (for > WinXP). I used the HFS (not HFS+) format option. > > --> This disk is not usable on an Emax yet, but at least the original > MS-DOS format structure is "killed" :-) > > 2/ Then I re-formatted the very same disk using the IomegaWare format > function (I have IomegaWare running on my PC, this package adds some > functions to the Windows Explorer menu, of which also Iomega Format). > I used the short format (30 seconds) procedure. > > --> This format resulted in an error... > > 3/ Immediately after this Iomega Format I re-formatted the very same > disk again, this time simply with the standard Format Disk function > in Windows Explorer. I used the "long" format option. The format > capacity I selected was 96 MB (the only possible one). > > Then I copied an EMAX-II HD image to that ZIP disk with EMXP. > > --> This disk can be read and booted on my EMAX-II ! > > > Maybe step 2 can be skipped, I don't know because I don't have any > non-EMAX zip disks left so I can't do another test anymore. > > Anyway, whatever format tools you try, it is extremely important that > you are able to format the disk with a 96 MB capacity. So not the > 95.7 MB which is the default capacity suggested by Windows Explorer... > > So it seems possible to create an EMAX-II ZIP disk from scratch > without any need for a Mac computer or EMAX-II sampler ! > > > Have fun, > > ///E-Synthesist > > > > > --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote: > > > > No, the restore function always works. > > Windows formatted ZIP disks are almost the same as Emax/MAC > formatted > > ZIP disks. But Emax/Mac machines format a few more sectors on the > > disk, and unfortunately Emax seems to check the existence of these > > additional sectors. If it can't find them, it gives an error > > message "Not an EMAX-II disk" or something like that. > > > > I haven't found a way yet to format ZIP disks with those additonal > > sectors under Windows XP. I think it's possible with parallel > > versions and old Iomega drivers, but most of us use USB drives of > > course. > > Anyway, that's the reason why there's no "format ZIP" function in > > EMXP... > > > > So I hope you have access to a Mac computer somewhere ? > > (or pre-formatted ZIP-disks for MAC, those exist too !) > > > > ///E-Synthesist > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > > > Thanks for the extra info. When I was trying the ZIP method, I > was > > > using a PC formatted (250MB) disk, though you warned this might > not > > > work. However, the "Restore" function in EMXP seemed to operate > > > correctly. But is the fact that Restore can be used to put an > image > > > on the disk enough to guarantee that the disk is in an acceptable > > > format to the Emax...? > > > > > > > That's strange ! > > > > > > > > I have an EMAX-II rack without any internal HD. > > > > The only two disk devices connected to this EMAX-II are: > > > > - the internal floppy drive > > > > - an external 100 MB ZIP drive with ID = 6 and terminator = ON. > > > > (the Boot SCSI ID in the Master Module is set to 4 however) > > > > > > > > When I boot the EMAX-II without any floppy disk in the drive, > but > > > > with an EMAX-II formatted ZIP disk with OS in the ZIP drive, it > > > boots > > > > from that ZIP disk ! > > > > > > > > The EMAX-II always scans the complete SCSI chain if it doesn't > > find > > > > an OS on the floppy disk or on the "default SCSI device" set by > > the > > > > SCSI ID you mentioned in the Master module. > > > > This Master setting does not mean that the OS can only be > loaded > > > from > > > > that device. The Master SCSI ID must be set if your EMAX-II has > > > > multiple HD's (or ZIP disks) each carrying its own OS. In that > > > case, > > > > you have to tell the EMAX-II which OS device is the preferred > > > > one/should be used. It indicates the first HD which will be > > checked > > > > by the EMAX-II. If no OS resides on that HD, EMAX-II will start > > the > > > > SCSI chain search. > > > > > > > > So normally you should not have any problem with booting from > an > > > > external ZIP drive. > > > > (on EMAX-I however, the ZIP drive MUST have SCSI ID = 0) > > > > > > > > Regards > > > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > > > > > > > Hi - > > > > > > > > > > Thanks for the quick reply - that's an excellent utility. > > > > > > > > > > Unfortunately the Emax II seems to want to read its OS from > the > > > > > floppy unless you change the SCSI Boot ID to something else. > > The > > > > > manual says: > > > > > > > > > > "This function allows you to select which SCSI drive > (0=floppy, > > 1- > > > > > 7=HD) Emax II will scan on initial power up for its operating > > > > > software. Note: Emax II will always boot from floppy if a > > > formatted > > > > > floppy disk resides in the drive on power up" > > > > > > > > > > My external ZIP drive only allows the 5/6 ID setting. I also > > > tried > > > > > booting up from a prepared internal SCSI drive set to ID 0, > and > > > > using > > > > > the trick of putting a jumper on pins 25/26 of the floppy > > > connector > > > > > to avert the system check, but it hangs on "Pease Insert > Disk". > > I > > > > > don't know whether that's because the drive doesn't spin up > in > > > > time, > > > > > or whether the thing is canny enough to know it's been > > hoodwinked. > > > > > > > > > > Bleugh - after pulling apart my PC, my Emax and my Kurzweil > to > > > get > > > > > this far, I think I'm going to have to surrender to Route > > 66...;) > > > > But > > > > > once I get it working, I'll definitely be making more use of > > the > > > > > wondrous EMXP... > > > > > > > > > > specify otherwise --- In emax@yahoogroups.com, "esynthesist" > > > > > <esynthesist@> wrote: > > > > > > > > > > > > Yes there is. > > > > > > > > > > > > You can create an EMAX-II ZIP disk image with EMXP v2.02. > > > > > > (using the "manage Emax HD/CD images"->"create new image" > > > menu). > > > > > After > > > > > > the 96 MB image-file has been created by EMXP, you can add > an > > > > Emax- > > > > > II > > > > > > OS to it (again with EMXP v2.02). OS files can be > downloaded > > in > > > > > this > > > > > > group or from the emulatorarchive website. > > > > > > > > > > > > Then you have to copy the image to a ZIP disk (connected to > > > your > > > > > PC). > > > > > > Again use EMXP for this :-) (via "restore" function) > > > > > > > > > > > > One important note though ! > > > > > > The ZIP disk must have been formatted first in an "emax- > > > > compatible" > > > > > way. > > > > > > You don't need an EMAX to do that, but unfortunately my > > > > experience > > > > > > shows that simply formatting a ZIP disk on a Windows > machine > > > does > > > > > not > > > > > > guarantee an EMAX-compatible ZIP disk. > > > > > > I always format them first on an old Mac Classic. This > format > > > > > procedure > > > > > > seems to be compatible with Emax... > > > > > > > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@...m, "b_j_glover" <b_j_glover@> > wrote: > > > > > > > > > > > > > > Hi - > > > > > > > > > > > > > > I've got an Emax II (2212) which I haven't been able to > > boot > > > > up - > > > > > > I've > > > > > > > tried creating boot floppies, but they've never worked, > and > > I > > > > > think > > > > > > the > > > > > > > drive might need replacing. But I've got a 100MB SCSI Zip
> > > > drive, > > > > > and > > > > > > I > > > > > > > was wondering if there might be any way to create a > > bootable > > > > > image on > > > > > > > that via a PC...? > > > > > > > > > > > > > > > > > > > > > > > > > > > >
2007-03-20 by b_j_glover
...an additional point of confusion I'm finding with this is that I can't see any indication of ZIP drive activity on boot, so I'm not sure that the Emax is looking at these disks that I'm carefully crafting for it. I don't know whether I should be expecting some of those snapping and shuffling noises I get when using it with a PC. When I tried connecting a CD drive and booting the Emax, there was no evidence of spin-up on that either. Perhaps you could confirm whether you would expect more signs of life, even with a non-bootable Zip disk (I don't know how quiet the process should be, but this is silent), and whether your Emax II still scans the SCSI chain with the SCSI boot ID set to 0...? Thanks! --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@...> wrote: > > Nice work...;) I was fiddling around trying something similar with a > free demo of MacDrive, but it got my PC into a horrible state - I > wouldn't recommend letting this software anywhere near your > computer. I'll have another crack at it with this approach. > > ) --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote: > > > > Just FYI: I managed to format a ZIP disk on a Windows XP machine > in > > such way that the disk is readable and bootable by an Emax. > > > > I'll just explain exactly what I did: > > > > 1/ I formatted the disk using a free demo-version of MacDisk (for > > WinXP). I used the HFS (not HFS+) format option. > > > > --> This disk is not usable on an Emax yet, but at least the > original > > MS-DOS format structure is "killed" :-) > > > > 2/ Then I re-formatted the very same disk using the IomegaWare > format > > function (I have IomegaWare running on my PC, this package adds > some > > functions to the Windows Explorer menu, of which also Iomega > Format). > > I used the short format (30 seconds) procedure. > > > > --> This format resulted in an error... > > > > 3/ Immediately after this Iomega Format I re-formatted the very > same > > disk again, this time simply with the standard Format Disk > function > > in Windows Explorer. I used the "long" format option. The format > > capacity I selected was 96 MB (the only possible one). > > > > Then I copied an EMAX-II HD image to that ZIP disk with EMXP. > > > > --> This disk can be read and booted on my EMAX-II ! > > > > > > Maybe step 2 can be skipped, I don't know because I don't have any > > non-EMAX zip disks left so I can't do another test anymore. > > > > Anyway, whatever format tools you try, it is extremely important > that > > you are able to format the disk with a 96 MB capacity. So not the > > 95.7 MB which is the default capacity suggested by Windows > Explorer... > > > > So it seems possible to create an EMAX-II ZIP disk from scratch > > without any need for a Mac computer or EMAX-II sampler ! > > > > > > Have fun, > > > > ///E-Synthesist > > > > > > > > > > --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote: > > > > > > No, the restore function always works. > > > Windows formatted ZIP disks are almost the same as Emax/MAC > > formatted > > > ZIP disks. But Emax/Mac machines format a few more sectors on > the > > > disk, and unfortunately Emax seems to check the existence of > these > > > additional sectors. If it can't find them, it gives an error > > > message "Not an EMAX-II disk" or something like that. > > > > > > I haven't found a way yet to format ZIP disks with those > additonal > > > sectors under Windows XP. I think it's possible with parallel > > > versions and old Iomega drivers, but most of us use USB drives > of > > > course. > > > Anyway, that's the reason why there's no "format ZIP" function > in > > > EMXP... > > > > > > So I hope you have access to a Mac computer somewhere ? > > > (or pre-formatted ZIP-disks for MAC, those exist too !) > > > > > > ///E-Synthesist > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > > > > > Thanks for the extra info. When I was trying the ZIP method, I > > was > > > > using a PC formatted (250MB) disk, though you warned this > might > > not > > > > work. However, the "Restore" function in EMXP seemed to > operate > > > > correctly. But is the fact that Restore can be used to put an > > image > > > > on the disk enough to guarantee that the disk is in an > acceptable > > > > format to the Emax...? > > > > > > > > > That's strange ! > > > > > > > > > > I have an EMAX-II rack without any internal HD. > > > > > The only two disk devices connected to this EMAX-II are: > > > > > - the internal floppy drive > > > > > - an external 100 MB ZIP drive with ID = 6 and terminator = > ON. > > > > > (the Boot SCSI ID in the Master Module is set to 4 however) > > > > > > > > > > When I boot the EMAX-II without any floppy disk in the > drive, > > but > > > > > with an EMAX-II formatted ZIP disk with OS in the ZIP drive, > it > > > > boots > > > > > from that ZIP disk ! > > > > > > > > > > The EMAX-II always scans the complete SCSI chain if it > doesn't > > > find > > > > > an OS on the floppy disk or on the "default SCSI device" set > by > > > the > > > > > SCSI ID you mentioned in the Master module. > > > > > This Master setting does not mean that the OS can only be > > loaded > > > > from > > > > > that device. The Master SCSI ID must be set if your EMAX- II > has > > > > > multiple HD's (or ZIP disks) each carrying its own OS. In > that > > > > case, > > > > > you have to tell the EMAX-II which OS device is the > preferred > > > > > one/should be used. It indicates the first HD which will be > > > checked > > > > > by the EMAX-II. If no OS resides on that HD, EMAX-II will > start > > > the > > > > > SCSI chain search. > > > > > > > > > > So normally you should not have any problem with booting > from > > an > > > > > external ZIP drive. > > > > > (on EMAX-I however, the ZIP drive MUST have SCSI ID = 0) > > > > > > > > > > Regards > > > > > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> > wrote: > > > > > > > > > > > > Hi - > > > > > > > > > > > > Thanks for the quick reply - that's an excellent utility. > > > > > > > > > > > > Unfortunately the Emax II seems to want to read its OS > from > > the > > > > > > floppy unless you change the SCSI Boot ID to something > else. > > > The > > > > > > manual says: > > > > > > > > > > > > "This function allows you to select which SCSI drive > > (0=floppy, > > > 1- > > > > > > 7=HD) Emax II will scan on initial power up for its > operating > > > > > > software. Note: Emax II will always boot from floppy if a > > > > formatted > > > > > > floppy disk resides in the drive on power up" > > > > > > > > > > > > My external ZIP drive only allows the 5/6 ID setting. I > also > > > > tried > > > > > > booting up from a prepared internal SCSI drive set to ID > 0, > > and > > > > > using > > > > > > the trick of putting a jumper on pins 25/26 of the floppy > > > > connector > > > > > > to avert the system check, but it hangs on "Pease Insert > > Disk". > > > I > > > > > > don't know whether that's because the drive doesn't spin > up > > in > > > > > time, > > > > > > or whether the thing is canny enough to know it's been > > > hoodwinked. > > > > > > > > > > > > Bleugh - after pulling apart my PC, my Emax and my > Kurzweil > > to > > > > get > > > > > > this far, I think I'm going to have to surrender to Route > > > 66...;) > > > > > But > > > > > > once I get it working, I'll definitely be making more use > of > > > the > > > > > > wondrous EMXP... > > > > > > > > > > > > specify otherwise --- In > emax@yahoogroups.com, "esynthesist" > > > > > > <esynthesist@> wrote: > > > > > > > > > > > > > > Yes there is. > > > > > > > > > > > > > > You can create an EMAX-II ZIP disk image with EMXP v2.02. > > > > > > > (using the "manage Emax HD/CD images"->"create new > image" > > > > menu). > > > > > > After > > > > > > > the 96 MB image-file has been created by EMXP, you can > add > > an > > > > > Emax- > > > > > > II > > > > > > > OS to it (again with EMXP v2.02). OS files can be > > downloaded > > > in > > > > > > this > > > > > > > group or from the emulatorarchive website. > > > > > > > > > > > > > > Then you have to copy the image to a ZIP disk (connected > to > > > > your > > > > > > PC). > > > > > > > Again use EMXP for this :-) (via "restore" function) > > > > > > > > > > > > > > One important note though ! > > > > > > > The ZIP disk must have been formatted first in an "emax- > > > > > compatible" > > > > > > way. > > > > > > > You don't need an EMAX to do that, but unfortunately my > > > > > experience > > > > > > > shows that simply formatting a ZIP disk on a Windows > > machine > > > > does > > > > > > not > > > > > > > guarantee an EMAX-compatible ZIP disk. > > > > > > > I always format them first on an old Mac Classic. This > > format > > > > > > procedure > > > > > > > seems to be compatible with Emax... > > > > > > > > > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> > > wrote: > > > > > > > > > > > > > > > > Hi - > > > > > > > > > > > > > > > > I've got an Emax II (2212) which I haven't been able > to > > > boot > > > > > up - > > > > > > > I've > > > > > > > > tried creating boot floppies, but they've never > worked, > > and > > > I > > > > > > think > > > > > > > the > > > > > > > > drive might need replacing. But I've got a 100MB SCSI
> Zip > > > > > drive, > > > > > > and > > > > > > > I > > > > > > > > was wondering if there might be any way to create a > > > bootable > > > > > > image on > > > > > > > > that via a PC...? > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
2007-03-20 by Lyn Oakey
Hello there My experiences with the Emax II with it's associated Zip can sometimes be problematic too. I find if I haven't used it for awhile the connections internally and externally (Scsi Zip cable) often benefit from being re-connected and a little contact cleaning or enhancing can do the trick. For cleaning, try Isopropyl Alcohol. regards Lyn
----- Original Message ----- From: b_j_glover To: emax@yahoogroups.com Sent: Tuesday, March 20, 2007 8:02 AM Subject: [emax] Re: Emax II - boot from Zip...? ...an additional point of confusion I'm finding with this is that I can't see any indication of ZIP drive activity on boot, so I'm not sure that the Emax is looking at these disks that I'm carefully crafting for it. I don't know whether I should be expecting some of those snapping and shuffling noises I get when using it with a PC. When I tried connecting a CD drive and booting the Emax, there was no evidence of spin-up on that either. Perhaps you could confirm whether you would expect more signs of life, even with a non-bootable Zip disk (I don't know how quiet the process should be, but this is silent), and whether your Emax II still scans the SCSI chain with the SCSI boot ID set to 0...? Thanks! --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@...> wrote: > > Nice work...;) I was fiddling around trying something similar with a > free demo of MacDrive, but it got my PC into a horrible state - I > wouldn't recommend letting this software anywhere near your > computer. I'll have another crack at it with this approach. > > ) --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote: > > > > Just FYI: I managed to format a ZIP disk on a Windows XP machine > in > > such way that the disk is readable and bootable by an Emax. > > > > I'll just explain exactly what I did: > > > > 1/ I formatted the disk using a free demo-version of MacDisk (for > > WinXP). I used the HFS (not HFS+) format option. > > > > --> This disk is not usable on an Emax yet, but at least the > original > > MS-DOS format structure is "killed" :-) > > > > 2/ Then I re-formatted the very same disk using the IomegaWare > format > > function (I have IomegaWare running on my PC, this package adds > some > > functions to the Windows Explorer menu, of which also Iomega > Format). > > I used the short format (30 seconds) procedure. > > > > --> This format resulted in an error... > > > > 3/ Immediately after this Iomega Format I re-formatted the very > same > > disk again, this time simply with the standard Format Disk > function > > in Windows Explorer. I used the "long" format option. The format > > capacity I selected was 96 MB (the only possible one). > > > > Then I copied an EMAX-II HD image to that ZIP disk with EMXP. > > > > --> This disk can be read and booted on my EMAX-II ! > > > > > > Maybe step 2 can be skipped, I don't know because I don't have any > > non-EMAX zip disks left so I can't do another test anymore. > > > > Anyway, whatever format tools you try, it is extremely important > that > > you are able to format the disk with a 96 MB capacity. So not the > > 95.7 MB which is the default capacity suggested by Windows > Explorer... > > > > So it seems possible to create an EMAX-II ZIP disk from scratch > > without any need for a Mac computer or EMAX-II sampler ! > > > > > > Have fun, > > > > ///E-Synthesist > > > > > > > > > > --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote: > > > > > > No, the restore function always works. > > > Windows formatted ZIP disks are almost the same as Emax/MAC > > formatted > > > ZIP disks. But Emax/Mac machines format a few more sectors on > the > > > disk, and unfortunately Emax seems to check the existence of > these > > > additional sectors. If it can't find them, it gives an error > > > message "Not an EMAX-II disk" or something like that. > > > > > > I haven't found a way yet to format ZIP disks with those > additonal > > > sectors under Windows XP. I think it's possible with parallel > > > versions and old Iomega drivers, but most of us use USB drives > of > > > course. > > > Anyway, that's the reason why there's no "format ZIP" function > in > > > EMXP... > > > > > > So I hope you have access to a Mac computer somewhere ? > > > (or pre-formatted ZIP-disks for MAC, those exist too !) > > > > > > ///E-Synthesist > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > > > > > Thanks for the extra info. When I was trying the ZIP method, I > > was > > > > using a PC formatted (250MB) disk, though you warned this > might > > not > > > > work. However, the "Restore" function in EMXP seemed to > operate > > > > correctly. But is the fact that Restore can be used to put an > > image > > > > on the disk enough to guarantee that the disk is in an > acceptable > > > > format to the Emax...? > > > > > > > > > That's strange ! > > > > > > > > > > I have an EMAX-II rack without any internal HD. > > > > > The only two disk devices connected to this EMAX-II are: > > > > > - the internal floppy drive > > > > > - an external 100 MB ZIP drive with ID = 6 and terminator = > ON. > > > > > (the Boot SCSI ID in the Master Module is set to 4 however) > > > > > > > > > > When I boot the EMAX-II without any floppy disk in the > drive, > > but > > > > > with an EMAX-II formatted ZIP disk with OS in the ZIP drive, > it > > > > boots > > > > > from that ZIP disk ! > > > > > > > > > > The EMAX-II always scans the complete SCSI chain if it > doesn't > > > find > > > > > an OS on the floppy disk or on the "default SCSI device" set > by > > > the > > > > > SCSI ID you mentioned in the Master module. > > > > > This Master setting does not mean that the OS can only be > > loaded > > > > from > > > > > that device. The Master SCSI ID must be set if your EMAX- II > has > > > > > multiple HD's (or ZIP disks) each carrying its own OS. In > that > > > > case, > > > > > you have to tell the EMAX-II which OS device is the > preferred > > > > > one/should be used. It indicates the first HD which will be > > > checked > > > > > by the EMAX-II. If no OS resides on that HD, EMAX-II will > start > > > the > > > > > SCSI chain search. > > > > > > > > > > So normally you should not have any problem with booting > from > > an > > > > > external ZIP drive. > > > > > (on EMAX-I however, the ZIP drive MUST have SCSI ID = 0) > > > > > > > > > > Regards > > > > > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> > wrote: > > > > > > > > > > > > Hi - > > > > > > > > > > > > Thanks for the quick reply - that's an excellent utility. > > > > > > > > > > > > Unfortunately the Emax II seems to want to read its OS > from > > the > > > > > > floppy unless you change the SCSI Boot ID to something > else. > > > The > > > > > > manual says: > > > > > > > > > > > > "This function allows you to select which SCSI drive > > (0=floppy, > > > 1- > > > > > > 7=HD) Emax II will scan on initial power up for its > operating > > > > > > software. Note: Emax II will always boot from floppy if a > > > > formatted > > > > > > floppy disk resides in the drive on power up" > > > > > > > > > > > > My external ZIP drive only allows the 5/6 ID setting. I > also > > > > tried > > > > > > booting up from a prepared internal SCSI drive set to ID > 0, > > and > > > > > using > > > > > > the trick of putting a jumper on pins 25/26 of the floppy > > > > connector > > > > > > to avert the system check, but it hangs on "Pease Insert > > Disk". > > > I > > > > > > don't know whether that's because the drive doesn't spin > up > > in > > > > > time, > > > > > > or whether the thing is canny enough to know it's been > > > hoodwinked. > > > > > > > > > > > > Bleugh - after pulling apart my PC, my Emax and my > Kurzweil > > to > > > > get > > > > > > this far, I think I'm going to have to surrender to Route > > > 66...;) > > > > > But > > > > > > once I get it working, I'll definitely be making more use > of > > > the > > > > > > wondrous EMXP... > > > > > > > > > > > > specify otherwise --- In > emax@yahoogroups.com, "esynthesist" > > > > > > <esynthesist@> wrote: > > > > > > > > > > > > > > Yes there is. > > > > > > > > > > > > > > You can create an EMAX-II ZIP disk image with EMXP v2.02. > > > > > > > (using the "manage Emax HD/CD images"->"create new > image" > > > > menu). > > > > > > After > > > > > > > the 96 MB image-file has been created by EMXP, you can > add > > an > > > > > Emax- > > > > > > II > > > > > > > OS to it (again with EMXP v2.02). OS files can be > > downloaded > > > in > > > > > > this > > > > > > > group or from the emulatorarchive website. > > > > > > > > > > > > > > Then you have to copy the image to a ZIP disk (connected > to > > > > your > > > > > > PC). > > > > > > > Again use EMXP for this :-) (via "restore" function) > > > > > > > > > > > > > > One important note though ! > > > > > > > The ZIP disk must have been formatted first in an "emax- > > > > > compatible" > > > > > > way. > > > > > > > You don't need an EMAX to do that, but unfortunately my > > > > > experience > > > > > > > shows that simply formatting a ZIP disk on a Windows > > machine > > > > does > > > > > > not > > > > > > > guarantee an EMAX-compatible ZIP disk. > > > > > > > I always format them first on an old Mac Classic. This > > format > > > > > > procedure > > > > > > > seems to be compatible with Emax... > > > > > > > > > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> > > wrote: > > > > > > > > > > > > > > > > Hi - > > > > > > > > > > > > > > > > I've got an Emax II (2212) which I haven't been able > to > > > boot > > > > > up - > > > > > > > I've > > > > > > > > tried creating boot floppies, but they've never > worked, > > and > > > I > > > > > > think > > > > > > > the > > > > > > > > drive might need replacing. But I've got a 100MB SCSI > Zip > > > > > drive, > > > > > > and > > > > > > > I > > > > > > > > was wondering if there might be any way to create a > > > bootable > > > > > > image on > > > > > > > > that via a PC...? > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed]
2007-03-21 by esynthesist
You're right... booting does not work the same when SCSI ID is set to 0. When SCSI ID is set to 0, the EMAX-II only wants to boot from floppy disk and it does not check the SCSI chain. When SCSI ID is set to any other value, the EMAX-II will first try the preferred boot SCSI ID and afterwards also try all other 6 IDs. In that case, if a bad formatted ZIP disk is present in the ZIP drive, there's still a bit of activity on the ZIP drive every time EMAX-II checks the ZIP drive. Note also that EMAX-II always shows the SCSI ID it is checking on its display. If your display only shows "Insert Disk", this means that the SCSI ID had been set to 0 and that EMAX-II is not checking the SCSI chain. Unfortunately I guess this is your problem. That's a pitty. I have no idea if it is possible to disconnect the flat cable of your floppy drive and put any other SCSI device on that port (internally, e.g. an internal ZIP drive with ID set to 0). I guess not... Anyway, good luck ! ///E-Synthesist --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@...> wrote: > > ...an additional point of confusion I'm finding with this is that I > can't see any indication of ZIP drive activity on boot, so I'm not > sure that the Emax is looking at these disks that I'm carefully > crafting for it. I don't know whether I should be expecting some of > those snapping and shuffling noises I get when using it with a PC. > When I tried connecting a CD drive and booting the Emax, there was > no evidence of spin-up on that either. > > Perhaps you could confirm whether you would expect more signs of > life, even with a non-bootable Zip disk (I don't know how quiet the > process should be, but this is silent), and whether your Emax II > still scans the SCSI chain with the SCSI boot ID set to 0...? > > Thanks! > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > Nice work...;) I was fiddling around trying something similar with > a > > free demo of MacDrive, but it got my PC into a horrible state - I > > wouldn't recommend letting this software anywhere near your > > computer. I'll have another crack at it with this approach. > > > > ) --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote: > > > > > > Just FYI: I managed to format a ZIP disk on a Windows XP machine > > in > > > such way that the disk is readable and bootable by an Emax. > > > > > > I'll just explain exactly what I did: > > > > > > 1/ I formatted the disk using a free demo-version of MacDisk > (for > > > WinXP). I used the HFS (not HFS+) format option. > > > > > > --> This disk is not usable on an Emax yet, but at least the > > original > > > MS-DOS format structure is "killed" :-) > > > > > > 2/ Then I re-formatted the very same disk using the IomegaWare > > format > > > function (I have IomegaWare running on my PC, this package adds > > some > > > functions to the Windows Explorer menu, of which also Iomega > > Format). > > > I used the short format (30 seconds) procedure. > > > > > > --> This format resulted in an error... > > > > > > 3/ Immediately after this Iomega Format I re-formatted the very > > same > > > disk again, this time simply with the standard Format Disk > > function > > > in Windows Explorer. I used the "long" format option. The format > > > capacity I selected was 96 MB (the only possible one). > > > > > > Then I copied an EMAX-II HD image to that ZIP disk with EMXP. > > > > > > --> This disk can be read and booted on my EMAX-II ! > > > > > > > > > Maybe step 2 can be skipped, I don't know because I don't have > any > > > non-EMAX zip disks left so I can't do another test anymore. > > > > > > Anyway, whatever format tools you try, it is extremely important > > that > > > you are able to format the disk with a 96 MB capacity. So not > the > > > 95.7 MB which is the default capacity suggested by Windows > > Explorer... > > > > > > So it seems possible to create an EMAX-II ZIP disk from scratch > > > without any need for a Mac computer or EMAX-II sampler ! > > > > > > > > > Have fun, > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote: > > > > > > > > No, the restore function always works. > > > > Windows formatted ZIP disks are almost the same as Emax/MAC > > > formatted > > > > ZIP disks. But Emax/Mac machines format a few more sectors on > > the > > > > disk, and unfortunately Emax seems to check the existence of > > these > > > > additional sectors. If it can't find them, it gives an error > > > > message "Not an EMAX-II disk" or something like that. > > > > > > > > I haven't found a way yet to format ZIP disks with those > > additonal > > > > sectors under Windows XP. I think it's possible with parallel > > > > versions and old Iomega drivers, but most of us use USB drives > > of > > > > course. > > > > Anyway, that's the reason why there's no "format ZIP" function > > in > > > > EMXP... > > > > > > > > So I hope you have access to a Mac computer somewhere ? > > > > (or pre-formatted ZIP-disks for MAC, those exist too !) > > > > > > > > ///E-Synthesist > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > > > > > > > Thanks for the extra info. When I was trying the ZIP method, > I > > > was > > > > > using a PC formatted (250MB) disk, though you warned this > > might > > > not > > > > > work. However, the "Restore" function in EMXP seemed to > > operate > > > > > correctly. But is the fact that Restore can be used to put > an > > > image > > > > > on the disk enough to guarantee that the disk is in an > > acceptable > > > > > format to the Emax...? > > > > > > > > > > > That's strange ! > > > > > > > > > > > > I have an EMAX-II rack without any internal HD. > > > > > > The only two disk devices connected to this EMAX-II are: > > > > > > - the internal floppy drive > > > > > > - an external 100 MB ZIP drive with ID = 6 and terminator > = > > ON. > > > > > > (the Boot SCSI ID in the Master Module is set to 4 however) > > > > > > > > > > > > When I boot the EMAX-II without any floppy disk in the > > drive, > > > but > > > > > > with an EMAX-II formatted ZIP disk with OS in the ZIP > drive, > > it > > > > > boots > > > > > > from that ZIP disk ! > > > > > > > > > > > > The EMAX-II always scans the complete SCSI chain if it > > doesn't > > > > find > > > > > > an OS on the floppy disk or on the "default SCSI device" > set > > by > > > > the > > > > > > SCSI ID you mentioned in the Master module. > > > > > > This Master setting does not mean that the OS can only be > > > loaded > > > > > from > > > > > > that device. The Master SCSI ID must be set if your EMAX- > II > > has > > > > > > multiple HD's (or ZIP disks) each carrying its own OS. In > > that > > > > > case, > > > > > > you have to tell the EMAX-II which OS device is the > > preferred > > > > > > one/should be used. It indicates the first HD which will > be > > > > checked > > > > > > by the EMAX-II. If no OS resides on that HD, EMAX-II will > > start > > > > the > > > > > > SCSI chain search. > > > > > > > > > > > > So normally you should not have any problem with booting > > from > > > an > > > > > > external ZIP drive. > > > > > > (on EMAX-I however, the ZIP drive MUST have SCSI ID = 0) > > > > > > > > > > > > Regards > > > > > > > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@...m, "b_j_glover" <b_j_glover@> > > wrote: > > > > > > > > > > > > > > Hi - > > > > > > > > > > > > > > Thanks for the quick reply - that's an excellent utility. > > > > > > > > > > > > > > Unfortunately the Emax II seems to want to read its OS > > from > > > the > > > > > > > floppy unless you change the SCSI Boot ID to something > > else. > > > > The > > > > > > > manual says: > > > > > > > > > > > > > > "This function allows you to select which SCSI drive > > > (0=floppy, > > > > 1- > > > > > > > 7=HD) Emax II will scan on initial power up for its > > operating > > > > > > > software. Note: Emax II will always boot from floppy if > a > > > > > formatted > > > > > > > floppy disk resides in the drive on power up" > > > > > > > > > > > > > > My external ZIP drive only allows the 5/6 ID setting. I > > also > > > > > tried > > > > > > > booting up from a prepared internal SCSI drive set to ID > > 0, > > > and > > > > > > using > > > > > > > the trick of putting a jumper on pins 25/26 of the > floppy > > > > > connector > > > > > > > to avert the system check, but it hangs on "Pease Insert > > > Disk". > > > > I > > > > > > > don't know whether that's because the drive doesn't spin > > up > > > in > > > > > > time, > > > > > > > or whether the thing is canny enough to know it's been > > > > hoodwinked. > > > > > > > > > > > > > > Bleugh - after pulling apart my PC, my Emax and my > > Kurzweil > > > to > > > > > get > > > > > > > this far, I think I'm going to have to surrender to > Route > > > > 66...;) > > > > > > But > > > > > > > once I get it working, I'll definitely be making more > use > > of > > > > the > > > > > > > wondrous EMXP... > > > > > > > > > > > > > > specify otherwise --- In > > emax@...m, "esynthesist" > > > > > > > <esynthesist@> wrote: > > > > > > > > > > > > > > > > Yes there is. > > > > > > > > > > > > > > > > You can create an EMAX-II ZIP disk image with EMXP > v2.02. > > > > > > > > (using the "manage Emax HD/CD images"->"create new > > image" > > > > > menu). > > > > > > > After > > > > > > > > the 96 MB image-file has been created by EMXP, you can > > add > > > an > > > > > > Emax- > > > > > > > II > > > > > > > > OS to it (again with EMXP v2.02). OS files can be > > > downloaded > > > > in > > > > > > > this > > > > > > > > group or from the emulatorarchive website. > > > > > > > > > > > > > > > > Then you have to copy the image to a ZIP disk > (connected > > to > > > > > your > > > > > > > PC). > > > > > > > > Again use EMXP for this :-) (via "restore" function) > > > > > > > > > > > > > > > > One important note though ! > > > > > > > > The ZIP disk must have been formatted first in > an "emax- > > > > > > compatible" > > > > > > > way. > > > > > > > > You don't need an EMAX to do that, but unfortunately > my > > > > > > experience > > > > > > > > shows that simply formatting a ZIP disk on a Windows > > > machine > > > > > does > > > > > > > not > > > > > > > > guarantee an EMAX-compatible ZIP disk. > > > > > > > > I always format them first on an old Mac Classic. This > > > format > > > > > > > procedure > > > > > > > > seems to be compatible with Emax... > > > > > > > > > > > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" > <b_j_glover@> > > > wrote: > > > > > > > > > > > > > > > > > > Hi - > > > > > > > > > > > > > > > > > > I've got an Emax II (2212) which I haven't been able
> > to > > > > boot > > > > > > up - > > > > > > > > I've > > > > > > > > > tried creating boot floppies, but they've never > > worked, > > > and > > > > I > > > > > > > think > > > > > > > > the > > > > > > > > > drive might need replacing. But I've got a 100MB > SCSI > > Zip > > > > > > drive, > > > > > > > and > > > > > > > > I > > > > > > > > > was wondering if there might be any way to create a > > > > bootable > > > > > > > image on > > > > > > > > > that via a PC...? > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
2007-03-21 by b_j_glover
Darn, foiled...(thanks for checking that...) --- In emax@yahoogroups.com, "esynthesist" <esynthesist@...> wrote: > > You're right... booting does not work the same when SCSI ID is set to > 0. > When SCSI ID is set to 0, the EMAX-II only wants to boot from floppy > disk and it does not check the SCSI chain. > When SCSI ID is set to any other value, the EMAX-II will first try > the preferred boot SCSI ID and afterwards also try all other 6 IDs. > In that case, if a bad formatted ZIP disk is present in the ZIP > drive, there's still a bit of activity on the ZIP drive every time > EMAX-II checks the ZIP drive. > Note also that EMAX-II always shows the SCSI ID it is checking on its > display. If your display only shows "Insert Disk", this means that > the SCSI ID had been set to 0 and that EMAX-II is not checking the > SCSI chain. > > Unfortunately I guess this is your problem. That's a pitty. > I have no idea if it is possible to disconnect the flat cable of your > floppy drive and put any other SCSI device on that port (internally, > e.g. an internal ZIP drive with ID set to 0). I guess not... > > Anyway, good luck ! > > ///E-Synthesist > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > ...an additional point of confusion I'm finding with this is that I > > can't see any indication of ZIP drive activity on boot, so I'm not > > sure that the Emax is looking at these disks that I'm carefully > > crafting for it. I don't know whether I should be expecting some of > > those snapping and shuffling noises I get when using it with a PC. > > When I tried connecting a CD drive and booting the Emax, there was > > no evidence of spin-up on that either. > > > > Perhaps you could confirm whether you would expect more signs of > > life, even with a non-bootable Zip disk (I don't know how quiet the > > process should be, but this is silent), and whether your Emax II > > still scans the SCSI chain with the SCSI boot ID set to 0...? > > > > Thanks! > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > > > Nice work...;) I was fiddling around trying something similar > with > > a > > > free demo of MacDrive, but it got my PC into a horrible state - I > > > wouldn't recommend letting this software anywhere near your > > > computer. I'll have another crack at it with this approach. > > > > > > ) --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote: > > > > > > > > Just FYI: I managed to format a ZIP disk on a Windows XP > machine > > > in > > > > such way that the disk is readable and bootable by an Emax. > > > > > > > > I'll just explain exactly what I did: > > > > > > > > 1/ I formatted the disk using a free demo-version of MacDisk > > (for > > > > WinXP). I used the HFS (not HFS+) format option. > > > > > > > > --> This disk is not usable on an Emax yet, but at least the > > > original > > > > MS-DOS format structure is "killed" :-) > > > > > > > > 2/ Then I re-formatted the very same disk using the IomegaWare > > > format > > > > function (I have IomegaWare running on my PC, this package adds > > > some > > > > functions to the Windows Explorer menu, of which also Iomega > > > Format). > > > > I used the short format (30 seconds) procedure. > > > > > > > > --> This format resulted in an error... > > > > > > > > 3/ Immediately after this Iomega Format I re-formatted the very > > > same > > > > disk again, this time simply with the standard Format Disk > > > function > > > > in Windows Explorer. I used the "long" format option. The > format > > > > capacity I selected was 96 MB (the only possible one). > > > > > > > > Then I copied an EMAX-II HD image to that ZIP disk with EMXP. > > > > > > > > --> This disk can be read and booted on my EMAX-II ! > > > > > > > > > > > > Maybe step 2 can be skipped, I don't know because I don't have > > any > > > > non-EMAX zip disks left so I can't do another test anymore. > > > > > > > > Anyway, whatever format tools you try, it is extremely > important > > > that > > > > you are able to format the disk with a 96 MB capacity. So not > > the > > > > 95.7 MB which is the default capacity suggested by Windows > > > Explorer... > > > > > > > > So it seems possible to create an EMAX-II ZIP disk from scratch > > > > without any need for a Mac computer or EMAX-II sampler ! > > > > > > > > > > > > Have fun, > > > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote: > > > > > > > > > > No, the restore function always works. > > > > > Windows formatted ZIP disks are almost the same as Emax/MAC > > > > formatted > > > > > ZIP disks. But Emax/Mac machines format a few more sectors on > > > the > > > > > disk, and unfortunately Emax seems to check the existence of > > > these > > > > > additional sectors. If it can't find them, it gives an error > > > > > message "Not an EMAX-II disk" or something like that. > > > > > > > > > > I haven't found a way yet to format ZIP disks with those > > > additonal > > > > > sectors under Windows XP. I think it's possible with parallel > > > > > versions and old Iomega drivers, but most of us use USB > drives > > > of > > > > > course. > > > > > Anyway, that's the reason why there's no "format ZIP" > function > > > in > > > > > EMXP... > > > > > > > > > > So I hope you have access to a Mac computer somewhere ? > > > > > (or pre-formatted ZIP-disks for MAC, those exist too !) > > > > > > > > > > ///E-Synthesist > > > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > > > > > > > > > Thanks for the extra info. When I was trying the ZIP > method, > > I > > > > was > > > > > > using a PC formatted (250MB) disk, though you warned this > > > might > > > > not > > > > > > work. However, the "Restore" function in EMXP seemed to > > > operate > > > > > > correctly. But is the fact that Restore can be used to put > > an > > > > image > > > > > > on the disk enough to guarantee that the disk is in an > > > acceptable > > > > > > format to the Emax...? > > > > > > > > > > > > > That's strange ! > > > > > > > > > > > > > > I have an EMAX-II rack without any internal HD. > > > > > > > The only two disk devices connected to this EMAX-II are: > > > > > > > - the internal floppy drive > > > > > > > - an external 100 MB ZIP drive with ID = 6 and terminator > > = > > > ON. > > > > > > > (the Boot SCSI ID in the Master Module is set to 4 > however) > > > > > > > > > > > > > > When I boot the EMAX-II without any floppy disk in the > > > drive, > > > > but > > > > > > > with an EMAX-II formatted ZIP disk with OS in the ZIP > > drive, > > > it > > > > > > boots > > > > > > > from that ZIP disk ! > > > > > > > > > > > > > > The EMAX-II always scans the complete SCSI chain if it > > > doesn't > > > > > find > > > > > > > an OS on the floppy disk or on the "default SCSI device" > > set > > > by > > > > > the > > > > > > > SCSI ID you mentioned in the Master module. > > > > > > > This Master setting does not mean that the OS can only be > > > > loaded > > > > > > from > > > > > > > that device. The Master SCSI ID must be set if your EMAX- > > II > > > has > > > > > > > multiple HD's (or ZIP disks) each carrying its own OS. In > > > that > > > > > > case, > > > > > > > you have to tell the EMAX-II which OS device is the > > > preferred > > > > > > > one/should be used. It indicates the first HD which will > > be > > > > > checked > > > > > > > by the EMAX-II. If no OS resides on that HD, EMAX-II will > > > start > > > > > the > > > > > > > SCSI chain search. > > > > > > > > > > > > > > So normally you should not have any problem with booting > > > from > > > > an > > > > > > > external ZIP drive. > > > > > > > (on EMAX-I however, the ZIP drive MUST have SCSI ID = 0) > > > > > > > > > > > > > > Regards > > > > > > > > > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> > > > wrote: > > > > > > > > > > > > > > > > Hi - > > > > > > > > > > > > > > > > Thanks for the quick reply - that's an excellent > utility. > > > > > > > > > > > > > > > > Unfortunately the Emax II seems to want to read its OS > > > from > > > > the > > > > > > > > floppy unless you change the SCSI Boot ID to something > > > else. > > > > > The > > > > > > > > manual says: > > > > > > > > > > > > > > > > "This function allows you to select which SCSI drive > > > > (0=floppy, > > > > > 1- > > > > > > > > 7=HD) Emax II will scan on initial power up for its > > > operating > > > > > > > > software. Note: Emax II will always boot from floppy if > > a > > > > > > formatted > > > > > > > > floppy disk resides in the drive on power up" > > > > > > > > > > > > > > > > My external ZIP drive only allows the 5/6 ID setting. I > > > also > > > > > > tried > > > > > > > > booting up from a prepared internal SCSI drive set to > ID > > > 0, > > > > and > > > > > > > using > > > > > > > > the trick of putting a jumper on pins 25/26 of the > > floppy > > > > > > connector > > > > > > > > to avert the system check, but it hangs on "Pease > Insert > > > > Disk". > > > > > I > > > > > > > > don't know whether that's because the drive doesn't > spin > > > up > > > > in > > > > > > > time, > > > > > > > > or whether the thing is canny enough to know it's been > > > > > hoodwinked. > > > > > > > > > > > > > > > > Bleugh - after pulling apart my PC, my Emax and my > > > Kurzweil > > > > to > > > > > > get > > > > > > > > this far, I think I'm going to have to surrender to > > Route > > > > > 66...;) > > > > > > > But > > > > > > > > once I get it working, I'll definitely be making more > > use > > > of > > > > > the > > > > > > > > wondrous EMXP... > > > > > > > > > > > > > > > > specify otherwise --- In > > > emax@yahoogroups.com, "esynthesist" > > > > > > > > <esynthesist@> wrote: > > > > > > > > > > > > > > > > > > Yes there is. > > > > > > > > > > > > > > > > > > You can create an EMAX-II ZIP disk image with EMXP > > v2.02. > > > > > > > > > (using the "manage Emax HD/CD images"->"create new > > > image" > > > > > > menu). > > > > > > > > After > > > > > > > > > the 96 MB image-file has been created by EMXP, you > can > > > add > > > > an > > > > > > > Emax- > > > > > > > > II > > > > > > > > > OS to it (again with EMXP v2.02). OS files can be > > > > downloaded > > > > > in > > > > > > > > this > > > > > > > > > group or from the emulatorarchive website. > > > > > > > > > > > > > > > > > > Then you have to copy the image to a ZIP disk > > (connected > > > to > > > > > > your > > > > > > > > PC). > > > > > > > > > Again use EMXP for this :-) (via "restore" function) > > > > > > > > > > > > > > > > > > One important note though ! > > > > > > > > > The ZIP disk must have been formatted first in > > an "emax- > > > > > > > compatible" > > > > > > > > way. > > > > > > > > > You don't need an EMAX to do that, but unfortunately > > my > > > > > > > experience > > > > > > > > > shows that simply formatting a ZIP disk on a Windows > > > > machine > > > > > > does > > > > > > > > not > > > > > > > > > guarantee an EMAX-compatible ZIP disk. > > > > > > > > > I always format them first on an old Mac Classic. > This > > > > format > > > > > > > > procedure > > > > > > > > > seems to be compatible with Emax... > > > > > > > > > > > > > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" > > <b_j_glover@> > > > > wrote: > > > > > > > > > > > > > > > > > > > > Hi - > > > > > > > > > > > > > > > > > > > > I've got an Emax II (2212) which I haven't been > able > > > to > > > > > boot > > > > > > > up - > > > > > > > > > I've > > > > > > > > > > tried creating boot floppies, but they've never > > > worked, > > > > and > > > > > I > > > > > > > > think > > > > > > > > > the > > > > > > > > > > drive might need replacing. But I've got a 100MB > > SCSI > > > Zip > > > > > > > drive, > > > > > > > > and > > > > > > > > > I > > > > > > > > > > was wondering if there might be any way to create a
> > > > > bootable > > > > > > > > image on > > > > > > > > > > that via a PC...? > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
2007-04-09 by b_j_glover
Postscript: Finally managed to create a boot floppy that worked...I think I must have been using a dud batch of old disks...and having changed that tricky SCSI setting have spent most of the Easter bank holiday weekend using EMXP to create bootable Zip disks stuffed with the old Emax library disk images. Happy days. :) > > Darn, foiled...(thanks for checking that...) > > --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote: > > > > You're right... booting does not work the same when SCSI ID is set > to > > 0. > > When SCSI ID is set to 0, the EMAX-II only wants to boot from > floppy > > disk and it does not check the SCSI chain. > > When SCSI ID is set to any other value, the EMAX-II will first try > > the preferred boot SCSI ID and afterwards also try all other 6 IDs. > > In that case, if a bad formatted ZIP disk is present in the ZIP > > drive, there's still a bit of activity on the ZIP drive every time > > EMAX-II checks the ZIP drive. > > Note also that EMAX-II always shows the SCSI ID it is checking on > its > > display. If your display only shows "Insert Disk", this means that > > the SCSI ID had been set to 0 and that EMAX-II is not checking the > > SCSI chain. > > > > Unfortunately I guess this is your problem. That's a pitty. > > I have no idea if it is possible to disconnect the flat cable of > your > > floppy drive and put any other SCSI device on that port > (internally, > > e.g. an internal ZIP drive with ID set to 0). I guess not... > > > > Anyway, good luck ! > > > > ///E-Synthesist > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > > > ...an additional point of confusion I'm finding with this is > that I > > > can't see any indication of ZIP drive activity on boot, so I'm > not > > > sure that the Emax is looking at these disks that I'm carefully > > > crafting for it. I don't know whether I should be expecting some > of > > > those snapping and shuffling noises I get when using it with a > PC. > > > When I tried connecting a CD drive and booting the Emax, there > was > > > no evidence of spin-up on that either. > > > > > > Perhaps you could confirm whether you would expect more signs of > > > life, even with a non-bootable Zip disk (I don't know how quiet > the > > > process should be, but this is silent), and whether your Emax II > > > still scans the SCSI chain with the SCSI boot ID set to 0...? > > > > > > Thanks! > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> wrote: > > > > > > > > Nice work...;) I was fiddling around trying something similar > > with > > > a > > > > free demo of MacDrive, but it got my PC into a horrible state - > I > > > > wouldn't recommend letting this software anywhere near your > > > > computer. I'll have another crack at it with this approach. > > > > > > > > ) --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> > wrote: > > > > > > > > > > Just FYI: I managed to format a ZIP disk on a Windows XP > > machine > > > > in > > > > > such way that the disk is readable and bootable by an Emax. > > > > > > > > > > I'll just explain exactly what I did: > > > > > > > > > > 1/ I formatted the disk using a free demo-version of MacDisk > > > (for > > > > > WinXP). I used the HFS (not HFS+) format option. > > > > > > > > > > --> This disk is not usable on an Emax yet, but at least the > > > > original > > > > > MS-DOS format structure is "killed" :-) > > > > > > > > > > 2/ Then I re-formatted the very same disk using the > IomegaWare > > > > format > > > > > function (I have IomegaWare running on my PC, this package > adds > > > > some > > > > > functions to the Windows Explorer menu, of which also Iomega > > > > Format). > > > > > I used the short format (30 seconds) procedure. > > > > > > > > > > --> This format resulted in an error... > > > > > > > > > > 3/ Immediately after this Iomega Format I re-formatted the > very > > > > same > > > > > disk again, this time simply with the standard Format Disk > > > > function > > > > > in Windows Explorer. I used the "long" format option. The > > format > > > > > capacity I selected was 96 MB (the only possible one). > > > > > > > > > > Then I copied an EMAX-II HD image to that ZIP disk with EMXP. > > > > > > > > > > --> This disk can be read and booted on my EMAX-II ! > > > > > > > > > > > > > > > Maybe step 2 can be skipped, I don't know because I don't > have > > > any > > > > > non-EMAX zip disks left so I can't do another test anymore. > > > > > > > > > > Anyway, whatever format tools you try, it is extremely > > important > > > > that > > > > > you are able to format the disk with a 96 MB capacity. So > not > > > the > > > > > 95.7 MB which is the default capacity suggested by Windows > > > > Explorer... > > > > > > > > > > So it seems possible to create an EMAX-II ZIP disk from > scratch > > > > > without any need for a Mac computer or EMAX-II sampler ! > > > > > > > > > > > > > > > Have fun, > > > > > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> > wrote: > > > > > > > > > > > > No, the restore function always works. > > > > > > Windows formatted ZIP disks are almost the same as > Emax/MAC > > > > > formatted > > > > > > ZIP disks. But Emax/Mac machines format a few more sectors > on > > > > the > > > > > > disk, and unfortunately Emax seems to check the existence > of > > > > these > > > > > > additional sectors. If it can't find them, it gives an > error > > > > > > message "Not an EMAX-II disk" or something like that. > > > > > > > > > > > > I haven't found a way yet to format ZIP disks with those > > > > additonal > > > > > > sectors under Windows XP. I think it's possible with > parallel > > > > > > versions and old Iomega drivers, but most of us use USB > > drives > > > > of > > > > > > course. > > > > > > Anyway, that's the reason why there's no "format ZIP" > > function > > > > in > > > > > > EMXP... > > > > > > > > > > > > So I hope you have access to a Mac computer somewhere ? > > > > > > (or pre-formatted ZIP-disks for MAC, those exist too !) > > > > > > > > > > > > ///E-Synthesist > > > > > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" <b_j_glover@> > wrote: > > > > > > > > > > > > > > Thanks for the extra info. When I was trying the ZIP > > method, > > > I > > > > > was > > > > > > > using a PC formatted (250MB) disk, though you warned > this > > > > might > > > > > not > > > > > > > work. However, the "Restore" function in EMXP seemed to > > > > operate > > > > > > > correctly. But is the fact that Restore can be used to > put > > > an > > > > > image > > > > > > > on the disk enough to guarantee that the disk is in an > > > > acceptable > > > > > > > format to the Emax...? > > > > > > > > > > > > > > > That's strange ! > > > > > > > > > > > > > > > > I have an EMAX-II rack without any internal HD. > > > > > > > > The only two disk devices connected to this EMAX-II > are: > > > > > > > > - the internal floppy drive > > > > > > > > - an external 100 MB ZIP drive with ID = 6 and > terminator > > > = > > > > ON. > > > > > > > > (the Boot SCSI ID in the Master Module is set to 4 > > however) > > > > > > > > > > > > > > > > When I boot the EMAX-II without any floppy disk in the > > > > drive, > > > > > but > > > > > > > > with an EMAX-II formatted ZIP disk with OS in the ZIP > > > drive, > > > > it > > > > > > > boots > > > > > > > > from that ZIP disk ! > > > > > > > > > > > > > > > > The EMAX-II always scans the complete SCSI chain if it > > > > doesn't > > > > > > find > > > > > > > > an OS on the floppy disk or on the "default SCSI > device" > > > set > > > > by > > > > > > the > > > > > > > > SCSI ID you mentioned in the Master module. > > > > > > > > This Master setting does not mean that the OS can only > be > > > > > loaded > > > > > > > from > > > > > > > > that device. The Master SCSI ID must be set if your > EMAX- > > > II > > > > has > > > > > > > > multiple HD's (or ZIP disks) each carrying its own OS. > In > > > > that > > > > > > > case, > > > > > > > > you have to tell the EMAX-II which OS device is the > > > > preferred > > > > > > > > one/should be used. It indicates the first HD which > will > > > be > > > > > > checked > > > > > > > > by the EMAX-II. If no OS resides on that HD, EMAX-II > will > > > > start > > > > > > the > > > > > > > > SCSI chain search. > > > > > > > > > > > > > > > > So normally you should not have any problem with > booting > > > > from > > > > > an > > > > > > > > external ZIP drive. > > > > > > > > (on EMAX-I however, the ZIP drive MUST have SCSI ID = > 0) > > > > > > > > > > > > > > > > Regards > > > > > > > > > > > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" > <b_j_glover@> > > > > wrote: > > > > > > > > > > > > > > > > > > Hi - > > > > > > > > > > > > > > > > > > Thanks for the quick reply - that's an excellent > > utility. > > > > > > > > > > > > > > > > > > Unfortunately the Emax II seems to want to read its > OS > > > > from > > > > > the > > > > > > > > > floppy unless you change the SCSI Boot ID to > something > > > > else. > > > > > > The > > > > > > > > > manual says: > > > > > > > > > > > > > > > > > > "This function allows you to select which SCSI drive > > > > > (0=floppy, > > > > > > 1- > > > > > > > > > 7=HD) Emax II will scan on initial power up for its > > > > operating > > > > > > > > > software. Note: Emax II will always boot from floppy > if > > > a > > > > > > > formatted > > > > > > > > > floppy disk resides in the drive on power up" > > > > > > > > > > > > > > > > > > My external ZIP drive only allows the 5/6 ID > setting. I > > > > also > > > > > > > tried > > > > > > > > > booting up from a prepared internal SCSI drive set > to > > ID > > > > 0, > > > > > and > > > > > > > > using > > > > > > > > > the trick of putting a jumper on pins 25/26 of the > > > floppy > > > > > > > connector > > > > > > > > > to avert the system check, but it hangs on "Pease > > Insert > > > > > Disk". > > > > > > I > > > > > > > > > don't know whether that's because the drive doesn't > > spin > > > > up > > > > > in > > > > > > > > time, > > > > > > > > > or whether the thing is canny enough to know it's > been > > > > > > hoodwinked. > > > > > > > > > > > > > > > > > > Bleugh - after pulling apart my PC, my Emax and my > > > > Kurzweil > > > > > to > > > > > > > get > > > > > > > > > this far, I think I'm going to have to surrender to > > > Route > > > > > > 66...;) > > > > > > > > But > > > > > > > > > once I get it working, I'll definitely be making > more > > > use > > > > of > > > > > > the > > > > > > > > > wondrous EMXP... > > > > > > > > > > > > > > > > > > specify otherwise --- In > > > > emax@yahoogroups.com, "esynthesist" > > > > > > > > > <esynthesist@> wrote: > > > > > > > > > > > > > > > > > > > > Yes there is. > > > > > > > > > > > > > > > > > > > > You can create an EMAX-II ZIP disk image with EMXP > > > v2.02. > > > > > > > > > > (using the "manage Emax HD/CD images"->"create new > > > > image" > > > > > > > menu). > > > > > > > > > After > > > > > > > > > > the 96 MB image-file has been created by EMXP, you > > can > > > > add > > > > > an > > > > > > > > Emax- > > > > > > > > > II > > > > > > > > > > OS to it (again with EMXP v2.02). OS files can be > > > > > downloaded > > > > > > in > > > > > > > > > this > > > > > > > > > > group or from the emulatorarchive website. > > > > > > > > > > > > > > > > > > > > Then you have to copy the image to a ZIP disk > > > (connected > > > > to > > > > > > > your > > > > > > > > > PC). > > > > > > > > > > Again use EMXP for this :-) (via "restore" > function) > > > > > > > > > > > > > > > > > > > > One important note though ! > > > > > > > > > > The ZIP disk must have been formatted first in > > > an "emax- > > > > > > > > compatible" > > > > > > > > > way. > > > > > > > > > > You don't need an EMAX to do that, but > unfortunately > > > my > > > > > > > > experience > > > > > > > > > > shows that simply formatting a ZIP disk on a > Windows > > > > > machine > > > > > > > does > > > > > > > > > not > > > > > > > > > > guarantee an EMAX-compatible ZIP disk. > > > > > > > > > > I always format them first on an old Mac Classic. > > This > > > > > format > > > > > > > > > procedure > > > > > > > > > > seems to be compatible with Emax... > > > > > > > > > > > > > > > > > > > > ///E-Synthesist > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "b_j_glover" > > > <b_j_glover@> > > > > > wrote: > > > > > > > > > > > > > > > > > > > > > > Hi - > > > > > > > > > > > > > > > > > > > > > > I've got an Emax II (2212) which I haven't been > > able > > > > to > > > > > > boot > > > > > > > > up - > > > > > > > > > > I've > > > > > > > > > > > tried creating boot floppies, but they've never > > > > worked, > > > > > and > > > > > > I > > > > > > > > > think > > > > > > > > > > the > > > > > > > > > > > drive might need replacing. But I've got a 100MB
> > > SCSI > > > > Zip > > > > > > > > drive, > > > > > > > > > and > > > > > > > > > > I > > > > > > > > > > > was wondering if there might be any way to > create a > > > > > > bootable > > > > > > > > > image on > > > > > > > > > > > that via a PC...? > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
