emx problem
2007-03-18 by tjockapeppar
Hi all EMAX II users! =) I tried to write an EMAX disk with the emx program. The problem occurs just when the samples are about to be written. Then it says "address mark not found!". I have no idea how to fix this so please help =).
2007-03-18 by esynthesist
Are you running EMX on a DOS-booted PC (so not in a DOS window under Windows) ? ///E-Synthesist --- In emax@yahoogroups.com, "tjockapeppar" <tjockapeppar@...> wrote:
> > Hi all EMAX II users! =) > > I tried to write an EMAX disk with the emx program. The problem occurs > just when the samples are about to be written. Then it says "address > mark not found!". I have no idea how to fix this so please help =). >
2007-03-19 by tjockapeppar
--- In emax@yahoogroups.com, "esynthesist" <esynthesist@...> wrote: > > Are you running EMX on a DOS-booted PC (so not in a DOS window under > Windows) ? > > ///E-Synthesist > > --- In emax@yahoogroups.com, "tjockapeppar" <tjockapeppar@> wrote: > > > > Hi all EMAX II users! =) > > > > I tried to write an EMAX disk with the emx program. The problem occurs > > just when the samples are about to be written. Then it says "address > > mark not found!". I have no idea how to fix this so please help =). > > > I'm running it in windows XP. Is it necessary to run it in dos? In that case, would the dosemulator DosBox be enough?
2007-03-19 by esynthesist
The only reliable way of using EMX is on a PC that has booted in MS- DOS. Emulations won't help as far as I know. EMX directly communicates with the BIOS, which is not allowed anymore in Windows XP. Win XP does not give an error if a program tries to do that, but it will only "emulate" the functions behind those BIOS calls. This emulation is limited. That's why it returns this addressing error. Sometimes it even doesn't give any error at all but the result will still be wrong. So you really should boot your PC in MS-DOS (you can make a bootable floppy to do that). Or you can try EMXP for Win XP (not that I want to push that :-) ///E-Synthesist --- In emax@yahoogroups.com, "tjockapeppar" <tjockapeppar@...> wrote: > > --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote: > > > > Are you running EMX on a DOS-booted PC (so not in a DOS window under > > Windows) ? > > > > ///E-Synthesist > > > > --- In emax@yahoogroups.com, "tjockapeppar" <tjockapeppar@> wrote: > > > > > > Hi all EMAX II users! =) > > > > > > I tried to write an EMAX disk with the emx program. The problem occurs > > > just when the samples are about to be written. Then it says "address > > > mark not found!". I have no idea how to fix this so please help =).
> > > > > > > I'm running it in windows XP. Is it necessary to run it in dos? In > that case, would the dosemulator DosBox be enough? >
