How to use emax Multitimbral ?
2007-05-31 by sam_goose_266
Hi can anyone tell me how/if its possible to play more then one preset at once on an emax 1, using an external midi sequencer. If so how do i set up the emax to play multiple voices at once? Thanks!
2007-05-31 by Lyn Oakey
Into Sequencer set-up then put Supermode on, Go into Track Status and make a track ready to record (the letter R comes up in the display when you press yes ) Press record, then play. then enter and UNTITLED will be displayed. Create as many tracks as you need and go into Track Preset and assign a preset to those tracks. Track numbers and Midi channel numbers are the same You can have upto 8 parts playing mono timbrally, otherwise you divide your 8 note polyphony accordingly. Lyn
----- Original Message ----- From: sam_goose_266 To: emax@yahoogroups.com Sent: Thursday, May 31, 2007 2:13 PM Subject: [emax] How to use emax Multitimbral ? Hi can anyone tell me how/if its possible to play more then one preset at once on an emax 1, using an external midi sequencer. If so how do i set up the emax to play multiple voices at once? Thanks! [Non-text portions of this message have been removed]
--- In emax@yahoogroups.com, "Lyn Oakey" <lynoakey@...> wrote: > > Into Sequencer set-up then put Supermode on, > Go into Track Status and make a track ready to record (the letter R > comes up in the display when you press yes ) > Press record, then play. then enter and UNTITLED will be displayed. > Create as many tracks as you need and go into Track Preset and assign > a preset to those tracks. > Track numbers and Midi channel numbers are the same Hello and Thank you. I was just wondering is there anyway to have the sounds come out of different outputs? I found the manual a bit confusing on this issue. It says i need to play a voice then if to sounds happen at once they get sent to other outputs? Is there no way i can just have 1 out for each sound or something?
> You can have upto 8 parts playing mono timbrally, otherwise you > divide your 8 note polyphony accordingly. > > Lyn > > > ----- Original Message ----- > From: sam_goose_266 > To: emax@yahoogroups.com > Sent: Thursday, May 31, 2007 2:13 PM > Subject: [emax] How to use emax Multitimbral ? > > > Hi can anyone tell me how/if its possible to play more then one preset > at once on an emax 1, using an external midi sequencer. > > If so how do i set up the emax to play multiple voices at once? > > Thanks! > > > > > > [Non-text portions of this message have been removed] >
