Emax
Emax II Why is it that when you go into digital processing you only get 1
2007-06-30 by joechatman1122
channel. My samples are stereo, up until i enter digiatal processing.
As soon as i choose the voice and go into the digital menu, I only get
one chanel, what the hell is with that.  If I go into the digital
filters its stereo, I am running 2.14 stereo.  Noided right now.
Thank you for your help
joebear
Re: [emax] Emax II Why is it that when you go into digital processing you only get 1
2007-06-30 by Tristan Upton
Hi Joe,
I think the problem is that the Emax 2 OS is based on the Emax OS which only
worked with mono samples. To get stereo playback in the Emax 2 you assign a
zone to stereo mode, which uses the primary and seconday voices to trigger
together as left and right sides of the stereo sample. That allows you to
process the stereo zone with the same parameters for left and right in
dynamic processing etc but in digital processing they are still treated as
separate samples. Its a little cumbersome for sample editing but there is
nothing that can be done as the OS is no longer updated. You could always
try dumping the samples out via MIDI, edit them on your computer in stereo
then dump them back into the Emax 2.
/Tristan
joechatman1122 writes:
> joebear
Re: Emax II Why is it that when you go into digital processing you only get 1
Ok that is kinda what I thought, the samples come in stereo, but go
out mono.  that is the jankiest OS ever written in the world, you
have got to be kidding me.  Hmm what are you using to edit samples?
PC compatible? something out of digidesign right, the most
impossible program to find in the world.
Triston thank you so much for your help, I am going to bed now that
I have an explanation that makes since in a world where A D D and
technology rule.
--- In emax@yahoogroups.com, "Tristan Upton" <tu@...> wrote:
> Hi Joe,
which only
assign a
trigger
you to
right in
treated as
there is
always
in stereo
> /Tristan
processing.
only get
digital
> > joebear
Hi Joe,
Back in the late 80s the Emax OS was actually not bad compared to some of
the competition. I believe the Emax 2 was rushed out to compete with the
Akai S1000 when 16 bit stereo sampling was the feature they needed to match.
But I don't think Emu put much thought into improving the user interface.
I don't use any external sample editing with the Emax 2 but it is possible
via MIDI or RS422 if you have the MAC and software. You can also use various
software on the PC that supports MIDI sample dump.
If you are wanting to do a lot of stereo sampling and editing you should
consider picking up one of the Emu Esi series. They work much better for
stereo sample editing and are dirt cheap these days.
Tristan
> technology rule.
>> Hi Joe,
> which only
> assign a
> trigger
> you to
> right in
> treated as
> there is
> always
> in stereo
>> /Tristan
> processing.
> only get
> digital
>> > joebear
