Emax
Emax II OS Disk
Emax II OS Disk
2007-07-19 by plus_321
Hello,
   I'm sure this has been ask multiple times in the past, but is there
someone here that can sell me a copy of the Emax II os on disk?  I've
tried several ways to put it on floppy myself but it hasn't worked.
First I tried to use CopyQM, but I can't boot into real DOS and have
access to the OS image at the same time so when I ran it at a command
window it would not work.  I also don't know anyone anymore that uses
Windows ME or below so aside from using a boot disk I'm not sure how
to approach this method.
Second, I tried doing a dd if=img of=/dev/floppy with the image found
in the files section and that also didn't work.
So if anyone has any suggestions I would be glad to hear them, but I
believe at this point it would be easier to just purchase a disk from
someone, preferably in America so it would arrive faster.  I could pay
with Paypal or whatever.
Thanks.
Re: [emax] Emax II OS Disk
2007-07-19 by Peter Poeml
Hi!
On 19.07.2007, at 18:39, plus_321 wrote:
> Hello,
Try writing the image to /dev/fd0u800 rather.
Sounds as if you run Linux. So you could use the following script:
http://svn.poeml.de/viewcvs/emx/trunk/tools/os.sh?view=markup&rev=41
with the file emaxos.emx from the images subdirectory:
http://svn.poeml.de/viewcvs/*checkout*/emx/trunk/images/emaxos.emx?
rev=36
There is also a script to write banks to floppy.
> Thanks.
weil, wer nicht tanzt und radfährt,
nicht als Bär infrage kommt!
