> So, no one of you all ever intended running alchemy on a
> powerbook
> via rs422 ?! ;)
> regards moe
> --- In emax@yahoogroups.com, Mike Wolak <mikewolak@...>
> wrote:
> > I've got a PowerPC 8100 running 8.1 and a 68030 Mac
> IIci
> > running 7.6.1 and both run Alchemy 3.0 perfect using
> RS422
> > Midi sample dump.
> > Just my 2 cents but i've found that although sample
> dumping
> > over rs242 is convenient, to capture the true grit of
> the
> > converters I re-sample most of the time.
> > Mike Wolak
> > Emax SE HD w / external SCSI port installed
> > --- Rei <vjrei@...> wrote:
> > > I had Motu Performer running from a powerbook once
> (ages
> > > ago). I used to use Master
> > > Track, well master tracks couldn't transmit midi via
> rs
> > > 422 port while Performe could. I
> > > assume alchemy may have the same problem, the drivers
> the
> > > software has to recognize
> > > the port may not there. But that is just me guessing.
> > > --- In emax@yahoogroups.com, "m.sislack" <m.sislack@>
> > > wrote:
> > > > Hello again together :)
> > > > After all I solved my "alchemy-problem" by using
> > > desktop macs and it is
> > > > really running great using the self-made
> rs422-cable.
> > > So the question,
> > > > why I still cannot get it running on any of my
> > > powerbooks (pb 3400c, pb
> > > > 1400cs) is getting even more mysterious.
> > > > Has anyone of you experience concerning running
> alchemy
> > > on a pb?
> > > > regards moe
