My EmaxII Repair Story with PC-Floppy Drive
2007-12-04 by Sascha
Hello everybody. This Is my very first Post here in this Group. My Name is Sascha and I'm from northern Germany. I'm owner of EmaxII Mod 2212. If you allready know all of my experiences please ignore this mail :- ) and please forgive me my sometimes defective english. After Powering the Emax some day the Display said "Please Insert Disk" and the Red LED between ENTER and Dynamic Processing light up. I wondered about the Red Light and its undocumented meaning. But now I know that it simply says, that there is not bootable OS available from Boot-Device and something is somehow wrong. After putting the EMXP-tested Floppy with OS into the Drive the Display continuously switched between "Disk not formatted" and "Insert Boot Disk" and started with continued noisy Head- Activity. Turning the Emax off and on again ... oups ... now I had two red error lights. Off - On ... Again only red light... The Red light was right. There was something wrong. So I tried to Boot from external SCSI-Zip-100. Some of you and the manual says, the EmaxII is "scanning" all SCSI ID's if Floppy is without Bootable OS. This seems not 100% correct if Boot Device is previously set to a specific ID with Master 9 function and/or the FloppyDrive is Dead. Also, with the Red Light on and a non-working Floppy-Drive you are not able to access Master 9 for Changing the Default SCSI-Devise. Tricks with Jumpers on Floppy- Connector or whatever also don't work of course. You are shut out. After hours of working, cleaning and testing with the original one there was no doubt the Drive is out of Service. I don't like to do visible handicrafts for PCMCIA, Flash or whatever. I tried to work out a Solution with a PC-Floppy-Drive for a clean and original Look of the Emax. I knew that I need a Drive with Jumpers. But I learned it is easier to win the Lottery-Jackpot than finding a known compatible Drive for less Money. A hundred Dollars for a Drive from an established "Studio"-Website in US including S/H, Import Tax plus 19% normal Tax (Germany!) . NO WAY! Don't misunderstand me, the price alone may be ok, but all together is to expensive for me. I have two hungry Kids. My Job is IT, EMAX is IT there must be another solution I thought. So I went down to the cellar, looking for any skeletons. I found several Drives but all without Jumpers and as I opened up the very last cardboard box, virtually counting the amout for a "Studio"- Drive, I found a Panasonic JU-257A604P, out of a 384DX40 PC bought 15 Years ago and gone a long time ago. Again no Jumpers. A millisecond before throwing it back into the box I saw a very little tiny switch between motor and connector with I and 0. Gotcha? It works! Here is the How-to for this Drive 1) Open up your PC and temporarily connect the Drive with ID- Switch set to 1 instead your Build-In Floppy-Drive. This is recommended, because Floppy-Read/Write-Heads can loose adjustment and so maybe a FloppyDisk build perfekt in one Drive isn't readable in another older Drive. 2) Use EMXP to build a formatted Boot Disk with OS and after this undo your PC-Mods. 3) Switch Floppy Drive from ID-1 to ID-0 and build the drive into your Emax. 4) NOTE: You can not use the original Emax-Floppy- DataCable with a PC-Floppy-Drive. Controller Damage possible. Look for a PC- Floppy-Drive Connector Cable with twisted Lines at one end. In normal Cases this Cable has 3 Connectors. 1 for PC-Motherboard and two for Floppy-Drives A and B where A is at the twisted end and B the other one in the middle of the cable. NOTE: You can not use the normal PC- Motherboard-End of this Cable, because one Pinhole (Pin 5?) in the Connector is usually Blind or Factory Closed. Don't use Brutal Force to replace the Cable inside the Emax. You need to take the two Drive- Connectors A and B. There are no Blind or Sealed Pinholes. Plug the Twisted Side Connector (A) into the new Drive and the other Connector (B) onto the Emax-Board. 5) NOTE: Before closing the Emax-Case make several tests and inspection for correct connection. Don't forget to connect the FloppyDrive-Powerline. Especially take care about Pin 1-Connections of the DataCable, a usually Red marked Line. Connect the Emax External PowerLine. Hold your Head near the Power Unit. When you turn the EMAX on and you hear a muted high Tone out of the Power Unit and the tone is getting higher and higher like a bomb seconds before explosion, something went wrong. Immediately turn the Emax off or you will kill the Power Unit. Check all connections again as explained. To see the correct Connections I used in my EmaxII look at my Pictures inside emax-Group. IF everything is mounted and connected correctly turn the Emax on. There should be no Red light on Front Panel and Floppy Drive / Display is awaiting the OS-Disk which will now boot the System without any problems including ZIP-Drive. And after this experience there should be more than only a few TEAC- Floppy-Drives for spare and you don't need Drives with tons of possible Jumper Settings. Just take a look for old 286 oder 386 .. maybe 486 PC's and I guess you will find a suitable Drive. My Panasonic Drive is quite often at ebay. I guess I will buy some more spareparts. Hopefully this story will help somebody with same problems. Of course, I do not garantie anything. If you do like I did your Risk. regards Sascha kellnssc
