Emax
Replacement LCD
Replacement LCD
2008-02-09 by alancurrall
Okay I got a replacement LCD module from RS components this is the part:
http://www.powertip.com.tw/products_2.php?product_id=1171043433&area_idbk=1170985616
Trouble is, it has 16 connections up one end instead of the 14
required. Other than that it's a perfect fit. Of course I've tried it,
ignoring the last to connections (15 and 16) and nothing happens.
Anyone got any experience in this area?
Alan
Re: [emax] Replacement LCD
2008-02-09 by ted Summers
I believe those last two connections may be for the backlight. ON the
original the extra two pins came out the other end, and are what held
up the old. Did you get an EL display? There should be some spec
information for the pinouts....
Ted
2008-02-09 by Roland S-50
Hi Alan,
I'm currently waiting on my replacement LCD, which is very similar spec to
yours.
I would expect that it's a direct replacement - after soldering on the
14-pin header of course...
Do you get anything at all?
Do you have the two-pin backlight header soldered on as well?
Are you replacing your Emax LCD because of a dead backlight?
Mike.
> Cheers,
> Alan
2008-02-09 by Alan Currall
Hi Mike,
It's a bit of a sorry tail of woe. The dim backlight didn't bother me
too much, but there was a background high pitch whine that some
people attributed to the lcd so, after buggering up the original one
by shoving bits of cardboard behind it, as advised, I thought I may
as well completely replace the module.
The one I got conforms as closely to the recommended replacement as
any I could find, but the documentation on it is all a bit
overwhelming and confusing for a novice like me.
I desoldered the original one away from the pins that connect it to
the board, leaving the pins in place. I cleaned up the pins and
plugged them straight into the aligning holes on the lcd module. I
then tried cautiously powering it up without committing to any
soldering. I get no response at all. What worries me more is that no
LED's come on either, although the floppy drive does start spinning.
Could it be that I need to bite the bullet and actually solder the
thing in place? I have wiggled the module in place while powered up
in case the contacts just aren't firm enough, but it seems to make no
difference.
Any suggestions?
Alan
On 9 Feb 2008, at 5:34PM, Roland S-50 wrote:
> Hi Alan,
> spec to
> yours.
> Cheers,
> Mike.
> the part:
> tried it,
> > Cheers,
> > Alan
Alan-
The LCD must be soldered. I don't know if the system checks whether
the LCD is displaying or not.
There are 2 kinds of LCD- EL (Electro Luminescent back light - which
takes 110V AC), and LED backlight (+5v or +12v - not sure which).
When I got mine, I got EL, but there are two rows of 8 (16 pin).
There are contacts on the other end for the backlight as well. I got
additional pins so I could put the old display back as necessary (for
test purposes). The pins were only like $2.
You would not populate pins 15 and 16, and would connect those other
two pins at the opposite end of the display for the Backlight....
However- that is assuming that you have an EL backlight. if you have
LED backlight, the high voltage could immediately blow out the LED
for the backlight, and could possible damage the main emax board.
You need to determine which kind of new display you have, then we can
go from there.
regards,
Ted
2008-02-10 by mr julian
from the OP's datasheet, pins 15 and 16 are for an LED backlight......
so, yeah.. it's an LED backlight. No need for the backlight inverter
module anymore. pull it out, too!
Just wire 5V through a resistor (start with 6R8, assuming the LED
load/current requirements are right in the datasheet) 1/2W resistor from
to the "A" connection of the backlight, and wire the "K" connection to
ground.
The Emax shouldn't worry about another 120mA, on 5V, I imagine.... (not
that I've ever tried, though!)
The LED backlight power is a pretty simple thing - has anyone checked
the data/control pins are in the right order on the old and the new module??
ted Summers wrote:
>Alan-
2008-02-11 by Alan Currall
Oh shit!
My soldering skills are even less developed than I had feared...
I've made a right hash of the back of the button board that hosts the
LCD module. Patches of scorched board and smears of useless solder
now litter the area where the 14 pins come through. I'm worried that
I may even have breached the integrity of on or two of the tracks.
I guess this is what comes of impatiently trying to do a job
inadequately equipped. Just out of (probably purely academic by now)
interest what size soldering iron tip should I have attempted this
butchery with? Also are there any recognised techniques for cleaning
up a mess looking piece of board? With any luck it may just look
worse than it actually is.
Forlornly,
Alan
> from
> ground.
> (not
> module??
> ted Summers wrote:
> >Alan-
2008-02-11 by Roland S-50
Hi Alan,
I was thinking of using and LED backlight too, but it looked like the LCD
assembly would be too thick (around 12mm as opposed to 8mm(?) for the EL
backlight-type LCD...
If it does fit in place okay please let me know.
Mike.
> ground.
> module??
> ted Summers wrote:
> >Alan-
Re: Replacement LCD
2008-02-12 by Mike
Hi Alan,
Just curious: why are you soldering on the button-board?
On my Emax, the LCD assembly comes out (the 14 pin header simply plugs
into the connector on the button-board)
Is it soldered in-place on yours?
cheers,
Mike.
--- In emax@yahoogroups.com, Alan Currall <alan@...> wrote:
> Oh shit!
> Forlornly,
> Alan
> > from
> > ground.
> > (not
> > module??
> > ted Summers wrote:
> > >Alan-
Re: [emax] Re: Replacement LCD
2008-02-12 by Alan Currall
Mike, Yeah it was soldered, and quite a fiddly bit for a novice like
me to tackle. My Emax's life now rests on finding someone skillful
enough to make good my handy work. As I couldn't even find anyone to
to replace to power supply recently, I fear the worst. Anybody out
there got a dead Emax I (rack) with a good button board?
Alan
On 12 Feb 2008, at 3:52AM, Mike wrote:
> Hi Alan,
> cheers,
> Mike.
> > Oh shit!
> the
> > Forlornly,
> > Alan
> backlight......
> inverter
> resistor
> > > from
> connection to
> > > ground.
> > > (not
> checked
> new
> > > module??
> > > ted Summers wrote:
> > > >Alan-
> whether
2008-02-12 by Roland S-50
Hi Alan,
Strange... Everything on my button board (including all the LEDs) are fitted
to 'pop-in/out' connectors, which I guess makes things easier!
Pity you are so far away from me, as I'd help you out (I'm in Melbourne,
Australia!). The button board wouldn't be a dead-loss, since it's only a
single-layer board, so any damaged tracks could be patched up pretty easily.
As for the PSU, I think (someone correct me if I'm wrong) it produces fairly
standard voltages and I've even heard of PC power supplies being hacked
about and used instead...
If I had the schematics (does anyone have the PDFs?) I'd be able to comment
a bit more on the PSU...
Mike.
> Cheers,
> Alan
> > Hi Alan,
> > cheers,
> > Mike.
> > --- In emax@yahoogroups.com <emax%40yahoogroups.com>, Alan Currall
> <alan@...> wrote:
> > > Oh shit!
> > the
> > > Forlornly,
> > > Alan
> > backlight......
> > inverter
> > resistor
> > > > from
> > connection to
> > > > ground.
> > > > (not
> > checked
> > new
> > > > module??
> > > > ted Summers wrote:
> > > > >Alan-
> > whether
Hi again Mike,
(My God what time is it in Melbourne?)
Thanks for your support. Yes, I guess it wouldn't be that difficult
for anyone with a bit more electronics experience.
I did actually manage to successfully track down and fit a power
supply and I was quite proud of my handiwork. That's what really irks
me about buggering up this solder job. If only mine had pop-in/out
connectors!
Alan
On 12 Feb 2008, at 8:43AM, Roland S-50 wrote:
> Hi Alan,
> are fitted
> Melbourne,
> only a
> pretty easily.
> produces fairly
> hacked
> comment
> Cheers,
> Mike.
> > Cheers,
> > Alan
> > > Hi Alan,
> simply plugs
> > > cheers,
> > > Mike.
> > <alan@...> wrote:
> > > > Oh shit!
> hosts
> > > the
> solder
> worried that
> tracks.
> by now)
> this
> cleaning
> > > > Forlornly,
> > > > Alan
> > > backlight......
> > > inverter
> the LED
> > > resistor
> > > > > from
> > > connection to
> > > > > ground.
> imagine....
> > > > > (not
> > > checked
> the
> > > new
> > > > > module??
> > > > > ted Summers wrote:
> > > > > >Alan-
> > > whether
Hi Alan,
Oh, it was only 6:00pm in the evening (we're 11 hours ahead of you) - it's
9:45pm now!
If you have a multimeter you could use it to check the track and if any of
them are damaged and you don't fancy bridging the tracks, you can always
solder thin wires between the components at each 'end of the broken tracks -
if you get what I mean?
I'm no soldering whizz, but I'd be pretty confident that yor button board
would be a pretty simple fix.
alternatively you could go along to maplins or another electronics shop and
see if they can point you in the direction of someone who could get your
board working again.
Mike.
>   Hi again Mike,
> connectors!
> Cheers,
> Alan
> > Hi Alan,
> > are fitted
> > Melbourne,
> > only a
> > pretty easily.
> > produces fairly
> > hacked
> > comment
> > Cheers,
> > Mike.
> > On 12/02/2008, Alan Currall <alan@...<alan%40wanlockhead.demon.co.uk>>
> > > Cheers,
> > > Alan
> > > > Hi Alan,
> > simply plugs
> > > > cheers,
> > > > Mike.
> > > > --- In emax@yahoogroups.com <emax%40yahoogroups.com><emax%40yahoogroups.com>, Alan Currall
> > > <alan@...> wrote:
> > > > > Oh shit!
> > hosts
> > > > the
> > solder
> > worried that
> > tracks.
> > by now)
> > this
> > cleaning
> > > > > Forlornly,
> > > > > Alan
> > > > backlight......
> > > > inverter
> > the LED
> > > > resistor
> > > > > > from
> > > > connection to
> > > > > > ground.
> > imagine....
> > > > > > (not
> > > > checked
> > the
> > > > new
> > > > > > module??
> > > > > > ted Summers wrote:
> > > > > > >Alan-
> > > > whether
