I partitioned and formatted the drive, it shows in windows explorer
and emxp recognises it now, but emxp says the disk is too
small...???
I used winhex to write the data from a .em2 file to the hd and I
still get "not emax II drive"...
I guess it's time for ebay. Thanks for your help esythesis(emax
guru).
--- In emax@yahoogroups.com, "esynthesist" <esynthesist@...> wrote:
> Is the drive listed in Windows Explorer ?
> E.g. as a drive G or H or whatever... If so, do you mean that EMXP
> gives an error when entering this driveletter ?
> But if it is not listed in Windows Explorer, I don't know what you
> should do... EMXP at least requires that Windows sees a drive.
Until
> now I only worked with removable drives, which means there's
always a
> drive letter assigned but not necessarily a disk in the drive.
> But if the HD is fixed and not formatted for windows, perhaps
Windows
> doesn't see the drive and doesn't assign a drive letter to it
(while
> MacDisk recognizes it via the scsi bus scan...).
> By the way: I assume you have a scsi driver on Windows installed :-
> If you find another way of writing "raw data" directly to a
harddisk,
> you can try it, e.g. maybe on a mac computer. EMXP is not really
> required to write the image to the disk, any "raw writing" utility
> can do it, also on mac. Unfortunately I don't know such tools for
mac.
> ///E-Synthesist
> --- In emax@yahoogroups.com, "gadgetfiddler" <gadgetfiddler@>
> wrote:
> > I've created an image with emxp but emxp says it can't find my
scsi
> > drive. I can access the drive using macdisk, but I don't see it
in
> > windows explorer... what am I missing?
> > --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote:
> > > I'm not sure if I understand your problem...
> > > If you want an empty image you can create one from scratch
with
> > EMXP -
> > > you don't need an existing working Emax drive for that.
> > > In EMXP just go to
> > > 1. Manage Emu EMAX/EMAXII Images and Disks
> > > 3. Manage Emax HD/CD Images
> > > 3. Create new (blank) Emax-II HD/CD Image
> > > Once you've created the image this way, you can "burn" it to
your
> > 2GB
> > > drive using:
> > > 1. Manage existing Emax HD/CD Images
> > > <select the image you just created><press enter>
> > > 3. Restore Emax HD/CD Image to removable HD
> > > If you want, you can also add an operating system (see files
> > section
> > > or emulatorarchive) to the image before writing it to your HD.
> > That
> > > makes the drive bootable...
> > > Hope this helps.
> > > ///E-Synthesist
> > > wrote:
> > > > I was trying the 2gb hd because my quantum prodrive lps(1992-
> > 2008,
> > > > rip) is now deceased. I don't have any hd back-ups on my pc
or
> a
> > > cd.
> > > > Does someone from the Emax group have enough freetime to
upload
> > an
> > > > empty hd image to my xdrive?
wrote:
> > > > > It might be impossible to do that because 2GB drives are
post-
> > > Emax
> > > > area.
> > > > > But here's just an idea, you never know:
> > > > > Have you tried to create an empty Emax-II Hard disk image
> with
> > > > EMXP
> > > > > (either 96, 239 or 632 MB) and then restore this image to
> your
> > > 2GB
> > > > hard
> > > > > disk using your PC ?
> > > > > The hard disk images created by EMXP are "logically
formatted
> > > EMAX-
> > > > II-
> > > > > ready partitions".
> > > > > It probably won't work but you never know, maybe the Emax-
II
> > will
> > > > > accept the disk with this image on it...
> > > > > ///E-Synthesist
<gadgetfiddler@>
> > > > wrote:
> > > > > > Is there a way to partition a 2gb hd so that emax II
with
> > > format
> > > > only
> > > > > > 540mb or so? I don't mind wasting the unused harddrive
> > space,
> > > it
> > > > > would
> > > > > > be well worth it considering it's easier to find a 2gb
hd
> > for
> > > $5
> > > > than
> > > > > a
> > > > > > 540mb hd for $20.
> > > > > > I've made a 200mb partition with macdisk but emax still
> > formats
> > > > for
> > > > > > 15min and then gives a hw error.
> > > > > > Any ideas, anyone?
