Emax
Help need to upgrade my Emax to Emax SE.......
2008-04-07 by karlscott2301
Hello All
Been reading on the site that some of you have managed to upgrade your OS for the Emax 1
to Emax 1 SE, (mine is original version with OS 3.2 & No HD) i was wondering if anyone
would be able to make the 2 disks for me  and i could pay someone thru paypal...
I do realise that all the needed files and software are in the "files" section I am on a Mac and
have no means of getting hold of an old DOS PC.
The main reason i wanna upgrade is so i can get to use the "Stack" function so i can stack my
presets.
I would be most thankful if someone you could get back to asap as i would like to get my
Emax 1 upgraded to SE as soon as possible..
thanks in advance, Karl....
Hello All
to Emax 1 SE, (mine is original version with No HD) i was wondering if anyone  would be able
I do realise that all the needed files and software are in the "files" section I am on a mac and
presets.
I would be thankful if someone you could get back to asap as i would like to get my Emax 1
Re: Help need to upgrade my Emax to Emax SE.......
2008-04-07 by hvr128
Hello,Karl,
I've got also an emax 1,the SE software is very easy to install,u
just ve to do a 3.5 DSDD disk with the Se Os,after it's charging thru
the emax ,u can ve the SE in u're Emaw as well!
So,please give me u're adress,u just need one dsdd 3.5,not 2 disk!!
i leave in france:Auvergne !!
so??
A bientot et keep the control!!
regards
rv
--- In emax@yahoogroups.com, "karlscott2301" <karlscott2301@...>
wrote:
> Hello All
> presets.
2008-04-18 by Niklas Noren
Well, the OS is located on each disk, there is no OS in the Emax, if
you understand what I mean.
I'm not sure, but I think there is difference between hard ware.
Otherwise you can download the OS from here, just look under files.
You need of course the EMXP program to convert the OS from your
computer to Emax.
You copy the OS to each disk under "Master" on the Emax.
cheers/
niklas
wrote:
> Hello All
> presets.
