Emax
Emax se hd boots to Diagnostics mode
2008-04-24 by Kevin Kelley
When I boot my newly aquired emax SE HD it immediatly goes into
Diagnostics mode witht he bottom two lights lit. Has anyone had this
occur to them also? Neither the hard drive or the floppy appears to
spin up before the system locks up.
Kevin Kelley
Re: [emax] Emax se hd boots to Diagnostics mode
2008-04-24 by Ted Summers
The floppy isn't working right. This will happen if a PC floppy is
hooked up (I know this is a possible cause for sure - Drive select is
set to 1 not 0) or a bad floppy drive.
Ted
Re: Emax se hd boots to Diagnostics mode
2008-04-25 by bass_krazy
is
> Regards,
> Ted
If this is the case and the HD is good you should be able to disconnect
the floppy and use the jumper cheat to make it boot by thinking it sees
a functional floppy.
Re: [emax] Re: Emax se hd boots to Diagnostics mode
2008-04-25 by nung242
Hi Ted,
 Do you have any ideas about that error message I spoke of? I have an EMAX II with o/s 2.14     When ever I try to format a floppy, format a SCSI drive or run BIRD RUN it flashes - "DIFFERENT SOFTWARE REV!"     Thanks!
Only Had this baby 1 week, still learning it but its a beauty.
bass_krazy <bass_krazy@...> wrote:                             --- In emax@yahoogroups.com, Ted Summers <djtbs1@...> wrote:
 is
 > Regards,
 > Ted
Be a better friend, newshound, and know-it-all with Yahoo! Mobile.  Try it now.
2008-04-25 by Ted Summers
I only have an Emax 1, but I know about the lights because I have
been working on addind Compact Flash in conjunction with a Laptop
Floppy drive. I had it working, then I did something to make it not
work again, so I am trying to figure out what I changed.... doh!
When the floppy works as a regular PC floppy, you get the two lights.
when you have a emax compatible floppy hooked up, you get only the
one light that is expected.
Ted
2008-06-16 by Kevin Kelley
I have removed both drive connections and when I boot the emax it
still prompts Diagnostic mode immediatley at boot time. Does anyone
have any advice on what might be causing this? My emax is a emax se hd.
Kevin Kelley
