Emax
Emax I/II VFD Display?
2008-06-14 by plus_321
Hello,
   Came across this today.
http://matrixsynth.blogspot.com/2007/04/sequential-circuits-studio-440-with.html
(Studio 440 simply modded to have a VFD rather than LCD).
VFD supplier: http://www.noritake-elec.com/tversion.htm
Anyone ever try this with an Emax I or II?  This would be amazing if
it could work.
Re: Emax I/II VFD Display?
2008-06-15 by Rei
It looks realy good, the only concern as far as I know would be voltage. Just find out about
the aspects of the original Emax LCD and compare it.
Now, personally I would use the same blue backlight the Emax has to keep it original, but
that is just me.
--- In emax@yahoogroups.com, "plus_321" <plus_321@...> wrote:
> Hello,
> it could work.
Re: [emax] Emax I/II VFD Display?
2008-06-15 by Ted Summers
you would not connect the high voltage for the inverter and instead
run a line from +5v for the backlight, just like if you were going to
use an LCD like in Emax II. I bought spares that are exact duplicate
EL backlight that literally plugged in to my Emax I, once I put the
pins on.
There is a 1MM differential in one dimension, and 8MM longer, but it
would depend on the hole placement whether that would have any actual
mounting issue.
That is looking at CU16025ECPB-W2J. You would have to have the N01
connector.
If the mounting is not an issue, then it could certainly work..
Regards.
Ted
