can you upload an audio file of the recorded sequence played from the
emax? (by the way, for the sequence recordings I'm using an original
emax HD model 1010, upgraded to SE too (board PC333 rev C). I'm going
to try the SE model 1000 now (board 237 rev 2 C), to see if there are
some difference.
I should try the cubase vst, but i can't find old versions of cubase.
chip!
--- In emax@yahoogroups.com, "Lyn Oakey" <lynoakey@...> wrote:
> OK, I've just had a test play from the PC using Cubase VST
> (SX does not support Midi Clock In, VST does)
> With Cubase acting as both Master and Slave I didn't hear any
sequence timing errors.
> Using the basic Rap Drums preset, I sent a couple of drum sequences
with 16t hats
> and a couple of 32'nd snare fills at 96 and 130 bpm.
> I also made sure the notelengths were quantised so as not to
overlap into one another.
> Could this have possibly contributed to your timing issues ?
> I used a Steinberg Midex 8 midi interface and the Emax is HD Plus
with SCSI.
> Being one of the later ones, it may have been improved in this
area, who knows ?
> regards
> Lyn
> From: Tristan
> To: Lyn Oakey
> Sent: Sunday, May 11, 2008 7:24 AM
> Subject: Re[2]: [emax] Re: EMXP, best software EVER?
> Hi Lyn,
> I suspect the Emax sequencer may actually only be 24 ppqn, the
same as
> MIDI clock. That is fine if everything is tightly on the beat,
but one
> clock of error puts your events off by ~21mS at 120 BPM. You
might get
> away with that for strings but for drums etc its way off. Its a
real
> shame Emu never included a quantise feature.
> Regards,
> Tristan
> Saturday, May 10, 2008, 9:50:11 PM, you wrote:
> One reason why you're having timing problems could be your host
sequencers ppqn
> is too fast for the Emax to interpret accurately.
> I would imagine the Emax seq is running at 96 ppqn, as were most
back then.
> Now a modern-day seq, like Cubase SX, will be running at
something like 3840 ppqn.
> So, if any patterns are not hard-quantised, the Emax won't be
able to capture the feel -
> no matter how you record.
> just a thought
> Lyn
> From: Chip
> To: emax@yahoogroups.com
> Sent: Saturday, May 10, 2008 12:14 PM
> Subject: [emax] Re: EMXP, best software EVER?
> The problem isn't real time sequencing from seq/pc to emax. When
> your're downloading or playing sequences from seq/pc all sounds
good
> (I use mp401 port), but the problem comes when you record them to
> emax sequencer, and play it from there (it's not play-timming
> problem, because the notes that sounds out-of-time are always in
> same place. I've tried to record track by track, all track
together,
> at slows tempo, at normal tempo, with the emax in slave, with no
> tempo reference, and even with the emax set at faster tempos than
> sequence (for having more resolution in tpq).
> I'm going to record a sequence that I use in live performances to
> show you these timing problems (there are small but perceptive
for
> the musician ear)
> chip.
> --- In emax@yahoogroups.com, "gadgetfiddler" <gadgetfiddler@>
> wrote:
> > isn't it possible to route all of your midi hardware through a
> > computer and then adjust timing offsets with software... isn't
that
> a
> > lot easier? i don't understand how copying sequences to an emax
> could
> > resolve any issues, if timing is off and you trigger a sequence
it
> > would still be offtime. am i missing something?
> > I don't know if you're refering to usb synths/samplers or
computer
> > usb, but if it's computer usb i'd suggest using your soundcard
> > instead. i've never had any timing issues playing my emax along
> with
> > other samplers via midi from sequencer software routed through
an
> > mpu401 compatible soundcard. any typical soundcard found in a
> trashed
> > computer is suitable... and free.
> > --- In emax@yahoogroups.com, "Chip" <xtr909x@> wrote:
> > > that's exactly what i mean tristan!!!
> > > the conversion from standard midi to emax would be a great
tool.
> > (we
> > > only need note on/off, velocity, mod/pitch wheel, midi
channels
> and
> > > tempo information)
> > > OK it's a scratch seq, but it could be very very very useful
for
> > live
> > > performances. (like factory -well quantized- sequences)
> > > tnx for your answers!
> > > chip
> > > --- In emax@yahoogroups.com, "Tristan Upton" <tu@> wrote:
> > > > Transferring sequences between EII, EIII and Emax is not so
> > useful.
> > > > It would be great to be able to convert Emax sequences
to/from
> > > standard MIDI
> > > > files. Then you could take sequences from a computer
sequencer
> > and
> > > load them
> > > > into the Emax with precise timing. Playing in via MIDI is
> > > problematic given
> > > > the less than stable timing most USB MIDI interfaces
provide.
> > Using
> > > the
> > > > external clock input to drive the Emax sequencer should
allow
> > much
> > > tighter
> > > > playback timing than is possible via MIDI.
> > > > Are you able to share the documentation on the Emax
sequencer
> > > format? There
> > > > is virtually no documentation in Emax the manual on the
timing
> > > resolution
> > > > and what messages are supported by the sequencer.
> > > > Thanks,
> > > > Tristan
> > > > esynthesist writes:
> > > > > Hi Chip
> > > > > After moving to another house I'm online again :-)
> > > > > But my whole studio/lab is to be built completely from
> scratch
> > > again,
> > > > > except for the machines themselves...
> > > > > So I'm "out of Emu business" for at least another few
weeks.
> > > > > Anyway, thx for appreciating the EMXP tool.
> > > > > But what exactly do you mean by "managing sequences".
> > > > > Do you want EMXP to be able to convert sequences between
> > > different
> > > > > samplers ? E.g. translating EMUII sequences to EMAX ?
> > > > > That was not on my priority list because I thought no one
was
> > > really
> > > > > using the builtin sequencers of these Emu machines (due
to
> > > scratchpad
> > > > > restrictions).
> > > > > I already have the specs of the EMAX/EMAXII sequences,
but
> not
> > > yet of
> > > > > the other samplers (EIII, EII). So that feature would
take
> > quite
> > > some
> > > > > time... Especially with the EIII sequences, because the
EIII
> > > > > sequencer is much more advanced than the other vintage
EMU
> > > samplers.
> > > > > Can you clarify your request ?
> > > > > ///E-Synthesist
> > > > >> This post is only to be thankful of EMXP. This soft
makes me
> > > love
> > > > > my
> > > > >> Emax even more.
> > > > >> I only have 1 question/suggestion for E-Synthesist:
> > > > >> Would be possible to add to empx the ability of manage
> > sequences
> > > in
> > > > >> Emax banks?, and/or make a conversion to midi?.
> > > > >> If some day EMPX can do that, I never going to buy any
new
> > > hardware
> > > > >> anymore.
> > > > >> cheers!
> > > > >> Chip
