Arpeggiator and Thru/Out confusion
2001-12-10 by sp99z
Im having some confusion/difficulty with the triggering other devices through the EmaxII and with the arpeggiator. I have keyboard (as controller) > hooked up to Emax II (rack) > then hooked up to another MIDI sound module. Having all three devices set to the same MIDI channel, I can play/trigger the module from the keyboard like normal when I have the Emax MIDI set to "Thru" (instead of "Out"), and when set to "Out" I can use the arpeggiator to trigger the sound module (this is what I want to do), but I cant play the module at all with the arpeggiator turned off (and the Emax MIDI still set to "Out") for some reason. I want to be able to use the arpeggiator to trigger other modules/things but I need it to be able to still send trigger signals to them whether the arpeggiator is on or off. Seems like it should be able to do this.. Im not sure what the problem is, any ideas? Thanks
