Emax
Problem with Scanner MPU?
2008-06-20 by markolaukka
Hello All,
Recently I bought a defected Emax rack.
It loads the disc but after that it hangs, and it won't respond to any
of the frontpanel buttons, i.e. nothing more happens.
Now, I have the tehcnial manual and it says that if the instrument load
the software but nothing more happens it's the scanner CPU/MPU that are
broken and needs to be replaced. As far as the manual say it's an
Rockwell 6500/11 microcontroller. Does anyone knows where I can find
one of these microcontrollers? I've been searching the net all day
without any result.
Any help would be much appreciated!
Thanks in advance
Re: Problem with Scanner MPU?
2008-06-20 by Rei
I would get another rack and canibalize it, is faster and cheaper. I just got an Emax II
keyboard and that is what I am planing to do for parts.
--- In emax@yahoogroups.com, "markolaukka" <markolaukka@...> wrote:
> Hello All,
> without any result.
> Thanks in advance
Re: [emax] Re: Problem with Scanner MPU?
2008-06-21 by Ted Summers
When you say it loads the disk and just hangs there. what exactly
happens.
Sequence of evemts- what leds come on on the panel and do they stay
on or change?
What shows in LCD? Does it say diagnostics, then loading software or
only diagnostics. These are all important because there may be other
explanation.
Regards.
Ted
2008-06-21 by Marko Laukka
Hello Ted,
It turns on normal and ask for 'Insert disk!'. If I load the OS3.2 disk that came with Emax, it loads it and gives error message: 'CRC error', and hangs. If  I put one of my own disks (OS1.1 HD) it loads and says: 'wait a moment' loads the disk and display the loaded bank/preset and then hangs, i.e. it doesn't matter which buttons I press, nothing happens. The 'Enter' led lights up as normal but no other leds (except for 'Analog processing'-led at beginning) or any sequences of leds turns on. So I don't get any hint from some diagnostic check at start up.
The technical manual says; Problem: 'Software loads and then display goes blank', Solution: 'Change bad scanner MPU'.
But in my case the display keep showing the loaded sound/preset and the whole front panel is locked/don't respond to any button pushes. The only led that stays on is the 'Enter' led.
Thanks in advance,
Marko
--- Den lör 2008-06-21 skrev Ted Summers <djtbs1@...m>:
Från: Ted Summers <djtbs1@...>
Ämne: Re: [emax] Re: Problem with Scanner MPU?
Till: emax@yahoogroups.com
Datum: lördag 21 juni 2008 02.18
happens.
on or change?
explanation.
Regards.
Ted
      __________________________________________________________
Går det långsamt? Skaffa dig en snabbare bredbandsuppkoppling.
Sök och jämför hos Yahoo! Shopping.
http://shopping.yahoo.se/c-100015813-bredband.html?partnerId=96914325
SV: [emax] Re: Problem with Scanner MPU?
I don't like to do that (not yet anyway) because it's in very good condition otherwise, and I feel it's worth a try to make it work.
--- Den fre 2008-06-20 skrev Rei <vjrei@...>:
Från: Rei <vjrei@...>
Ämne: [emax] Re: Problem with Scanner MPU?
Datum: fredag 20 juni 2008 22.51
--- In emax@yahoogroups. com, "markolaukka" <markolaukka@ ...> wrote:
> Hello All,
> without any result.
> Thanks in advance
Re: SV: [emax] Re: Problem with Scanner MPU?
2008-06-21 by Tristan
Hi Marko,
The problem you have here is that the 6500/11 scanner MPU in your Emax
has been mask programmed at the factory. Unless you can find a spare
chip with the correct Emu software in the ROM then you are out of
luck. I expect Emu did a bulk order of these back in the day but they
are now long obsolete. I believe the same chip was used in the EIII,
Emax and Emax II. If identical software was used on the scanner chip
for all these samplers then it is likely that some Emu service agents
may still have spares.
The first thing you should determine though is whether the 6500/11 is
actually the problem. The fault could just be an oxidised chip socket
or something else entirely. Either getting another working Emax or
getting together with someone who has one would be the simplest
solution. Then you can swap the chips between the two machines and see
if that fixes the problem. You would be better off trying your 6500/11
in the working Emax just in case your Emax is doing something that
killed your chip.
If you are not confident with diagnosing and repairing electronic
equipment then it would be better to get a tech to do it for you. And
always observe static safety, for every dead 6500/11 another Emax dies
Best regards,
Tristan
Saturday, June 21, 2008, 4:28:05 PM, you wrote:
ML> I don't like to do that (not yet anyway) because it's in very
ML> good condition otherwise, and I feel it's worth a try to make it work.
ML> --- Den fre 2008-06-20 skrev Rei <vjrei@...>:
ML> Fr�n: Rei <vjrei@...>
ML> �mne: [emax] Re: Problem with Scanner MPU?
ML> Till: emax@yahoogroups.com
ML> Datum: fredag 20 juni 2008 22.51
ML> I would get another rack and canibalize it, is faster and cheaper. I just got an Emax II
ML> keyboard and that is what I am planing to do for parts.
ML> --- In emax@yahoogroups. com, "markolaukka" <markolaukka@ ...> wrote:
>> Hello All,
>> without any result.
>> Thanks in advance
ML> __________________________________________________________
ML> G�r det l�ngsamt? Skaffa dig en snabbare bredbandsuppkoppling.
ML> S�k och j�mf�r hos Yahoo! Shopping.
ML> http://shopping.yahoo.se/c-100015813-bredband.html?partnerId=96914325
ML> [Non-text portions of this message have been removed]
ML>
2008-06-21 by esynthesist
Does this problem occur with all of your disks ?
Because sometimes if there's a defective soundbank or OS on the
floppy disk, it can cause the Emax immediately to "crash".
Have you tried with a floppy *only* containing the OS, but no bank ?
As far as I remember you should also use the appropriate OS, e.g. no
OS for HD versions if you don't have a HD Emax...
Of course there's only a small chance that the above is the actual
cause of your problem, but you never know: the above problem would be
much easier to solve than trying to find spare parts...
///E-Synthesist
--- In emax@yahoogroups.com, Marko Laukka <markolaukka@...> wrote:
> Hello Ted,
> Â
> Thanks in advance,
> Marko
> --- Den lör 2008-06-21 skrev Ted Summers <djtbs1@...>:
> happens.
> on or change?
or
other
> explanation.
> Regards.
> Ted
partnerId=96914325
Thanks for your answer Tristan,
I do have another Emax rack working. So I guess I have to test it with that one.
Hopefully it's something else than the Scanner MPU itself. I'll try what you suggested.
Marko
--- Den lör 2008-06-21 skrev Tristan <tu@...>:
Från: Tristan <tu@...>
Ämne: Re: SV: [emax] Re: Problem with Scanner MPU?
Datum: lördag 21 juni 2008 11.09
Hi Marko,
killed your chip.
Best regards,
Tristan
ML> --- Den fre 2008-06-20 skrev Rei <vjrei@yahoo. com>:
ML> Från: Rei <vjrei@yahoo. com>
ML> Ämne: [emax] Re: Problem with Scanner MPU?
ML> Till: emax@yahoogroups. com
>> Hello All,
>> without any result.
>> Thanks in advance
ML> ____________ _________ _________ _________ _________ _________ _
ML> Går det långsamt? Skaffa dig en snabbare bredbandsuppkopplin g.
ML> Sök och jämför hos Yahoo! Shopping.
ML> http://shopping. yahoo.se/ c-100015813- bredband. html?partnerId= 96914325
ML>
Ta semester! - sök efter resor hos Yahoo! Shopping.
Jämför pris på flygbiljetter och hotellrum här:
http://shopping.yahoo.se/c-169901-resor-biljetter.html?partnerId=96914052
Hello esynthesist,
Yes I have tried different disks, and it's all the same.
When I use the OS3.2 disk it says 'CRC error' which means (I think) 'Cyclic Redundancy Check'. A way to check that data was received correctly.
But that message does not occur with the other disks, not with HD version anyway.
Marko
--- Den lör 2008-06-21 skrev esynthesist <esynthesist@...>:
Från: esynthesist <esynthesist@...>
Datum: lördag 21 juni 2008 17.54
///E-Synthesist
--- In emax@yahoogroups. com, Marko Laukka <markolaukka@ ...> wrote:
> Hello Ted,
other leds (except for 'Analog processing'- led at beginning) or any
> Â
> Thanks in advance,
> Marko
> --- Den lör 2008-06-21 skrev Ted Summers <djtbs1@...> :
> happens.
> on or change?
or
other
> explanation.
> Regards.
> Ted
partnerId=96914325
Låna pengar utan säkerhet. Jämför vilkor online hos Yahoo!
http://shopping.yahoo.se/c-100390123-lan-utan-sakerhet.html?partnerId=96915014
Ok, so it most probably is a hardware error like you assumed.
I just booted my Emax SE with the SE HD OS and it works perfectly.
Booting it with HD 1.1 OS does not work but then again it also
doesn't load the bank so this is not the same problem as you
encounter.
Good luck.
///E-Synthesist
> Hello esynthesist,
received correctly.
version anyway.
> Â
> Marko
no
be
> ///E-Synthesist
> > Hello Ted,
OS3.2
loads
any
and
> > Thanks in advance,
> > Marko
> > --- Den lör 2008-06-21 skrev Ted Summers <djtbs1@> :
> > Från: Ted Summers <djtbs1@>
> > happens.
stay
> > on or change?
> or
> other
> > explanation.
> > Regards.
> > Ted
> partnerId=96914325
partnerId=96915014
