Emax
'DIAGNOSTICS' displayed before boot-up...
2008-06-27 by leonsocoldfreeze
Good day, people.  I believe this is my first post here.  Getting down
to brass tacks...I recently purchased a Baldwin IKE.  The boot disk it
came with did not work, but I was able to successfully boot-up with the
OS from my Emax SE rack.  However, when I power the unit up it
displays 'DIAGNOSTICS' for roughly 5 seconds before initiating the OS
boot-up.
I was just curious if this was an indication of a technical problem
with the unit..if it is a 'user servicable' issue and/or generally
speaking if this is something I should be worried about.  I've tested
most of the functions I am familiar with and apparently have no
problems otherwise.  A brief rundown of why this message appears before
boot-up would be greatly appreciated.  Thank you.
Re: 'DIAGNOSTICS' displayed before boot-up...
Simple enough.  Guess I won't sweat it.  Thank you for the prompt reply.
--- In emax@yahoogroups.com, Ted Summers <djtbs1@...> wrote:
> MIne does that too.. No problems that I know of here....
> Regards,
> Ted
