multi mode /super mode?
2008-07-10 by asrvegas
Hi, HOw do I use my emax in a multi mode? Is there a way to have preset 1 on midi chanel 1 etc...? Im using cubase with it
2008-07-10 by Chase Smith
You must create tracks in the sequencer by recording a small amount for each track you wish to use. Under the sequencer options is a track status (or similar) option to set each mode to play or record. After you have set up the number of parts that you need (by setting a track's status to record and recording a second of nothing), then set them to play and you can assign presets for each of the parts. There are 16 available tracks that correspond to 16 midi channels. Also super mode must be on. --- asrvegas <asrvegas@...> wrote:
> Hi, > > HOw do I use my emax in a multi mode? > Is there a way to have preset 1 on midi chanel 1 > etc...? > Im using cubase with it > >
2008-07-14 by asrvegas
wow that sounds like a pain to use. im not using the sequencer on the emax. isnt there an easier way to do this? -- In emax@yahoogroups.com, Chase Smith <plus_321@...> wrote:
> > You must create tracks in the sequencer by recording a > small amount for each track you wish to use. > > Under the sequencer options is a track status (or > similar) option to set each mode to play or record. > After you have set up the number of parts that you > need (by setting a track's status to record and > recording a second of nothing), then set them to play > and you can assign presets for each of the parts. > There are 16 available tracks that correspond to 16 > midi channels. > > Also super mode must be on. > > > --- asrvegas <asrvegas@...> wrote: > > > Hi, > > > > HOw do I use my emax in a multi mode? > > Is there a way to have preset 1 on midi chanel 1 > > etc...? > > Im using cubase with it > > > > >
2008-07-15 by KW
it is easy as hell to do it, you just have to set every 16 track on rec and then hit "rec" press stop directly after and go throug all 16 tracks and set patch number and channel for each track, done! don't remember exacly how i made this in the early 90's but once you've got use to it it is easy as .....yes hell ;=) yes this is the only way you can get the emax to respond multitimbral to all 16 ch
/k
--- Den mån 2008-07-14 skrev asrvegas <asrvegas@...>:
Från: asrvegas <asrvegas@...>
Ämne: [emax] Re: multi mode /super mode?
Till: emax@yahoogroups.com
Datum: måndag 14 juli 2008 21.55
> midi channels.
> --- asrvegas <asrvegas@.. .> wrote:
> > Hi,
> > etc...?
__________________________________________________________
Låna pengar utan säkerhet. Jämför vilkor online hos Kelkoo.
http://www.kelkoo.se/c-100390123-lan-utan-sakerhet.html?partnerId=96915014
[Non-text portions of this message have been removed]2009-10-15 by Michael Wisbech
RE: " .... and go throug all 16 tracks and set patch number for each track,.... " you can use your Sequezers Abilitiy to send Program Changes. Then you do not need to set The Channel -> Patch manually. and remember; you can save your Supermode Seq on the Disk. and then load this Seq on the emax. From disk. :) At 15-07-2008 12:17, you wrote:
>it is easy as hell to do it, you just have to set every 16 track on rec >and then hit "rec" press stop directly after and go throug all 16 tracks >and set patch number and channel for each track, done! don't remember >exacly how i made this in the early 90's but once you've got use to it it >is easy as .....yes hell ;=) yes this is the only way you can get the emax >to respond multitimbral to all 16 ch > >/k > >--- Den mÃ¥n 2008-07-14 skrev asrvegas ><<mailto:asrvegas%40yahoo.com>asrvegas@...>: > >FrÃ¥n: asrvegas <<mailto:asrvegas%40yahoo.com>asrvegas@...> >Ãmne: [emax] Re: multi mode /super mode? >Till: <mailto:emax%40yahoogroups.com>emax@yahoogroups.com >Datum: mÃ¥ndag 14 juli 2008 21.55 > >wow that sounds like a pain to use. im not using the sequencer on the >emax. isnt there an easier way to do this? > >-- In emax@yahoogroups. com, Chase Smith <plus_321@.. .> wrote: > > > > You must create tracks in the sequencer by recording a > > small amount for each track you wish to use. > > > > Under the sequencer options is a track status (or > > similar) option to set each mode to play or record. > > After you have set up the number of parts that you > > need (by setting a track's status to record and > > recording a second of nothing), then set them to play > > and you can assign presets for each of the parts. > > There are 16 available tracks that correspond to 16 > > midi channels. > > > > Also super mode must be on. > > > > > > --- asrvegas <asrvegas@.. .> wrote: > > > > > Hi, > > > > > > HOw do I use my emax in a multi mode? > > > Is there a way to have preset 1 on midi chanel 1 > > > etc...? > > > Im using cubase with it > > > > > > > >
