I know when I download serially into my old Mac in Alchemy it loads
the whole bank, but I can see it doing each preset, etc separately.
So this would not be the mass load / unload as you have described.
I also looked at the sysex implementation guide.
It doesn't indicate the load bank function except from floppy.
It would be nice like John said to be able to get OS source to redo
the code.
But I think Rob at Emu Archive already tried to negotiate for that to
no avail.
Ted
On Oct 29, 2008, at 1:54 PM, esynthesist wrote:
For my project I assume that the Emax indeed has no bulk load/unload
command. But that's not necessarily a problem because it has a SYSEX
implementation which covers (almost) all parameters available in a
bank. So it is possible to use a set of these commands to simulate
the load/unload of a full bank. The only question will be whether the
large amount of SYSEX instructions will be acceptable from an end-to-
end response time point of view... That's subject of the experiment :-
It's interesting though to think about how the CDS3 cdrom drive
communicated with the Emax. If the Emax behaves like the Emulator II,
i.e. if the Emax acts as a slave of the device connected to the
serial port, then they must have encountered exactly the same
problem: either the computer in the cdrom drive could send a bulk
load command to the Emax (which means that the Emax OS is equipped
with this command), or it had to send individual SYSEX commands.
But if the Emax OS contains logic which can operate the CDROM drive
as a slave device (the opposite), then the Emax may have instructed
the CDROM drive in the same way as it did through SCSI.
As far as I know the CDS3 drives had a computer onboard so that they
could instruct the Emulator II to execute commands. In fact these
drives can be considered to be "very small computers including a
cdrom drive" fitted in a handy box with numeric keyboard and running
a small operating system in order to communicate with the num
keyboard, the Emulator and the cdrom drive.
Are these the very same drives that also could be used on the Emax ?
///E-Synthesist
--- In emax@yahoogroups.com, John Silveria II <john@...> wrote:
> Yes, the Universe of Sounds collection (I believe that was the name
more
> info on my website) came with a CD-Rom drive that used the RS-422
port.
> But that's not the same as having the Emax execute a receive/send
bulk
> dump command via Sysex through the port. Once again I stress this
is if
> understand all that I've read and been told over the last 20 years.
> tu@... wrote:
> > Didn't the Emax originally use the RS422 port to load banks from
a (pre SCSI) CDROM drive?
> > /Tristan
> > Wednesday, October 29, 2008, 11:54:39 AM, you wrote:
> > I am certainly no expert in this field but I remember a guy an E-
mu
> > telling me the Emax and Emax II were missing a key bit of Sysex,
> > primarily they never assigned a string for sending/receiving full
banks.
> > That is why no software ever implemented that function. If only
they
> > would release the code for the Emax OS so someone could update it.
> > esynthesist wrote:
> >> EMXP, I could add some features which are not available in any
Mac
> >> software. E.g. sending/receiving full banks at once.
> Yahoo! Messenger: EmaxJS
> The Silveria Family Website and Emax and Emax II User's Group
> http://www.silveriafamily.com
