As long as the E-chip isn't dead it should be fixable.
Any other IC's can be found and it could be fixed.
If overseas, I believe Jammie (here on the group) possibly could look at it.
If in US, you could send the board to Synth service centers mentioned in
previous posts...I believe there is one in LA?
Lastly, you could send it to me.
Ted
On Wed, Jan 7, 2009 at 9:32 AM, amigauser24 <amigauser24@...> wrote:
> Hello again everyone..
> I have an emax keyboard that has stopped working after the sync input cable
> shorted out on
> a metal case. I have read previous posts about this same issue from someone
> else and would
> like to know if there has been a fix or solution.
> Currently the screen displays two black bars and all the leds are lit. I
> tried to replace the
> fuses with no luck.
> Thanks!
