Problems with ZIP drive in Emax HD SE
2009-07-05 by bermudaben2006
Hi all, I have been trying to use an internal 100 MB Zip drive with my Emax HD SE for for quite some time now, but I still don't succeed. As I am getting increasingly frustrated, I would be very grateful if someone could assist me. This is what I have done so far: - removed internal HD - replaced internal floppy drive with slim floppy drive using a floppy drive converter from Ted Summers - fitted 100 MB SCSI ZIP drive into Emax Both drives are now sitting where the original floppy drive was. The slim floppy is working fine. But if I try to format the Zip disk I get an error message: "hard disk error". I double-checked all connections. The cables are all connected correctly. SCSI ID of the Zip drive is set to 0 (all jumpers removed), termination is on, as there are no more drives connected to the SCSI cable. If I run "scan hd" or "scsi/echip" in the hd diagnostics mode, Emax freezes and I need to power off. What can I do? I bought the Zip drive from a trustworthy person, so I don't think it's broken. Its green light flashes up when I power on the Emax. On the other hand, I think that something could be wrong with the SCSI connection. When I bought this Emax the hard disk was not working. Since this is not unusual I thought that the hd was simply broken and everything would be fine as soon as I connect the Zip drive. I really appreciate your help. Ben
