Emax
emax se upgrade
emax se upgrade
2009-08-08 by markrocket@...
This has been covered b4 probably but i just noticed the seup file is 800kb and i thought emax's only formatted to standard 720kb?
Thats one thing the other thing is how do i create a dos6.22 boot disk on floppy from windows vista? (ive tried it on cd and it says driver missing). Is it the whole fat32 ntfs thing?
Im not very PC literate.
Other question is which floppy drives can you use in the emax.
I think i might have to make some jumper adjustments or even
cut the cable and do a bit of swapping. Ive read that the sony mpf920 works and the other question is... which one (mpf920-e  -f    z/121)
Once youve made the switch can you use hd disks?
I know this has probably all been covered before but ive had a scan through the groups archives and i cannot see much.
Thanks in advance
Re: [emax] emax se upgrade
2009-08-08 by Ted Summers
The file works when the disk is created with Emaxutil. That is all I
can say.
I just do it, I can't explain it. It has never been difficult for me.
fat32 ntfs thing?
to make a bootable dos CD you have to load in a CD driver into
config.sys and autoexec.bat
It can be a pain to make one , but can be done.
CDs are not ntfs or fat32, there are a different type (High Sierra FS
or Rockridge or something like that).
The jumpers on the model I had were SMT, so had to be soldered. And
they changed the board after that rev, so I dunno if you can still do
that mod.
But you should be able to modify a floppy cable by matching Schugart
floppy pinouts to PC floppy pinouts, cut some of the wires in the
ribbon and cross wire as needed.
It will leave a gap, but it is what it is.
Or if you have an internal SCSI Zip or CF you can get a slim floppy
and one of my converters.
See a pic here:
http://djtbs1.spaces.live.com/
pic #4
You still need to cover the hole, but I have never had any problem
with my slim floppy drives and HD disks for samples.
Ted
2009-08-08 by Frequency Spectrum
Thanks for your help
much appreciated
> can say.
> fat32 ntfs thing?
> that mod.
> See a pic here:
> pic #4
> Regards,
> Ted
