Emax
emax1 key repair
emax1 key repair
2009-12-09 by Bob
There are two keys on my Emax 1 that no longer work although I can still access the notes via midi. Has anyone had a similar problem and been able to fix it?
Thanks for any advice.
Bob
Re: emax1 key repair
2009-12-09 by emax_dx5
Key contacts are springs. It could happen the spring has broken (they tend to deforming after years).
They suffer of carbon too. Maybe a cleaning with isopropylic alcohol could fix it.
An adjustment in the spring level screw could be the goal too.
> Bob
Re: [emax] emax1 key repair
2009-12-09 by jammie
dirty contacts just use some deoxit and a cotton wool bud
  To: emax@yahoogroups.com
  Sent: Wednesday, December 09, 2009 10:23 AM
  Subject: [emax] emax1 key repair
  Bob
  Checked by AVG - www.avg.com
  Version: 8.5.426 / Virus Database: 270.14.98/2552 - Release Date: 12/08/09 07:34:00
2009-12-10 by Patrick R
This could also be a shorted out pathway. I had this issue and used emery cloth to sand down the insulator over the pathway, cleaned the pathway and sealed it. For me this repaired the critical middle C range of keys. You may need complete the circuit if the pathway is extremely damaged or broken. Great thing about old tech is it is macro and not micro circuitry, and easy to repair. Don't forget to disconnect the keyboard from the rest of the unit. That way if you have some static build-up or otherwise cause problems, you won't kill the all important ICs.
Good luck!
Sent: Wed, December 9, 2009 6:34:45 AM
Subject: Re: [emax] emax1 key repair
To: emax@yahoogroups. com
Bob
2009-12-10 by Bob King
Thanks guys: I'll give it a go over the week end.
Bob
Date: Thursday, 10 December, 2009, 1:11
Good luck!
____________ _________ _________ __
Bob
