Out of Memory Error
2010-06-22 by Ted Summers
So I was starting to actually try and use my emax 2 this last weekend, and ran into trouble. Any Emax 1 disk I try and load, it starts loading and says "Out of Sample Memory". But Emax 1 only has 512K. So why can't the Emax 2 use an Emax 1 disk? Am I missing something? Regards, Ted
2010-06-22 by tu@...
Hi Ted, I recall that there was a limitation on loading very full Emax I banks into a 1MB Emax II because some memory was still needed to do the sample decompression. But that should only be affecting a few Emax I disks. How much memory is remaining before you attempt to load the bank? Can you load individual presets from Emax I disks? /Tristan
On Tue, Jun 22nd, 2010 at 11:57 AM, Ted Summers <djtbs1@...> wrote: > So I was starting to actually try and use my emax 2 this last > weekend, > and ran into trouble. > > Any Emax 1 disk I try and load, it starts loading and says "Out of > Sample Memory". > But Emax 1 only has 512K. So why can't the Emax 2 use an Emax 1 > disk? > > Am I missing something? > > > Regards, > Ted > >
2010-06-22 by jammie
if its a 1mb machine that might be the problem as the 512k being 8bit data will double when its put into the emax2 as its put into 16bit data structure the problem might be that it uses some of the memory for other duties so tht the full 1mb might not just be for samples i dont know about the emax2 as i never owned 1 but my other samplers use memory for sequecer data and fx might be the same for the emax2
To: emax@yahoogroups.com
Sent: Tuesday, June 22, 2010 2:57 AM
Subject: [emax] Out of Memory Error
Sample Memory".
Ted
Checked by AVG - www.avg.com
Version: 8.5.437 / Virus Database: 271.1.1/2952 - Release Date: 06/20/10 18:36:00
[Non-text portions of this message have been removed]2010-06-22 by Elk Latham
That's right, The Emax II wants to convert it to 16 bit. Then you run out of memory. ________________________________
From: "tu@..." <tu@...> To: emax@yahoogroups.com; Ted Summers <djtbs1@...m> Sent: Mon, June 21, 2010 8:00:08 PM Subject: Re: [emax] Out of Memory Error Hi Ted, I recall that there was a limitation on loading very full Emax I banks into a 1MB Emax II because some memory was still needed to do the sample decompression. But that should only be affecting a few Emax I disks. How much memory is remaining before you attempt to load the bank? Can you load individual presets from Emax I disks? /Tristan On Tue, Jun 22nd, 2010 at 11:57 AM, Ted Summers <djtbs1@...> wrote: > So I was starting to actually try and use my emax 2 this last > weekend, > and ran into trouble. > > Any Emax 1 disk I try and load, it starts loading and says "Out of > Sample Memory". > But Emax 1 only has 512K. So why can't the Emax 2 use an Emax 1 > disk? > > Am I missing something? > > > Regards, > Ted > > [Non-text portions of this message have been removed]
2010-06-23 by emax2@...
back in the day, I converted all of my emax 1 discs (over 200) to emax 2 by updating the software. I never ran into a memory problem.
----- Original Message ----- From: "Elk Latham" <elk_latham@...> To: emax@yahoogroups.com Sent: Tuesday, June 22, 2010 12:08:29 AM GMT -06:00 Central America Subject: Re: [emax] Out of Memory Error That's right, The Emax II wants to convert it to 16 bit. Then you run out of memory. ________________________________ From: "tu@..." <tu@...> To: emax@yahoogroups.com; Ted Summers <djtbs1@...> Sent: Mon, June 21, 2010 8:00:08 PM Subject: Re: [emax] Out of Memory Error Hi Ted, I recall that there was a limitation on loading very full Emax I banks into a 1MB Emax II because some memory was still needed to do the sample decompression. But that should only be affecting a few Emax I disks. How much memory is remaining before you attempt to load the bank? Can you load individual presets from Emax I disks? /Tristan On Tue, Jun 22nd, 2010 at 11:57 AM, Ted Summers <djtbs1@...> wrote: > So I was starting to actually try and use my emax 2 this last > weekend, > and ran into trouble. > > Any Emax 1 disk I try and load, it starts loading and says "Out of > Sample Memory". > But Emax 1 only has 512K. So why can't the Emax 2 use an Emax 1 > disk? > > Am I missing something? > > > Regards, > Ted > > [Non-text portions of this message have been removed] ------------------------------------ Emax and Emax II User's Group Website http://www.silveriafamily.comYahoo! Groups Links [Non-text portions of this message have been removed]
