Emax
Alan Wilder collection
2011-05-31 by patrick.rebullida@...
By the way :
http://auction.recoil.co.uk/samplers/
----- Mail Original -----
De: "jammie emma" <jammie.emma@...>
À: emax@yahoogroups.com
Envoyé: Mardi 31 Mai 2011 20h51:14 GMT +01:00 Amsterdam / Berlin / Berne / Rome / Stockholm / Vienne
Objet: Re: [emax] Re: emax service manual
the diahgnostic parts are available from emulator archive it was just the schematics that were not which is the file that you have which was from the ftp server of emulator archive file download page for people who purchased it
To: emax@yahoogroups.com
Sent: Tuesday, May 31, 2011 6:32 PM
Subject: [emax] Re: emax service manual
I have a different revision of the service manual, version B.
The missing pages mentioned are from the diagnostics chapter.
In my manual this chapter is complete, but it could be different.
I'll try to scan this chapter first, but that will be at the end of next week at the earliest.
--- In emax@yahoogroups.com , Robin Price <crx091081gb@...> wrote:
> I can confirm all copies of the service manual I can find have those
> missing pages. Perhaps a re-scan is in order?
Checked by AVG - www.avg.com
Version: 9.0.901 / Virus Database: 271.1.1/3671 - Release Date: 05/31/11 07:34:00
Emulator libraries
2011-06-14 by blchrr@...
Greetings to the list members.
First post on the list, i wanted to ask about the similarities between the
original Emulator I and EII libraries and later Emax libraries, did many
banks get moved from the early emulators to the later Emax machines? Was
there a lot of overlap in the libraries?
Also id like to know if you guys have seen the Zip disk packages on Ebay, 5
zips for Emax 1 and 2 zips for Emax II, supposedly with the complete factory
libraries for each machine spread over the zip disks, has anyone bought from
them?
As for me, i bought an Emax 1 rack fairly recently and am hoping to add an
internal scsi zip drive in the future, i used to have a few vintage
samplers, but now the emax is the only machine i have.
Cheers, Rob.
Re: [emax] Emulator libraries
2011-06-14 by Johnny Tomasello
I have an Emax I, and I installed the SCSI myself.  There are several things you should be aware of when doing this.  You have to open the Emax and check to see if the motherboard can support the SCSI upgrade.  Rev A boards do not, which is what I had.  So I found a Rev C board on ebay and swapped it out.  If your board already supports SCSI, I believe you can still purchase the upgrade from someone online.  Check the board, I think I saw the info there.  Also, check the emulator archive site.  That has been invaluable to me in support of my Emax and SP12.
Also, the Emax I cannot boot from a hard drive unless the SCSI ID is set to 0.  I set mine up with an external ZIP (limited to SCSI ID 6 ro 5) for now.  I can save and access sounds only.  I'm still in the process of researching which SCSI card reader is compatible with the Emax I.  I've tried a Spryus without luck.  If anyone has any info on this, I'd be glad to hear it.
As far as the internal ZIP, that should fix the "SCSI ID set to 0" problem, but I don't know if the power supply in the Emax is enough to support it.  I have read where people have had problems supporting hard drives this way. I have not tested this, so I may be completely wrong.  If anyone on this list has a definitive answer, I'd also be glad to learn that as well.
I also purchased the Emax library on ebay you're mentioning.  For the price, I thought it was well worth it.  But the sounds are, for my purposes, a bit dated.  So I usually edit them quite a bit.  But the sounds are 20 or so years old, so I shouldn't complain, really.
As always, thanks to everyone on this list for all the information.
Johnny.
> them?
> Cheers, Rob.
2011-06-15 by Ted Summers
In regards to Card Reader- PCD-50b works and is bootable.
In regards to power supply too weak to support Zip or Compact Flash- my power readings data I have shows no proof of it.
I did some testing and there is a table of all my measurements at my wordpress site under "Drive Power Readings".
http://djtbs1.wordpress.com/
My testing I believe debunks that myth.
My belief is that some of the power supplies simply have bad solder joints, or were spec'ed at a very minimal tolerance in the first place.
But that is just my opinion.
When I bought my Emax the first thing I did was remove the power supply and resolder all the joints and replace all the caps.
These are 20+ year old units after all.
Ted
Johnny.
> them?
> Cheers, Rob.
http://www.silveriafamily.comYahoo! Groups Links
Re: Emulator libraries
2011-06-15 by blchrr@...
Hi Johnny, Ted.
Johnny- thanks for the tips and info, i do have a Rev C board so i think im
ok. I have checked out the Emulator archive- its a great little resource
site, i need to read through the install notes for the scsi upgrade as my
kit has arrived now and im keen to get cracking. I ended up buying used
internal SCSI zip, 2 slim floppy drives (one as a spare) all from Ebay.
I picked up a set of the Zip disk libraries from Ebay too.
Ted- small world, are you the guy that i just bought the SCSI kit and slim
floppy adapter from? :) Thanks man... real fast shipping on that.
On a side note im also thinking of replacing the LCD with a VFD, has anyone
done that?
Thanks guys.
Look forward to getting my Emax upgraded over the next few months.
Rob.
> Regards,
> Ted
> Hi,
> Regards,
> Johnny.
>> them?
>> Cheers, Rob.
Re: [emax] Re: Emulator libraries
Yes, I am the SCSI upgrade provider.
Just ask anyone here :-)
With rev C (PC333) board there are no modifications just drop those chips in.
It should be an easy smooth transition.
Ted
On Jun 15, 2011, at 1:56 AM, blchrr@... wrote:
Hi Johnny, Ted.
done that?
Thanks guys.
Rob.
> Regards,
> Ted
> Hi,
> Regards,
> Johnny.
>> them?
>> Cheers, Rob.
2011-06-15 by Johnny Tomasello
Thanks for all the info Ted.
You did your Emax up right.  Since you are selling the SCSI upgrades, I thought I would ask if you sell any SCSI card readers and or slim floppy drives.  It would be great if you did, since you clearly know what you're doing.
Also, I wanted to ask your advice.  In doing this SCSI upgrade project, I wound up with a whole other (non working) Emax SE.  Are there discontinued parts in the Emax  (such as filter chips, etc.) that I could salvage and keep for future repairs on my working Emax?  I'm suspecting it will be costly to repair, if it's even possible.  I tested the power supply, and that's not the problem, as far as I can tell.  So I can't really test anything else.
I was just wondering what you might do in this situation.
Thanks again for the info.
Johnny...
> Regards,
> Ted
> Hi Johnny, Ted.
> done that?
> Thanks guys.
> Regards,
> Rob.
>> Regards,
>> Ted
>> Hi,
>> Regards,
>> Johnny.
>>> them?
>>> Cheers, Rob.
Unless it is the echip, the other parts can be sourced, although it can get
pricey.
Usually it is repairable.
Jammie in UK has spare boards as well......my rack testbed was a DOA unit
when I got it and I was able to get it fixed....
As to carrying slim floppy drives- In 3 yrs only about 4 people have asked
me to supply them, so it wouldn't be worth it to stock them myself.
As to CF drives- I got a lot of 40 of them on ebay and sold them to group
users for cheap after verifying they worked in Emax and updating the
firmware.
But the supply ran out, as I knew it would.
I can't get them any cheaper than you can......
There is another vendor claiming his units work, but he hasn't sent me a
sample to test.
I told him if he sent it, I would test it, send it back, and spread the
word.
That was about a month or so ago.....nothing further from him.
Ted
> doing.
> Regards,
> Johnny...
> in.
> > Regards,
> > Ted
> > Hi Johnny, Ted.
> im
> slim
> anyone
> > done that?
> > Thanks guys.
> > Regards,
> > Rob.
> >> Regards,
> >> Ted
> >> Hi,
> it.
> as well.
> >> Regards,
> >> Johnny.
> the
> many
> Was
> Ebay, 5
> factory
> from
> >>> them?
> an
> >>> Cheers, Rob.
Guys... just thought id mention it, figured others had done this already,
but clearly not.... a scsi zip can not be installed internally, it can be
mounted inside using the old mounting brackets but the zip disks are too
wide to be inserted from the front (where floppy drive used to be)
Major bummer, i have two options now it seems, either i attempt to cut the
metal bay on the front to accomodate the zip drive or use an external drive.
This is a pain as i really liked the idea of having the zip drive installed
internally. Has anyone had any experience of installing zip drives
internally? I have an Emax 1 rack btw.
Thanks
> pricey.
> firmware.
> sample to test.
> word.
> Regards,
> Ted
>> doing.
>> Regards,
>> Johnny...
>> in.
>> > Regards,
>> > Ted
>> > Hi Johnny, Ted.
>> im
>> slim
>> anyone
>> > done that?
>> > Thanks guys.
>> > Regards,
>> > Rob.
>> >> Regards,
>> >> Ted
>> >> Hi,
>> it.
>> as well.
>> >> Regards,
>> >> Johnny.
>> the
>> many
>> Was
>> Ebay, 5
>> factory
>> from
>> >>> them?
>> an
>> >>> Cheers, Rob.
2011-06-16 by jammie.emma@...
you have to file out the opening so that it fits its the same with the scsi cf adapter its been talked about before
  Sent: Wednesday, June 15, 2011 11:33 PM
  Subject: [emax] Re: Emulator libraries
  Thanks
  > pricey.
  > firmware.
  > sample to test.
  > word.
  > Regards,
  > Ted
  >> doing.
  >> Regards,
  >> Johnny...
  >> in.
  >> > Regards,
  >> > Ted
  >> > Hi Johnny, Ted.
  >> im
  >> slim
  >> anyone
  >> > done that?
  >> > Thanks guys.
  >> > Regards,
  >> > Rob.
  >> >> Regards,
  >> >> Ted
  >> >> Hi,
  >> it.
  >> as well.
  >> >> Regards,
  >> >> Johnny.
  >> the
  >> many
  >> Was
  >> Ebay, 5
  >> factory
  >> from
  >> >>> them?
  >> an
  >> >>> Cheers, Rob.
  Version: 9.0.901 / Virus Database: 271.1.1/3705 - Release Date: 06/15/11 07:34:00
2011-06-16 by Ted Summers
Must depend on the CF adapter used, because my install with the PCD-50b I didn't have to modify the front of my rack at all...
Ted
Thanks
> pricey.
> firmware.
> sample to test.
> word.
> Regards,
> Ted
>> doing.
>> Regards,
>> Johnny...
>> in.
>> > Regards,
>> > Ted
>> > Hi Johnny, Ted.
>> im
>> slim
>> anyone
>> > done that?
>> > Thanks guys.
>> > Regards,
>> > Rob.
>> >> Regards,
>> >> Ted
>> >> Hi,
>> it.
>> as well.
>> >> Regards,
>> >> Johnny.
>> the
>> many
>> Was
>> Ebay, 5
>> factory
>> from
>> >>> them?
>> an
>> >>> Cheers, Rob.
