To: emax@yahoogroups.com
Sent: Saturday, June 04, 2011 8:33 PM
Subject: [emax] Re: Emax SE HD Retro: Stuck On Diagnostics?
Hi Jammie:
I forgot to add in my previous post... I'm in the United States (New York City to be precise).
DBM
--- In emax@yahoogroups.com, <jammie.emma@...> wrote:
> now see i new it was that i have had this a number of times where people have messed with trying to fix things but dont have a clue as i am a registered
> synth technician ex ensoniq i do this all the time and have had this happen a couple of times
> now on a few i have had the dacs for the cv circuits short out due to fitting the cable the wrong way round 5 volts going to the wrong pin and 12v and 0v and -12v which can really damage some ic,s some have protection as some dont some ic,s have a max voltage of 15 volts so are ok where digital ic like the cv dac only work of 5v input for icc
> now it sounds to me the guy you brought it from lied to you saying it was working as it was definitly not due to tampering
> now also becuase of this you could also damage psu due to shorts to earth and negitive voltage shorting out the power rails need to test power rail supplies
> write it needs to load the os before the diagnostics will work as it needs the os to do this have you got the os disk in
> can you tell me what happens does the disk boot or spin
> when the os is loaded it will do the diagnostic and the led,s will go out and the black boxes disapear on the lcd
> let me know what happens
> where do you live as i have a spare revision c mother board and i can test your board and swap it with a working 1 if its broken i can fix the mother board at another date
> all depends on where you live uk or usa if its usa then i recoment ted for this as you need some digital mesurement equipement and analog measure ment equipment to tell whats wrong with the mother board
> as for the analog board if the cv dac is burnt out then when you play samples you would not be able to do modulation of the filter amp or panning or volume due to no cv control going to the sample and holds
> i had this with a member on the furom and told him how to fix by his elimination telling me what was hapenning and what was not a new cd dac and he was away he fitted a new 1 and all was well
> we will get your machine running again me and ted
> From: ditabeardmemo
> Sent: Saturday, June 04, 2011 4:22 PM
> So the good news is this: Jammie was right! I checked the position of the ribbon cable running between the analog board (on the bottom of the unit) and the digital board (on the top of the unit), and it turns out it had been flipped so that data line 1 of the cable did not correspond with data line 1 of the analog board pins.
> The bad news is the Emax still won't boot and now has new different/problems. I powered on/off several time in a row, and here is what I noticed:
> - All front panel lights turn on, floppy drive light is on, LCD displays black boxes across the top row and nothing on the bottom row, no progress.
> - All front panel lights turn on, floppy drive light is on, "Dynamic Allocation" light turns off after about 0:30, LCD displays black boxes across the top row and nothing on the bottom row, no progress.
> - No front panel lights turn on, LCD displays "Diagnostics" but does not run the tests, no progress.
> So guys... any ideas where I should turn next?
> --- In emax@yahoogroups.com, <jammie.emma@> wrote:
> > its denoted with a 1 on the circuit pcb on the digital mainboard as the ribbon is fixed to the analog board
> > From: ditabeardmemo
> > Sent: Friday, June 03, 2011 7:57 PM
> > Thanks Jammie.
> > I'll check this, although I'm quite sure that I didn't flip that ribbon cable when I re-seated it. And I don't believe the seller messed with that ribbon cable after he tested the unit, either.
> > Is there an easy way to determine where pin 1 is on the analog board connection, or do I need to look at the schematic in the service manual?
> > > the ribbon cable between the logic board and the analog board is seated the wrong way round make sure that the pin 1 lines up with th red or blue cable of the ribbon
> > > theres only 1 coloured cable which denotes pin 1 on the ribbon
> > > the reason i say blue or red is that i have a rack that is red and a keyboard that is blue
> > > From: ditabeardmemo
> > > Sent: Friday, June 03, 2011 1:53 PM
> > > Thanks Ted. Still no luck with the unit, unfortunately.
> > > Although I didn't completely remove every socketed IC from the board (I'm always a little uncomfortable removing ICs), I did re-adjust those ICs by gently prying up each side with a flat screwdriver and then pressing back down again.
> > > Ribbon cable connections seem quite secure, although I will try again.
> > > The ribbon cable that connects the logic board and the analog board has a strange connector on the logic side... some flat blue plastic thing. I have no idea how to disconnect/reseat this.
> > > A member on the eiiiforum.com Web site suggested it might be the floppy disk drive, although the owner said the floppy was working fine prior to shipment (and the unit was very well packed.) Any thoughts there?
> > > --- In emax@yahoogroups.com, Ted Summers <djtbs1@> wrote:
> > > > Reseat all the ICs and connectors on the logic board....
> > > > On Thu, Jun 2, 2011 at 6:47 AM, ditabeardmemo <brandt@> wrote:
> > > > > Hi everyone:
> > > > > I just received an Emax SE HD Retrofit rack unit with a factory-installed
> > > > > external SCSI port. The previous owner reported that the unit worked
> > > > > perfectly.
> > > > > Unfortunately the unit gets stuck on the "Diagnostics" screen at power on.
> > > > > When I power it on, it displays a screen that reads "Diagnostics," and the
> > > > > front panel "Play" and "Stop" buttons are lit. The red light on the floppy
> > > > > drive also stays lit. It does not proceed with the diagnostic tests, no
> > > > > buttons respond and I can't get the unit to move past this screen. This
> > > > > happens regardless of whether I have the Plus OS 1.0 floppy inserted, or no
> > > > > floppy at all. I don't have any SCSI peripherals connected, either.
> > > > > Thanks in advance to anyone who can offer some insight!
> > > > > Best,
> > > > > DBM
> No virus found in this incoming message.
> Checked by AVG - www.avg.com
> Version: 9.0.901 / Virus Database: 271.1.1/3680 - Release Date: 06/04/11 07:34:00
