Emax
No Power
No Power
2011-07-29 by emax_dx5
Emax are quite famous because of dead power supplies  when shipped. If you are skill with electronics (Just only in case of! high voltage inside), check to resolder all the PSU transformer pins. Also, check as many solder points as you can. It is very common to find some of them broken (I experienced up to two emax that way after being shipped).
Just my 5 cent.
Re: No Power
2011-07-29 by inicasire
definately never soldered anything before, maybe I would benefit from buying a new psu and trying that if I can't isolate the issue. Thanks :)
> Just my 5 cent.
Re: [emax] Re: No Power
2011-07-29 by jammie.emma@...
it might have a newer psu which did away with the red wires
on the old psu there is a relay that the 2 red wires go to when powered up it switched the 2 110v windings in series making it a 220-240 volt transformer primary
  To: emax@yahoogroups.com
  Sent: Friday, July 29, 2011 2:21 PM
  Subject: [emax] Re: No Power
  > Just my 5 cent.
  Checked by AVG - www.avg.com
  Version: 9.0.901 / Virus Database: 271.1.1/3795 - Release Date: 07/28/11 23:12:00
Re: No Power
2011-07-30 by inicasire
Thanks Jammie this is a 220 euro version, the seller said he didn't cut anything so you're probably right. I'm going to check out the service manual again, it's very frustrating because I've checked everything I could think of already. So you think maybe a new psu board will do it?
>   ----- Original Message -----
>   From: inicasire
>   > Just my 5 cent.
