Low gain/ no signal on sampling inputs
2011-11-26 by jdchevallier
So after being content for a long time simply playing the large library of disk my emax se rack came with I decided to sample some drums today. Do my dismay there seems to be minimal/no signal coming into the unit. The VU has 3 bars and is set to +40. I've tried several signal sources and none make a difference. Does anyone have a sense of what might be wrong with my sampler??? Thanks! Joel
2011-11-26 by llingoapt@...
describe whatt your sampling source is and anyother device you run it through before it enters the emax
----- Original Message ----- From: "jdchevallier" <joel.chevallier@...> To: emax@yahoogroups.com Sent: Saturday, November 26, 2011 2:59:59 PM Subject: [emax] Low gain/ no signal on sampling inputs So after being content for a long time simply playing the large library of disk my emax se rack came with I decided to sample some drums today. Do my dismay there seems to be minimal/no signal coming into the unit. The VU has 3 bars and is set to +40. I've tried several signal sources and none make a difference. Does anyone have a sense of what might be wrong with my sampler??? Thanks! Joel [Non-text portions of this message have been removed]
2011-11-26 by Joel Chevallier
I tried my Jupiter 6, an iPod, and a turntable, all directly from the devices' outputs into the emax to no avail. -joel On Nov 26, 2011, at 1:10 PM, llingoapt@... wrote: > describe whatt your sampling source is and anyother device you run it through before it enters the emax > > ----- Original Message ----- > From: "jdchevallier" <joel.chevallier@...> > To: emax@yahoogroups.com > Sent: Saturday, November 26, 2011 2:59:59 PM > Subject: [emax] Low gain/ no signal on sampling inputs > > So after being content for a long time simply playing the large library of disk my emax se rack came with I decided to sample some drums today. Do my dismay there seems to be minimal/no signal coming into the unit. The VU has 3 bars and is set to +40. I've tried several signal sources and none make a difference. Does anyone have a sense of what might be wrong with my sampler??? > > Thanks! > > Joel > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed]
2011-11-26 by jack
SOUNDS LIKE YOU HAVE A ADC PROBLEM send analog board to me and ill check it if i cant fix it i have spares first where do you live if you are in us ask ted to have a look if in uk you can send to me jammie logan synth and sampler repair 42 glastonbury crescent walsallws3 2rf or you can send it to epr electronics as they are authorized emu repair services but be pre pared to pay mega bucks as they charge $80 for diagnostics if you dont get it fixed by them
Cc: emax@yahoogroups.com
Sent: Saturday, November 26, 2011 10:52 PM
Subject: Re: [emax] Low gain/ no signal on sampling inputs
-joel
> Thanks!
> Joel
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1873 / Virus Database: 2101/4640 - Release Date: 11/26/11
[Non-text portions of this message have been removed]2011-11-26 by Joel Chevallier
Jammie, Thanks for the generous offer. I'm in the US, so I guess Ill reach out to Ted. If I can figure out a way to edit samples without buying an older computer and send via midi perhaps this isnt such a big deal. Can this be done with any software than runs on a new Mac? Thanks again! Joel On Nov 26, 2011, at 3:17 PM, "jack" <jammie.emma@...> wrote: > SOUNDS LIKE YOU HAVE A ADC PROBLEM > > send analog board to me and ill check it if i cant fix it i have spares > > first where do you live if you are in us ask ted to have a look if in uk you can send to me jammie logan > synth and sampler repair > 42 glastonbury crescent > walsallws3 2rf > > or you can send it to epr electronics as they are authorized emu repair services > > but be pre pared to pay mega bucks as they charge $80 for diagnostics if you dont get it fixed by them > ----- Original Message ----- > From: Joel Chevallier > To: emax@yahoogroups.com > Cc: emax@yahoogroups.com > Sent: Saturday, November 26, 2011 10:52 PM > Subject: Re: [emax] Low gain/ no signal on sampling inputs > > I tried my Jupiter 6, an iPod, and a turntable, all directly from the devices' outputs into the emax to no avail. > > -joel > > On Nov 26, 2011, at 1:10 PM, llingoapt@... wrote: > > > describe whatt your sampling source is and anyother device you run it through before it enters the emax > > > > ----- Original Message ----- > > From: "jdchevallier" <joel.chevallier@...> > > To: emax@yahoogroups.com > > Sent: Saturday, November 26, 2011 2:59:59 PM > > Subject: [emax] Low gain/ no signal on sampling inputs > > > > So after being content for a long time simply playing the large library of disk my emax se rack came with I decided to sample some drums today. Do my dismay there seems to be minimal/no signal coming into the unit. The VU has 3 bars and is set to +40. I've tried several signal sources and none make a difference. Does anyone have a sense of what might be wrong with my sampler??? > > > > Thanks! > > > > Joel > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > > No virus found in this message. > Checked by AVG - www.avg.com > Version: 2012.0.1873 / Virus Database: 2101/4640 - Release Date: 11/26/11 > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed]
2011-11-26 by Matt
You can send samples via MIDI with elektron c6 MIDI i believe. On Nov 26, 2011 3:27 PM, "Joel Chevallier" <joel.chevallier@...> wrote: > ** > > > Jammie, > > Thanks for the generous offer. I'm in the US, so I guess Ill reach out to > Ted. > If I can figure out a way to edit samples without buying an older computer > and send via midi perhaps this isnt such a big deal. Can this be done with > any software than runs on a new Mac? > > Thanks again! > > Joel > > On Nov 26, 2011, at 3:17 PM, "jack" <jammie.emma@blueyonder.co.uk> wrote: > > > SOUNDS LIKE YOU HAVE A ADC PROBLEM > > > > send analog board to me and ill check it if i cant fix it i have spares > > > > first where do you live if you are in us ask ted to have a look if in uk > you can send to me jammie logan > > synth and sampler repair > > 42 glastonbury crescent > > walsallws3 2rf > > > > or you can send it to epr electronics as they are authorized emu repair > services > > > > but be pre pared to pay mega bucks as they charge $80 for diagnostics if > you dont get it fixed by them > > ----- Original Message ----- > > From: Joel Chevallier > > To: emax@yahoogroups.com > > Cc: emax@yahoogroups.com > > Sent: Saturday, November 26, 2011 10:52 PM > > Subject: Re: [emax] Low gain/ no signal on sampling inputs > > > > I tried my Jupiter 6, an iPod, and a turntable, all directly from the > devices' outputs into the emax to no avail. > > > > -joel > > > > On Nov 26, 2011, at 1:10 PM, llingoapt@... wrote: > > > > > describe whatt your sampling source is and anyother device you run it > through before it enters the emax > > > > > > ----- Original Message ----- > > > From: "jdchevallier" <joel.chevallier@...> > > > To: emax@yahoogroups.com > > > Sent: Saturday, November 26, 2011 2:59:59 PM > > > Subject: [emax] Low gain/ no signal on sampling inputs > > > > > > So after being content for a long time simply playing the large > library of disk my emax se rack came with I decided to sample some drums > today. Do my dismay there seems to be minimal/no signal coming into the > unit. The VU has 3 bars and is set to +40. I've tried several signal > sources and none make a difference. Does anyone have a sense of what might > be wrong with my sampler??? > > > > > > Thanks! > > > > > > Joel > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > [Non-text portions of this message have been removed] > > > > No virus found in this message. > > Checked by AVG - www.avg.com > > Version: 2012.0.1873 / Virus Database: 2101/4640 - Release Date: 11/26/11 > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed]
2011-11-26 by Nik Kinloch
You can hook it up to a PC using http://www.emxp.net/ + a small electronics project to convert the serial to USB properly. Or buy an Apple II and use some old software http://www.emulatorarchive.com/Samplers/EmaxOverview/EmaxEditors/emaxeditors.html
On 26/11/2011 23:26, Joel Chevallier wrote: > Jammie, > > Thanks for the generous offer. I'm in the US, so I guess Ill reach out to Ted. > If I can figure out a way to edit samples without buying an older computer and send via midi perhaps this isnt such a big deal. Can this be done with any software than runs on a new Mac? > > Thanks again! > > Joel > >
Thanks Nik, but was hoping against hope that there would be a solution using my new Mac/that doesn't require me purchasing a pc or older Mac. Joel On Nov 26, 2011, at 3:33 PM, Nik Kinloch <nikkinloch@...> wrote: > You can hook it up to a PC using http://www.emxp.net/ + a small > electronics project to convert the serial to USB properly. > > Or buy an Apple II and use some old software > http://www.emulatorarchive.com/Samplers/EmaxOverview/EmaxEditors/emaxeditors.html > > On 26/11/2011 23:26, Joel Chevallier wrote: > > Jammie, > > > > Thanks for the generous offer. I'm in the US, so I guess Ill reach out to Ted. > > If I can figure out a way to edit samples without buying an older computer and send via midi perhaps this isnt such a big deal. Can this be done with any software than runs on a new Mac? > > > > Thanks again! > > > > Joel > > > > > > [Non-text portions of this message have been removed]
Matt, Thanks for the suggestion. I'll definitely give this a go! Joel
On Nov 26, 2011, at 3:33 PM, Matt <somatt@...> wrote: > You can send samples via MIDI with elektron c6 MIDI i believe. > On Nov 26, 2011 3:27 PM, "Joel Chevallier" <joel.chevallier@...> > wrote: > >> ** >> >> >> Jammie, >> >> Thanks for the generous offer. I'm in the US, so I guess Ill reach out to >> Ted. >> If I can figure out a way to edit samples without buying an older computer >> and send via midi perhaps this isnt such a big deal. Can this be done with >> any software than runs on a new Mac? >> >> Thanks again! >> >> Joel >> >> On Nov 26, 2011, at 3:17 PM, "jack" <jammie.emma@...> wrote: >> >>> SOUNDS LIKE YOU HAVE A ADC PROBLEM >>> >>> send analog board to me and ill check it if i cant fix it i have spares >>> >>> first where do you live if you are in us ask ted to have a look if in uk >> you can send to me jammie logan >>> synth and sampler repair >>> 42 glastonbury crescent >>> walsallws3 2rf >>> >>> or you can send it to epr electronics as they are authorized emu repair >> services >>> >>> but be pre pared to pay mega bucks as they charge $80 for diagnostics if >> you dont get it fixed by them >>> ----- Original Message ----- >>> From: Joel Chevallier >>> To: emax@yahoogroups.com >>> Cc: emax@yahoogroups.com >>> Sent: Saturday, November 26, 2011 10:52 PM >>> Subject: Re: [emax] Low gain/ no signal on sampling inputs >>> >>> I tried my Jupiter 6, an iPod, and a turntable, all directly from the >> devices' outputs into the emax to no avail. >>> >>> -joel >>> >>> On Nov 26, 2011, at 1:10 PM, llingoapt@... wrote: >>> >>>> describe whatt your sampling source is and anyother device you run it >> through before it enters the emax >>>> >>>> ----- Original Message ----- >>>> From: "jdchevallier" <joel.chevallier@...> >>>> To: emax@yahoogroups.com >>>> Sent: Saturday, November 26, 2011 2:59:59 PM >>>> Subject: [emax] Low gain/ no signal on sampling inputs >>>> >>>> So after being content for a long time simply playing the large >> library of disk my emax se rack came with I decided to sample some drums >> today. Do my dismay there seems to be minimal/no signal coming into the >> unit. The VU has 3 bars and is set to +40. I've tried several signal >> sources and none make a difference. Does anyone have a sense of what might >> be wrong with my sampler??? >>>> >>>> Thanks! >>>> >>>> Joel >>>> >>>> [Non-text portions of this message have been removed] >>>> >>>> >>> >>> [Non-text portions of this message have been removed] >>> >>> No virus found in this message. >>> Checked by AVG - www.avg.com >>> Version: 2012.0.1873 / Virus Database: 2101/4640 - Release Date: 11/26/11 >>> >>> [Non-text portions of this message have been removed] >>> >>> >> >> [Non-text portions of this message have been removed] >> >> >> > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > > >
2011-11-26 by jack
not that i know of emxp is good i use it all the time for making disks sample wrench is another good program but pc only get youyr self a mac IIci fx si se/30 i see them for sale all the time in the usa going for $30-80 just download image and your away i have fitted scsi to cf drive in mine quiet i have several old macs and pc for just this type of thing as newer comps dont cater for the old software i have atari,s aswell for the same reason midi timing is rock sollid on an atari so all my midi gets done on that with the atari as master midi clock
Cc: <emax@yahoogroups.com>
Sent: Saturday, November 26, 2011 11:26 PM
Jammie,
Thanks again!
Joel
> walsallws3 2rf
> -joel
> > From: "jdchevallier" <joel.chevallier@gmail.com>
> > Thanks!
> > Joel
[Non-text portions of this message have been removed]2011-11-26 by jack
yes you can but have not tried with emu works with yamaha sy85 and sy99 ----- Original Message -----
From: "Matt" <somatt@...> To: <emax@yahoogroups.com> Sent: Saturday, November 26, 2011 11:33 PM Subject: Re: [emax] Low gain/ no signal on sampling inputs > You can send samples via MIDI with elektron c6 MIDI i believe. > On Nov 26, 2011 3:27 PM, "Joel Chevallier" <joel.chevallier@...> > wrote: > >> ** >> >> >> Jammie, >> >> Thanks for the generous offer. I'm in the US, so I guess Ill reach out to >> Ted. >> If I can figure out a way to edit samples without buying an older >> computer >> and send via midi perhaps this isnt such a big deal. Can this be done >> with >> any software than runs on a new Mac? >> >> Thanks again! >> >> Joel >> >> On Nov 26, 2011, at 3:17 PM, "jack" <jammie.emma@...> wrote: >> >> > SOUNDS LIKE YOU HAVE A ADC PROBLEM >> > >> > send analog board to me and ill check it if i cant fix it i have spares >> > >> > first where do you live if you are in us ask ted to have a look if in >> > uk >> you can send to me jammie logan >> > synth and sampler repair >> > 42 glastonbury crescent >> > walsallws3 2rf >> > >> > or you can send it to epr electronics as they are authorized emu repair >> services >> > >> > but be pre pared to pay mega bucks as they charge $80 for diagnostics >> > if >> you dont get it fixed by them >> > ----- Original Message ----- >> > From: Joel Chevallier >> > To: emax@yahoogroups.com >> > Cc: emax@yahoogroups.com >> > Sent: Saturday, November 26, 2011 10:52 PM >> > Subject: Re: [emax] Low gain/ no signal on sampling inputs >> > >> > I tried my Jupiter 6, an iPod, and a turntable, all directly from the >> devices' outputs into the emax to no avail. >> > >> > -joel >> > >> > On Nov 26, 2011, at 1:10 PM, llingoapt@... wrote: >> > >> > > describe whatt your sampling source is and anyother device you run it >> through before it enters the emax >> > > >> > > ----- Original Message ----- >> > > From: "jdchevallier" <joel.chevallier@...> >> > > To: emax@yahoogroups.com >> > > Sent: Saturday, November 26, 2011 2:59:59 PM >> > > Subject: [emax] Low gain/ no signal on sampling inputs >> > > >> > > So after being content for a long time simply playing the large >> library of disk my emax se rack came with I decided to sample some drums >> today. Do my dismay there seems to be minimal/no signal coming into the >> unit. The VU has 3 bars and is set to +40. I've tried several signal >> sources and none make a difference. Does anyone have a sense of what >> might >> be wrong with my sampler??? >> > > >> > > Thanks! >> > > >> > > Joel >> > > >> > > [Non-text portions of this message have been removed] >> > > >> > > >> > >> > [Non-text portions of this message have been removed] >> > >> > No virus found in this message. >> > Checked by AVG - www.avg.com >> > Version: 2012.0.1873 / Virus Database: 2101/4640 - Release Date: >> > 11/26/11 >> > >> > [Non-text portions of this message have been removed] >> > >> > >> >> [Non-text portions of this message have been removed] >> >> >> > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > > > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > Version: 2012.0.1873 / Virus Database: 2101/4640 - Release Date: 11/26/11 >
2011-11-26 by jack
hi nik how are you all work is done just waiting for slim floppy convertor to turn up i rang the wholesaler he promised it will definetly be here for monday ive pre fitted a cf drive drilled the holes for it so that i could test scsi so when you get a drive it will just be to screw it in
> Jammie,
> Thanks again!
> Joel
[Non-text portions of this message have been removed]2011-11-27 by Nik Kinloch
Hey Jack, nice one mate! I'm doing fine, windy weekend up here, but going mountain biking tomorrow! Hope you are well down there. I was having second thoughts about getting the screen done, but then car broke down again yesterday and hand to get two batteries = �180, plus TAX, plus MOT and service, plus insurance... so I guess that will just have to wait :-/ Cheers, Nik
On 26/11/2011 23:59, jack wrote: > hi nik how are you > > all work is done just waiting for slim floppy convertor to turn up i rang the wholesaler > > he promised it will definetly be here for monday > > ive pre fitted a cf drive drilled the holes for it so that i could test scsi so when you get a drive it will just be to screw it in > ----- Original Message ----- > From: Nik Kinloch > To: emax@yahoogroups.com > Sent: Saturday, November 26, 2011 11:33 PM > Subject: Re: [emax] Low gain/ no signal on sampling inputs > > > > You can hook it up to a PC using http://www.emxp.net/ + a small > electronics project to convert the serial to USB properly. > > Or buy an Apple II and use some old software > http://www.emulatorarchive.com/Samplers/EmaxOverview/EmaxEditors/emaxeditors.html > > On 26/11/2011 23:26, Joel Chevallier wrote: > > Jammie, > > > > Thanks for the generous offer. I'm in the US, so I guess Ill reach out to Ted. > > If I can figure out a way to edit samples without buying an older computer and send via midi perhaps this isnt such a big deal. Can this be done with any software than runs on a new Mac? > > > > Thanks again! > > > > Joel > > > >
2011-11-27 by Matt
Google elektron c6 or wait till I'm done with family crab dinner and ill link you. On Nov 26, 2011 3:49 PM, "Joel Chevallier" <joel.chevallier@gmail.com> wrote: > ** > > > Thanks Nik, but was hoping against hope that there would be a solution > using my new Mac/that doesn't require me purchasing a pc or older Mac. > Joel > > On Nov 26, 2011, at 3:33 PM, Nik Kinloch <nikkinloch@...> wrote: > > > You can hook it up to a PC using http://www.emxp.net/ + a small > > electronics project to convert the serial to USB properly. > > > > Or buy an Apple II and use some old software > > > http://www.emulatorarchive.com/Samplers/EmaxOverview/EmaxEditors/emaxeditors.html > > > > On 26/11/2011 23:26, Joel Chevallier wrote: > > > Jammie, > > > > > > Thanks for the generous offer. I'm in the US, so I guess Ill reach out > to Ted. > > > If I can figure out a way to edit samples without buying an older > computer and send via midi perhaps this isnt such a big deal. Can this be > done with any software than runs on a new Mac? > > > > > > Thanks again! > > > > > > Joel > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed]
2011-11-27 by Matt
http://www.elektron.se/support-and-downloads On Nov 26, 2011 5:07 PM, "Matt" <somatt@...> wrote: > Google elektron c6 or wait till I'm done with family crab dinner and ill > link you. > On Nov 26, 2011 3:49 PM, "Joel Chevallier" <joel.chevallier@...> > wrote: > >> ** >> >> >> Thanks Nik, but was hoping against hope that there would be a solution >> using my new Mac/that doesn't require me purchasing a pc or older Mac. >> Joel >> >> On Nov 26, 2011, at 3:33 PM, Nik Kinloch <nikkinloch@...> wrote: >> >> > You can hook it up to a PC using http://www.emxp.net/ + a small >> > electronics project to convert the serial to USB properly. >> > >> > Or buy an Apple II and use some old software >> > >> http://www.emulatorarchive.com/Samplers/EmaxOverview/EmaxEditors/emaxeditors.html >> > >> > On 26/11/2011 23:26, Joel Chevallier wrote: >> > > Jammie, >> > > >> > > Thanks for the generous offer. I'm in the US, so I guess Ill reach >> out to Ted. >> > > If I can figure out a way to edit samples without buying an older >> computer and send via midi perhaps this isnt such a big deal. Can this be >> done with any software than runs on a new Mac? >> > > >> > > Thanks again! >> > > >> > > Joel >> > > >> > > >> > >> > >> >> [Non-text portions of this message have been removed] >> >> >> > [Non-text portions of this message have been removed]
2011-11-27 by Joel-David Chevallier
So I purchased DSP-Quattro in a moment of desperation, hoping to get samples transferring to the emax. I've resampled and I'm sending over in 12-bit, but I keep getting an error on the emax: "Aborted - back ACK for packet #0000". I've searched online and looked through my manual, but no hints as to what I'm doing wrong. Anyone seen this error? Joel
On Sat, Nov 26, 2011 at 7:11 PM, Matt <somatt@...> wrote: > http://www.elektron.se/support-and-downloads > On Nov 26, 2011 5:07 PM, "Matt" <somatt@...> wrote: > >> Google elektron c6 or wait till I'm done with family crab dinner and ill >> link you. >> On Nov 26, 2011 3:49 PM, "Joel Chevallier" <joel.chevallier@...> >> wrote: >> >>> ** >>> >>> >>> Thanks Nik, but was hoping against hope that there would be a solution >>> using my new Mac/that doesn't require me purchasing a pc or older Mac. >>> Joel >>> >>> On Nov 26, 2011, at 3:33 PM, Nik Kinloch <nikkinloch@...> wrote: >>> >>> > You can hook it up to a PC using http://www.emxp.net/ + a small >>> > electronics project to convert the serial to USB properly. >>> > >>> > Or buy an Apple II and use some old software >>> > >>> http://www.emulatorarchive.com/Samplers/EmaxOverview/EmaxEditors/emaxeditors.html >>> > >>> > On 26/11/2011 23:26, Joel Chevallier wrote: >>> > > Jammie, >>> > > >>> > > Thanks for the generous offer. I'm in the US, so I guess Ill reach >>> out to Ted. >>> > > If I can figure out a way to edit samples without buying an older >>> computer and send via midi perhaps this isnt such a big deal. Can this be >>> done with any software than runs on a new Mac? >>> > > >>> > > Thanks again! >>> > > >>> > > Joel >>> > > >>> > > >>> > >>> > >>> >>> [Non-text portions of this message have been removed] >>> >>> >>> >> > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > > > >
