My Quadra has 64mb of Ram. I guess I'll stick to Alchemy. The cache could
give problems.
It's mainly for editing the samples. The rest, like parameters, I prefer to
use the Emax itself. Then, EMXP does the job for backups.
So I won't bother.
Thanks a lot!
On Tue, Jan 3, 2012 at 5:21 AM, esynthesist <esynthesist@...> wrote:
> Most functions of SD for Emax work fine on the Emax-II.
> That includes real time control of all functions of the Emax-II which were
> also available on Emax-I.
> And it also includes sample transfer (12-bit only though) and bank
> transfer (but only upload to Emax-II, not download, that's a limitation of
> the Emax-II OS.
> However, samples larger than 512K can not be transferred properly. In that
> case SD for Emax will only transfer a small portion of the sample, i.e. the
> size of the sample minus K*512K :-)
> ///E-Synthesist
> --- In emax@yahoogroups.com, Francis Cote <francis.cote@...> wrote:
> > If it is only for the Emax 1, I won't try to make it work. It doesn't
> > explain why it crashes like that.
> > Anyways, thanks for answering.
> > On Mon, Jan 2, 2012 at 6:27 PM, rjmm1900 <rjmacarthur@...> wrote:
> > > I believe Sound Designer EMAX only works on the original EMAX not EMAX
> II
> > > Also you don't have to use a Zip Drive to run this software.
> > > If you load the SDEMAX.hfs file into Basilisk II (Macintosh Emulator)
> You
> > > can make a data
> > > image of the HFS with Disk Copy 6.22 in .IMG format and you can copy
> the
> > > .IMG to your Macintosh and mount it.
> > > --- In emax@yahoogroups.com, Francis Cote <francis.cote@> wrote:
> > > > Hi guys,
> > > > I've managed to make a clean install of 7.5.5 on my Quadra 700. I
> can use
> > > > Alchemy fine with my Emax 2.
> > > > I tried the SDEmax which runs on an image on Zip drive. I did as
> > > written, I
> > > > used the exe program and created the image on Zip 100.
> > > > The Zip is recognized fine. When try starting sound designer, it
> crashes
> > > > bad.
> > > > The screen says :
> > > > Sorry, a system error occured.
> > > > "Sound Designer Emax 1.13"
> > > > CHK error.
> > > > Means anything to one of you?
> > > > Thanks
> > > > Francis
> > > > [Non-text portions of this message have been removed]
