Emax II CD-ROM "Not EMAX2 drive"
2011-12-31 by Will
2011-12-31 by Will
I found some ISO files for the Elements Of Sounds CDs and when I burned them to a disk and tried to use them in the Emax II I got "Not EMAX2 drive". I tried burning the disks at 1x and at maximum speed and I got the same result. The drive is an AppleCD 300e Plus. Is it the drive or the ISO files themselves?
2011-12-31 by LIFELIKE
the CDROM drive in itself i think... Le 31 d�c. 2011 � 19:00, Will a �crit : > I found some ISO files for the Elements Of Sounds CDs and when I burned them to a disk and tried to use them in the Emax II I got "Not EMAX2 drive". I tried burning the disks at 1x and at maximum speed and I got the same result. The drive is an AppleCD 300e Plus. > > Is it the drive or the ISO files themselves? > > [Non-text portions of this message have been removed]
2011-12-31 by jammie
depends on where you got the iso,s from
To: emax@yahoogroups.com
Sent: Saturday, December 31, 2011 6:00 PM
Subject: [emax] Emax II CD-ROM "Not EMAX2 drive"
[Non-text portions of this message have been removed]2011-12-31 by Will
Well after some more poking around I fired up EMXP to check the images and it complained about something a smaller size than the E-MU formatted size. I probably should of checked them through that before burning to disk. *face palm* I've sent an e-mail to Route 66 Studios so I can purchase volumes 1-3. Since I really want the Emax I library terribly and I'd be interested experimenting with volumes 2-3. I don't know if the drive is good or not because if I try to repeatedly make the Emax II read the disk in the drive it goes crazy with a SCSI error. --- In emax@yahoogroups.com, "jammie" <jammie.emma@...> wrote:
> > depends on where you got the iso,s from > ----- Original Message ----- > From: Will > To: emax@yahoogroups.com > Sent: Saturday, December 31, 2011 6:00 PM > Subject: [emax] Emax II CD-ROM "Not EMAX2 drive" > > > > I found some ISO files for the Elements Of Sounds CDs and when I burned them to a disk and tried to use them in the Emax II I got "Not EMAX2 drive". I tried burning the disks at 1x and at maximum speed and I got the same result. The drive is an AppleCD 300e Plus. > > Is it the drive or the ISO files themselves? > > > > > > [Non-text portions of this message have been removed] >
2012-01-01 by esynthesist
Just for information: this warning message displayed by EMXP does not necessarily mean that the disk is not an Emax2 disk. It only means that the original disk on which the banks were originally collected was bigger in size than the cdrom on which this disk was copied later on. E.g. some sample production company originally used an 850MB SCSI Hard Disk to create the collection of banks on an Emax-II, but the total size of all 100 banks does not exceed 300MB. Then they copied the "used part" of the hard disk to a cdrom, including the index which still says that th original disk was formatted for 850MB. I think this way of working was even quite common practice at the time, so that's why EMXP is showing this message pretty often. BTW: Did you check both the ISO images and the burned CDROMs on EMXP ? I you mention were you have found the ISO files, perhaps we can check whether they are indeed corrupt too. Anyway, I would say: if EMXP is showing the bank overview after skipping this warning messge, the cdrom is probably OK and Emax2 compliant. But if I remember well, the Apple CD300e Plus is giving problems with the Emax2. I think you need a more basic version, like the Apple CD300 which works fine (I have one...) ///E-Synthesist --- In emax@yahoogroups.com, "Will" <deadtotheworld002@...> wrote:
> > > > > Well after some more poking around I fired up EMXP to check the images and it complained about something a smaller size than the E-MU formatted size. I probably should of checked them through that before burning to disk. *face palm* > > I've sent an e-mail to Route 66 Studios so I can purchase volumes 1-3. Since I really want the Emax I library terribly and I'd be interested experimenting with volumes 2-3. > > I don't know if the drive is good or not because if I try to repeatedly make the Emax II read the disk in the drive it goes crazy with a SCSI error. > > > --- In emax@yahoogroups.com, "jammie" <jammie.emma@> wrote: > > > > depends on where you got the iso,s from > > ----- Original Message ----- > > From: Will > > To: emax@yahoogroups.com > > Sent: Saturday, December 31, 2011 6:00 PM > > Subject: [emax] Emax II CD-ROM "Not EMAX2 drive" > > > > > > > > I found some ISO files for the Elements Of Sounds CDs and when I burned them to a disk and tried to use them in the Emax II I got "Not EMAX2 drive". I tried burning the disks at 1x and at maximum speed and I got the same result. The drive is an AppleCD 300e Plus. > > > > Is it the drive or the ISO files themselves? > > > > > > > > > > > > [Non-text portions of this message have been removed] > > >
2012-01-01 by jammie
esynthesis is right i have had iso images that have been 512mb but the 100 banks are only 300mb and had the same message also the cd300 is the only apple one to work the e version was a later issue and ans scsi 2 spec and was not complient with the emax2 or e3 but does work with the emulator eos samplers i have a cd300 and it does work with the emax2 and e3 but are rare if you have a zip drive then use emxp to read the iso and transfer the banks to the zip drive
Sent: Sunday, January 01, 2012 11:18 AM
Subject: [emax] Re: Emax II CD-ROM "Not EMAX2 drive"
///E-Synthesist
> > From: Will
