HELLO emax II Ram upgrad 8 MB
2012-02-23 by Vavasseur Philippe
I have an emax II 2 MB keyboard version I buy a rack 8 MB and I want to recover the 8 Mb and placed in the keyboard 2 mb and put in the rack the main board is not compatible Between the keyboard and rack version the control panel and not the same what ic Which Holds the information ??
2012-02-23 by Simon Forsyth
you are getting confused between the display board and the main board.. the main board holds the relevant ICs and is perfectly interchangeable between keyboard and rack ________________________________
From: Vavasseur Philippe <philippe.69@...> To: emax@yahoogroups.com Sent: Thursday, 23 February 2012, 19:49 Subject: [emax] HELLO emax II Ram upgrad 8 MB I have an emax II 2 MB keyboard version I buy a rack 8 MB and I want to recover the 8 Mb and placed in the keyboard 2 mb and put in the rack the main board is not compatible Between the keyboard and rack version the control panel and not the same what ic Which Holds the information ?? [Non-text portions of this message have been removed]
2012-02-24 by philippe.69
I tested the exchange of mainboard it does not start for the 3rd time the panel button and lcd are not compatible between emax II Rack and emax II Keyboard -----Message d'origine----- De : emax@yahoogroups.com [mailto:emax@yahoogroups.com] De la part de Simon Forsyth Envoyé : vendredi 24 février 2012 00:35 À : emax@yahoogroups.com Objet : Re: [emax] HELLO emax II Ram upgrad 8 MB you are getting confused between the display board and the main board.. the main board holds the relevant ICs and is perfectly interchangeable between keyboard and rack ________________________________
From: Vavasseur Philippe <philippe.69@...> To: emax@yahoogroups.com Sent: Thursday, 23 February 2012, 19:49 Subject: [emax] HELLO emax II Ram upgrad 8 MB I have an emax II 2 MB keyboard version I buy a rack 8 MB and I want to recover the 8 Mb and placed in the keyboard 2 mb and put in the rack the main board is not compatible Between the keyboard and rack version the control panel and not the same what ic Which Holds the information ?? [Non-text portions of this message have been removed] ------------------------------------ Emax and Emax II User's Group Website http://www.silveriafamily.comYahoo! Groups Links
2012-02-24 by Simon Forsyth
well.. I have transplanted successfully.. the panel board doesn't even come into it ________________________________
From: philippe.69 <philippe.69@...> To: emax@yahoogroups.com Sent: Friday, 24 February 2012, 5:12 Subject: RE: [emax] HELLO emax II Ram upgrad 8 MB I tested the exchange of mainboard it does not start for the 3rd time the panel button and lcd are not compatible between emax II Rack and emax II Keyboard -----Message d'origine----- De : emax@yahoogroups.com [mailto:emax@yahoogroups.com] De la part de Simon Forsyth Envoyé : vendredi 24 février 2012 00:35 À : emax@yahoogroups.com Objet : Re: [emax] HELLO emax II Ram upgrad 8 MB you are getting confused between the display board and the main board.. the main board holds the relevant ICs and is perfectly interchangeable between keyboard and rack ________________________________ From: Vavasseur Philippe <philippe.69@...> To: emax@yahoogroups.com Sent: Thursday, 23 February 2012, 19:49 Subject: [emax] HELLO emax II Ram upgrad 8 MB I have an emax II 2 MB keyboard version I buy a rack 8 MB and I want to recover the 8 Mb and placed in the keyboard 2 mb and put in the rack the main board is not compatible Between the keyboard and rack version the control panel and not the same what ic Which Holds the information ?? [Non-text portions of this message have been removed] ------------------------------------ Emax and Emax II User's Group Website http://www.silveriafamily.comYahoo! Groups Links [Non-text portions of this message have been removed]
2012-02-24 by emax_dx5
Philippe: What are the symphtoms for a non starting?. Does the display show something?. Are voltages OK and stable on the power supply outputs? I agree with Chevy, both motherboards should be interchangeable, as long as the Sub CPU Scanner (IM386) contains the same programming code for both Keyboard and Rack versions (and as far as I remember, rack board also has the Keyboard male socket alreay installed). Is there any Internal device as HD installed in the rack version that is not present in the Keyboard(or vice versa?) --- In emax@yahoogroups.com, "philippe.69" <philippe.69@...> wrote:
> > I tested the exchange of mainboard it does not start for the 3rd time the panel button and lcd are not compatible between emax II Rack and emax II Keyboard > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links >
2012-03-04 by philippe.69
the exchange of memory and made I have the 8 Mb on my keyboard and 2 mb's in the rack I sell the rack with SCSI drive CF install + slim floppy drive with the complete collection Omi Universe 3 CD emulator and all the colection Emu E2,E3 and even bank for zip ALAN -----Message d'origine----- De : emax@yahoogroups.com [mailto:emax@yahoogroups.com] De la part de emax_dx5 Envoyé : vendredi 24 février 2012 17:47 À : emax@yahoogroups.com Objet : [emax] Re: HELLO emax II Ram upgrad 8 MB Philippe: What are the symphtoms for a non starting?. Does the display show something?. Are voltages OK and stable on the power supply outputs? I agree with Chevy, both motherboards should be interchangeable, as long as the Sub CPU Scanner (IM386) contains the same programming code for both Keyboard and Rack versions (and as far as I remember, rack board also has the Keyboard male socket alreay installed). Is there any Internal device as HD installed in the rack version that is not present in the Keyboard(or vice versa?) --- In emax@yahoogroups.com, "philippe.69" <philippe.69@...> wrote: > > I tested the exchange of mainboard it does not start for the 3rd time the panel button and lcd are not compatible between emax II Rack and emax II Keyboard > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > ------------------------------------ Emax and Emax II User's Group Website http://www.silveriafamily.comYahoo! Groups Links
